Glider Racing in the future
Old February 14th 16, 10:39 PM posted to rec.aviation.soaring
SF
Default Glider Racing in the future
I was at a sports class nationals a few years ago, and One 1-26 competed. The only day he didn't land out, was near the end of the contest, and when he landed every other competitor there quit de-rigging, and gave him a standing ovation all down the runway as he landed. Never bring a knife to a gun fight.
SF
  #32
Old February 14th 16, 11:53 PM posted to rec.aviation.soaring
Nice to hear SF, granted one has to be slighty masocistic to try and compete in even a sport class contest with a 1-26 but I applaud that brave soul for going for it. I can say this from experience, if/when that guy moves up to anything with an l/d over 30/1 he is going to be a much better pilot than if he had never spent that time working xc in the schweizer. I did my early xc work in one then moved up to a pilatus, then up to a ventus, the struggle experienced in those lower performance birds paid of in big dividends when I finaly got into something with the performance to mask many of my mistakes. I'm now going back to the 1-26 simply due to a love for one-design racing/record flying. From how things are today, the 1-26 assoc is the only viable one-design racing in existance today.
Dan
  #33
Old February 15th 16, 03:34 AM posted to rec.aviation.soaring
WB
That former 1-26 racer now flies a DG-400. His second motor glider since the 1-26. Got tired of landing out.
  #34
Old February 15th 16, 08:22 PM posted to rec.aviation.soaring
Got tired of paying tow fees
  #35
Old February 16th 16, 04:22 PM posted to rec.aviation.soaring
Soartech
All the details are in the paper from the US Naval Research Lab that you may read he
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA614555 (Downloads a PDF)
Thanks Dave!
Reading this is fascinating. Here is a quote:
"Main (control)loop rates faster than 4 Hz were
tested (up to 10 Hz), but did not appear to have a positive effect on the success of the thermal centering.
Slower rates down to 1 Hz were tested, but appeared to consistently fly through lift and have poor centering ability. The rate of 4 Hz appeared to be a good balance between computational usage and thermalling performance."
Wow, does this apply to human pilots too? If so then you have to make a decision of to turn or not and which way to turn in less than one second or you might be missing lift. Somehow this does not sound right, especially because this small scale glider is flying slower than a sailplane.
  #36
Old February 16th 16, 04:30 PM posted to rec.aviation.soaring
Thanks Dave!
Could be that the "organic computer" (human pilot) is hearing & feeling little things that indicate you're getting close to lift. This, coupled with experience:
1-Has you primed to do something
2-Allows you to focus on additional info to "premake" a decision
3-All that's left is to decide "when" to actually carry out the plan
Well...... that's how it goes for some people. ;-)
  #37
Old February 16th 16, 04:48 PM posted to rec.aviation.soaring
Giaco
"The rate of 4 Hz appeared to be a good balance between computational usage and thermalling performance."
This is rather interesting from a controls and handling qualities standpoint, given that the quickest most pilots are capable of responding to an aircraft is between 4 and 5 Hz... who would have thought we were optimized for anything related to flight!
  #38
Old February 16th 16, 09:37 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
sailplane.
Don't forget that ALOFT didn't use a vario: it took all its altitude and
climb rate data from the GPS receiver (they preferred climb rates read
off the GPS to autopilot's output because it was a less noisy signal),
but combined that with airspeed and (I think) pitch and roll rates output
by the autopilot. And then they downlinked all that to a laptop and
uploaded instructions, which they fed to the autopilot to control the
thermal search and centring.
I think they used a bidirectional link to a laptop, which did the
calculations, because there was nothing like the RaspberryPi or
BeagleBoard Black available at the time and also because it let them fine-
tune its calculations in real time while the model was in the air.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #39
Old February 16th 16, 09:48 PM posted to rec.aviation.soaring
ND
On Tuesday, February 9, 2016 at 9:40:55 PM UTC-5, SF wrote:
John can speak for himself, but my read is that he admitted to using it tactically, and he admitted to enjoying it. Don't see it credited with helping him win one. We could put John in a G-102 with a compass and a radio and he would beat most of us, without a handicap.
My vision of the future of racing does not involve electronics, its more about increasing the popularity of the sport so much That Hooters decides to offer the Sierra Fox Racing team sponsorship in the form of crew, beer wings, and a brand new glider.
Maybe not so much a vision as a wish list.
SF
SF
hear hear!
  #40
Old February 16th 16, 11:32 PM posted to rec.aviation.soaring
aibrd
My guess is that the primary consideration here is "poor centering" and not that the slower controller was missing thermals. The fact that the uav is slower can paradoxically require higher rate control. For a given bank angle, the turn rate is inversely proportional to speed. This means that a given amount of vario (or control) latency corresponds to a greater angular displacement around the circle.
This was and is a nontrivial challenge for autonomous sailplanes, especially when we try to implement an algorithmic version of something like Reichmann's method.
I think Charlie's right on another part of it. Humans (or at least this one anyway) fly with a lot of feedforward in their thermalling, that is we remember/anticipate where we felt the bump or vario jump on the last circle, and anticipate when to start making an adjustment.
I had the opportunity to fly our soaring uav two weeks with Dan's feedback and observations. For one of the weeks he had ALOFT out as well and we could compare side-by-side. ALOFT does indeed do everything on a laptop via radio link, which has advantages and disadvantages.
Compared to our carefully simulated and prepared software builds (our plane was running totally on-board), it was bizarre to see him ctrl-c his system, rewrite some code and boot the whole thing back up, all while the plane was a kilometer overhead. On the other hand, if the radio link got shaky, ALOFT couldn't thermal at all.
shameless plug
Autonomous glider presentation on Friday at the convention, learn all about them!
/shameless plug
John Bird
autonomous sailplane takeoff, landing, and spin recovery specialist
AVIA Lab, Penn State
sailplane.
org |
Outstanding video on the sport of Glider RACING Sean Fidler Soaring 22 January 22nd 15 06:45 PM
Basic glider racing presentation? [email protected] Soaring 4 October 25th 12 12:27 AM
Past Results/Future Performance Redux (Another weekend, another 2U.S. glider incidents...) BobW Soaring 0 February 6th 12 06:58 PM
Art of Racing, concluded - Langelle - Glen Martin Racing.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 28th 10 08:22 PM
Glider Racing on aopa.org and Let's Go Flying [email protected][_2_] Soaring 2 April 4th 09 05:48 PM
