Handicap Distance Tasks
Old January 27th 16, 03:43 PM posted to rec.aviation.soaring
Jim White[_3_]
Default Handicap Distance Tasks
I have been following the arguments about Flarm as well as US task setting
with interest. I do not wish to confuse the picture further but I do want
to point out that Handicap Distance Tasks solve many of the complaints
about standard assigned tasks (including leeching).
With HDTs we recognise the glider's handicap in the task, not in the
scoring. This means that every pilot can fly at the same time of day, in
the same air, for roughly the same time on task.
We have been using HDTs successfully in UK rated competition for two
seasons with great pilot feedback. It needs a bit of software for task
setting and if you want to use See You to score them, there is a second bit
of software that prepares the evidence for this.
Following requests from a couple of US clubs, I have put a lot of effort
into modifying this software to be used with the US handicap system, US
Miles, SSA distance calculation rules, and scoring formulae. I would be
delighted if more of you guys gave it a look.
handicaptask.uk or pm me for more information.
ps: If you want to modify your own scoring software, I can tell you how.
Old January 27th 16, 05:07 PM posted to rec.aviation.soaring
howard banks
Jim:
I passed your earlier (UK specific) software to the US competition Committee. Requested that they take a look. They did and rejected it pretty sumararily, though I was not at all clear why. I am a techno-illiterate so that may not be surprising. But their reaction was.
You might try approaching John Godfrey, current chair of the Competition Committee directly and see if you can get any better response, especially now you have Americanized the program.
Howard
Old January 28th 16, 12:53 AM posted to rec.aviation.soaring
smfidler
Great idea. Simple and easy and Fun.
Your handicap task would be a great innovation for US sports class (handicaps from 126 to Concordia). I imagine that the USRC did not like the idea that all pilots essentially had their own un-timed, assigned task (with greater lateral variability as you go down in handicap) in which no extra distance could be added (not timed). Also, the work is complete and it's ready to go! No complex scoring equations are required. We can't have this kind of simplicity in the US! ;-)
I prefer non handicap classes (I think we all do) but this new task would definitely make handicap flying (or club flights as you mention) MUCH more fun and interesting.
I wish you success and thank you for the great effort you (and likely many others) have put into developing this cool new task. Very impressive. I will try it at my flying site in the spring.
Sean Fidler
Old January 28th 16, 06:41 AM posted to rec.aviation.soaring
krasw
We tried similar idea 5 years ago in GrandPrix-style contest, where traditional handicapping is not possible. I made simple formula for calculating turnpoint barrel radius for individual competitors:
R = D / 2N * ( 1 - k/k0 ) + 0,5 * k/k0
R is radius
D task length
N number of turnpoints
k0 handicap of the best glider participating
k your handicap
All distance units kilometers.
It works well enough if angle between legs is large, out-and-return legs being optimal.
Old January 28th 16, 05:05 PM posted to rec.aviation.soaring
Jim White[_3_]
R is radius
D task length
k your handicap
being optimal.
This is where we started but the present system is somewhat more refined.
In the UK we use windicapping which skews towards low handicap gliders as
the wind strength increases.
We also realised that the shortest way around the task is not to go
directly towards the centre of the barrel, nor to the point where the
bisector intersects the barrel circumference.
So we measure the shortest (handicapped or windicapped)path around task for
each barrel size step and compare to the reference task length * handicap
(/handicap in US). This iterative process arrives at the barrel size that
best fits the desired task length for each handicap flying.
Our software will cope with start lines of any length, variable barrels,
acute and oblique turns, checkpoints, angled finish lines and finish
rings.
It then prints a handy briefing document for the pilots.
If you put a task into the calculator then export it into SeeYou you will
see what I mean.
Old January 30th 16, 10:43 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
It's a very interesting idea. A couple of questions.
What are the implications for leeching and does the handicapping account for the fact that this likely makes it easier for lower handicap gliders to hang back a bit and use higher performance gliders as markers throughout the task.
In uniform weather this seems fine, but what about tasks where flying farther requires the higher performance gliders to face blue holes, thunderstorms, getting off convergence lines and the like.
These were questions that were asked of me when I asked some experienced pilots about it and I had no experience from which to provide an answer.
9B
Old January 31st 16, 02:09 AM posted to rec.aviation.soaring
jfitch
9B
Andy, I can answer those questions from some experience.
Everybody has to fly the same course, but higher performance gliders must fly further into the turnpoint cylinder than lower performance, as their radius is smaller. If one is leeching from the other, they will loose each other at each turn point (or at least, the low performance will turn first and then the high performance might leech temporarily in passing to the next turnpoint). The contests we have flown at Truckee like this are simultaneous start, or effectively so. In a perfectly flown contest by all participants, they will see each other only at the start, once between each turnpoint (though maybe not then - see below), and at the simultaneous finish.
For the most part, the weather will be similar, since the handicap difference in radius is usually only a few miles at each turnpoint. Of course it can happen that the only thermal in the area is right at the low performance or high performance turnpoint, which will favor that glider. If the difference in handicap is large, then the best course between two handicapped turnpoints might differ which again might favor one or the other. Some of this can be mitigated by choosing intelligent turnpoints to handicap (not all of them need be).
If run with a simultaneous start and open Flarm, this kind of racing is far more like real racing than traditional US sailplane racing (which is really a time trial). You start at the same time, you can see how you are doing against your fellow competitors, in between each handicapped turnpoint the difference is accounted for and you are even again. Just like real racing.
Old January 31st 16, 02:28 AM posted to rec.aviation.soaring
Giaco
9B
If run with a simultaneous start and open Flarm, this kind of racing is far more like real racing than traditional US sailplane racing (which is really a time trial). You start at the same time, you can see how you are doing against your fellow competitors, in between each handicapped turnpoint the difference is accounted for and you are even again. Just like real racing..
Would it be possible to use Winscore to score a task using this method currently? Is there a reason that we couldn't start trying out this method in US Sanctioned contests?
Old January 31st 16, 05:43 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Scoring seems like a significant issue - presumably you set up a nominal distance and just score off of raw time no matter what handicapped distance was flown. I'm guessing Winscore would have trouble with variable task lengths with dynamically created waypoints for each task for each pilot, so you'd have to assume people flew their assigned task on an honor system - or do a lot of manual checking. Landouts would also would require manual work.
Unless the software that sets up the task can also read the IGC files and score the flights?
9B
Old January 31st 16, 09:26 AM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
di=
w=
lengt=
you'=
do=
s=
core the flights?=20
9B
The DHT software suite will pre-process each IGC file and insert the task
flown (which will be different for each handicap value) into the file.
SeeYou will use this task when scoring.
Come to UK this Summer and see it in action.
WGC Day 11 Tasks Set Duster Soaring 1 August 16th 12 05:30 PM
handicap 5 ugly Soaring 1 November 26th 11 01:57 AM
How is handicap weight determined for the SSA handicap list? AK Soaring 1 September 25th 07 01:43 PM
Tasks??? Jack Soaring 2 July 4th 06 12:16 AM
Handicap bargains Ian Cant Soaring 8 December 29th 05 04:01 AM
