RAAF releases jet fighter back-up plan
Old June 9th 04, 02:47 AM
JD
Default RAAF releases jet fighter back-up plan
rec.aviation.military added.
"Brash" wrote in message u...
They should lease 24 F-15E's until JSF come on-line.
JSF = F-35?
The Air Force should lease F-16Es (http://tinyurl.com/2vdm7) as a
replacement for the F/A-18 until the F-35 is ready for production,
which may take a decade longer than anticipated based on the F-22
experience.
To replace the capability of the F-111, simply lease F-15Ts, which is
a vastly more capable long range strike aircraft than the F-35 anyway.
Any concerns over range are immediately dispelled now that we are
getting refuelling capability.
These aircraft are proven, modern and cheaper.
As always, we won't get the best, most cost effective solution as ego
and politics intervene.
A really good analysis of the JSF is located at
http://tinyurl.com/yvxkn
Old June 9th 04, 08:32 AM
Ron the Barbarian
(JD) wrote in
om:
u...
JSF = F-35?
experience.
The ADF won't buy that!
Civilians rule Defence, the cheapest quote will win, as always....
Old June 9th 04, 02:12 PM
Kevin Brooks
"JD" wrote in message
om...
u...
JSF = F-35?
experience.
How many Block 60's have you seen offered for "lease"? The only lease deal
for F-16's that I know of is the Italian one, for refurbished old F-16 ADF
variants.
Again, how many F-15's of *any* type, much less the Tango, have been leased,
or offered for lease?
An F-15T is cheaper than what the F-35 is supposed to cost?
But you may get a more realistic one than the lease of late model variants
that are the least likely to be offered on lease.
Brooks
Old June 9th 04, 05:04 PM
DC
JD said the following on 9/06/2004 9:47 AM:
JSF = F-35?
experience.
The RAAF originally selected the F/A-18 over the F16. I don't see
them acquiring any F16s.
The Mustang was proven, modern and cheaper at the end of WWII but it
was still outclassed by the latest jet technology.
Isn't the F22 the best. Cost effective - that depends on what the
opposing force has. Mustangs would be pretty cost effective if the
other side has Sopwith Camels. However, if the other guy is in an
F35 then I'd feel more cost effective in an F22.
Old June 10th 04, 03:10 AM
JD
"Kevin Brooks" wrote in message ...
om...
u...
JSF = F-35?
experience.
variants.
But we have a special relationship. It is something we should be
considering. Only a fool thinks that the F-35 will be delivered on
time.
Off hand i don't know, but that doesn't prevent us asking for them.
Certainly. The latest F-15 is in production for less than half of the
production cost of the F-22, which is marginally more expensive than
the proposed cost for the F-35.
Granted, but it doesn't hurt to ask and it is a better plan than
putting missiles on Orions!
Old June 10th 04, 03:19 AM
JD
DC wrote in message .au...
JSF = F-35?
experience.
Did that have something to do with HMAS Melbourne, or is that a furphy?
False analogy.
Old June 10th 04, 04:04 AM
Kevin Brooks
om...
om...
u...
JSF = F-35?
experience.
deal
ADF
variants.
considering.
I don't think our "special relationship" has much to do with it. As long as
LMCO can keep finding *buyers* for the F-16 Block 60 they are not going to
be too interested in doing a lease deal with anyone unless it is one that
offers them an end outcome as favorable as purchasing does. Purchase price
for a Block 60 is over $30 million per--not too awful far from the estimated
price range of the F-35.
time.
When is "on time"? Yeah, the originally projected schedule has slipped a
year or so, IIRC--no big surprise there. But the USAF, and especially the
USMC, are facing a real timecrunch in the future as to replacing some of
their older airframes (especially F/A-18 early mods and AV-8B's), so I sort
of see a lot of pressure to keep the F-35 schedule in the current ballpark.
leased,
The answer is "none". The only US manufactured combat aircraft currently
available for lease are older F-16 versions. The USAF does not have an
overabundance of E models just sitting around, so that source is a
non-starter. Boeing is going to keep the F-15 line going for as long as they
can sell them, but they would be unlikely to agree to a lease deal
(especially for the paltry number you are talking about) unless they can
plan on recouping a roughly similar profit margin from the deal. What you
are proposing appears to be quite a bit different from the Boeing proposal
to lease 767's to the USAF, where they have been keen to keep the current
assembly line operating; the F-15 production line is in its twilight years
( I doubt there will be much chance of selling new-builds to anyone else
after the Singapore selection is done with).
Estimates I have seen for the F-35 start at around $38 million
(http://www.globalsecurity.org/milita...craft/f-35.htm) and run
to $45 million per (http://tnr.com/easterbrook.mhtml?pid=777). Cost for an
F-15 back in the late 98 was running around $43 million (according to FAS)
per, IIRC--the F-15K is costing the ROKAF some $3.2 billion for 40 aircraft,
which is around $80 million per copy. So I am not sure your solution is the
slam-dunk "cheaper" option that you portray it as being ($80 million per
leaves a LOT of expansion room for the F-35 unit cost to expand and still
come in under the F-15K).
variants
If the RAAF really had its back to the wall in terms of replacing the F-111
with a similarly capable strike platform in the near term, and leasing is
the way you want to go, I'd suggest that a more realistic way of taking
advantage of that "special relationship" would be to talk the US into
loaning (or leasing at nominal/symbolic rate) about four B-1B's. That way
you only require a minimum of 16 rated aircrew (and IIRC keeping aircrew for
the current F-111 fleet has been a significant problem) to keep them mission
capable, and each one hauls a lot of munitions. Getting an older aircraft
like that at good terms would be a lot more likely than your F-15T at
similarly good terms option, IMO. Scratch the F-16 proposal at the get-go;
keep your F/A-18's flying and updated until the F-35 is available.
Brooks
Old June 10th 04, 05:04 AM
Michael Kelly
Kevin Brooks wrote:
[Snip]
Brooks
Kevin,
Doubt you'd only want a fleet of 4 of any aircraft. I've had the
experience of trying to support 3 customers with a squadron of only 6
Bones (6 + 1 in depot), and it wasn't pretty. This is at a base with
two other squadrons flying another 24 planes, 4 would be unworkable.
Furthermore, there aren't enough Bones left to lease four unless
congress backs off from bringing the 23 out of retirement (7 are gone
for good). Even at that not sure you'd want the ones at DM, pretty
picked over.
That said, it could be workable with a fleet size of 10 or 11 if the US
follows through with the plans to stand up a squadron in Guam. Although
that would depend on us only bringing back 11-12.
Cheers,
Michael Kelly
Bone Maintainer
Old June 10th 04, 05:47 AM
Kevin Brooks
"Michael Kelly" wrote in message
m...
Kevin Brooks wrote:
[Snip]
F-111
is
way
for
mission
aircraft
get-go;
Brooks
Kevin,
picked over.
Good and valid points. The only way something like this would work is if the
maintenance/spares chain remained tied to the USAF. I'd still think a
nominal force (i.e., that figure of four, or even six, for example) could
work (albeit with extra money appropriated to procure spares, but if the
aircraft procurement cost is negligable, that makes the spending for spares
more palatible), especially if they had a maintenace relationship with the
USAF at Guam. But hey, this was all a "what if" inspired only by what I saw
as an even more implausible proposal (that whole leased F-15/F-16 idea).
I guess one way around these problems would be a more radical proposal, but
one that could serve both US and Aussie needs. That would be an agreement
that put a rotating detachment of USAF B-1B's at some RAAF base, with the
USAF in turn handing off the requisite four aircraft to the RAAF and
agreeing to handle their higher level maintenance in conjunction with our
own detachment's aircraft. The USAF gains another forward operating base in
an area that it does not have much in now, and the RAAF maintains its own
strike capability at minimal cost. Even if we did something like that and
took the aircraft "out of hide" it would likely not be a loss of capability,
as we and they tend to follow the same general course in that part of the
world. Of course, this is all fantasy play--not a chance in hell of
something like that ever actually happening, I'd think.
Brooks
Cheers,
Michael Kelly
Bone Maintainer
Canadian IFR/VFR Flight Plan gwengler Instrument Flight Rules 4 August 11th 04 03:55 AM
Why was the Fokker D VII A Good Plane? Matthew G. Saroff Military Aviation 111 May 4th 04 05:34 PM
RAAF back up to 6 Wedgetails Henry J Cobb Military Aviation 0 May 2nd 04 05:18 PM
A-4 / A-7 Question Tank Fixer Military Aviation 135 October 25th 03 03:59 AM
