#21
Tango Eight, the wire clips in your pictures are ok, but you still have to insert them in a hole in the L'Hotellie, one advantage with your clips is not having to remove the L'Hotellier when you originally install them. The Wedekind sleeves is pulled back against its spring, then when the rod is connected the sleeve is released, the sleeve under its spring tension slides over the L'Hotellier, locking it in place. To disconnect the control, the sleeve is pulled clear of L'Hotellier, the L'Hotellier can then be disengaged. I had Wedekind on my Cirrus, they are excellent, loved them. Picture of Wedekind, http://aviation.derosaweb.net/wedekind/ At 16:08 05 March 2016, Tango Eight wrote: On Saturday, March 5, 2016 at 10:22:31 AM UTC-5, Mark628CA wrote: My first Pegasus had L'Hotellier fittings with safety pins, and the small= inspection hole was barely large enough for my forearm, so everything was = by feel. I hated it. My second Pegasus had the Wedekind sleeves, and are wo= rth every penny you might spend. Control hookup went from ten minutes and m= uch cursing to about ten seconds. Perhaps we aren't talking about the same kinds of clips. I hook up, safety= and physically test six connections on my ASW-20B with one hand, by feel, = in about 90 seconds. Then I inspect by eye which takes about ten more. If= the clips are properly installed and tweaked for proper fit, they more or = less fall into place. =20 Here's a photo of a similar installation on a 20A. http://tinyurl.com/zdop= rgz Here are the clips before installation: http://tinyurl.com/zbjf6nh Those may be home made (but as far as I know you can also buy from Shempp H= irth). None of this is to suggest that Wedekind sleeves aren't up to the job or th= at installing them was a bad idea. I simply wanted to point out that there= is a good/fast/cheap option for those so inclined. best, Evan Ludeman / T8 |
Tango Eight, the wire clips in your pictures are ok, but you still have to insert them in a hole in the L'Hotellie, one advantage with your clips is not having to remove the L'Hotellier when you originally install them. |
I assembled my ASW-20B more than 300 times when I owned it and used standard aircraft safety pins. Never dropped one and it never took me more than a minute or two. :-)
5Z On Friday, March 4, 2016 at 11:08:52 AM UTC-8, Tango Eight wrote: Sheesh. Captive safety clips for the win. Make 'em yourself or buy from Schempp Hirth. Absolutely zero reason for those over engineered sleeves. Take the thousand dollars (?) or so you save and put it to a new vario. Email me and I can help you with that too :-). Evan Ludeman / T8 |
On Wednesday, March 2, 2016 at 7:06:17 PM UTC-5, ZP wrote:
Kevin, checking in to see if you ever installed them. This is still something I'm considering. Thanks. -Dirk Not yet. I got the parts and looked over everything carefully, but my IA has been tied up working on a power plane that has been rode hard and put up wet. In looking things over, I have decided to do the Wedikind Sleeves on the ailerons, and will do the Unreling on the dive brakes. The Ailerons are easier on the DG-400, they unscrew, where the dive brakes are riveted and GLUED, making it very difficult if not impossible to get them apart without damage. I checked on the price of getting new push rods and Holellier, but is was going to be ridiculous. I will have two Wedekind sleeves for sale that will fit the DG-400 after I get mine installed. Kevin |
Vernon and 5Z,
The safety pins I was referring to look like this. http://aviation.derosaweb.net/wedeki.../safetypin.jpg. While mine were tied to something to prevent loosing them in the belly of the beast, they were a bear for me to install just by feel (at least for my level of dexterity). The safety pins that you show on your ASW-20's might be a different solution to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad97-08-06_r1.pdf. Never seen them before. Were they home made? From Schleicher? Someone else? Also, maybe the location of your fittings are more accessible in the 20. On the DG's two of the fittings are easy to get to (through a small white hole while looking into darkness against bright sunlight) while two of the fittings are totally buried, invisible, and are difficult to get to at the best of times. I raise a glass to my next ship that will have automatic hookups! My $0.02 - John |
John, your links don’t work, cant see the photos. Vernon At 16:17 06 March 2016, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaw= eb.net/wedekind/documentation/safetypin.jpg. While mine were tied to somet= hing to prevent loosing them in the belly of the beast, they were a bear fo= r me to install just by feel (at least for my level of dexterity). =20 The safety pins that you show on your ASW-20's might be a different solutio= n to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad9= 7-08-06_r1.pdf. Never seen them before. Were they home made? From Schleic= her? Someone else? =20 Also, maybe the location of your fittings are more accessible in the 20. O= n the DG's two of the fittings are easy to get to (through a small white ho= le while looking into darkness against bright sunlight) while two of the fi= ttings are totally buried, invisible, and are difficult to get to at the be= st of times. I raise a glass to my next ship that will have automatic hookups! =20 My $0.02 - John=20 =20 |
On Sunday, March 6, 2016 at 12:30:08 PM UTC-5, Vernon Brown wrote:
John, your links don't work, cant see the photos. Vernon At 16:17 06 March 2016, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaw= eb.net/wedekind/documentation/safetypin.jpg. While mine were tied to somet= hing to prevent loosing them in the belly of the beast, they were a bear fo= r me to install just by feel (at least for my level of dexterity). =20 The safety pins that you show on your ASW-20's might be a different solutio= n to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad9= 7-08-06_r1.pdf. Never seen them before. Were they home made? From Schleic= her? Someone else? =20 Also, maybe the location of your fittings are more accessible in the 20. O= n the DG's two of the fittings are easy to get to (through a small white ho= le while looking into darkness against bright sunlight) while two of the fi= ttings are totally buried, invisible, and are difficult to get to at the be= st of times. I raise a glass to my next ship that will have automatic hookups! =20 My $0.02 - John=20 =20 They both just worked for me. Older Windows & Chrome browser. |
#28
This looks like what I used:
http://www.mcmaster.com/#90174a112/=11fc3wv 5Z On Sunday, March 6, 2016 at 8:17:42 AM UTC-8, Oscar-Hotel-Mike wrote: Vernon and 5Z, The safety pins I was referring to look like this. http://aviation.derosaweb.net/wedeki.../safetypin.jpg. While mine were tied to something to prevent loosing them in the belly of the beast, they were a bear for me to install just by feel (at least for my level of dexterity). The safety pins that you show on your ASW-20's might be a different solution to the issue covered in the AD. http://ntl.bts.gov/lib/5000/5700/5722/ad97-08-06_r1.pdf. Never seen them before. Were they home made? From Schleicher? Someone else? Also, maybe the location of your fittings are more accessible in the 20. On the DG's two of the fittings are easy to get to (through a small white hole while looking into darkness against bright sunlight) while two of the fittings are totally buried, invisible, and are difficult to get to at the best of times. I raise a glass to my next ship that will have automatic hookups! My $0.02 - John |
#29
Kevin, I'll buy the other 2 sleeves from you (for a DG202).
Thanks. -Dirk |
#30
Le dimanche 6 mars 2016 16:27:13 UTC+1, a écrit*:
On Wednesday, March 2, 2016 at 7:06:17 PM UTC-5, ZP wrote: Kevin, checking in to see if you ever installed them. This is still something I'm considering. Thanks. -Dirk Not yet. I got the parts and looked over everything carefully, but my IA has been tied up working on a power plane that has been rode hard and put up wet. In looking things over, I have decided to do the Wedikind Sleeves on the ailerons, and will do the Unreling on the dive brakes. The Ailerons are easier on the DG-400, they unscrew, where the dive brakes are riveted and GLUED, making it very difficult if not impossible to get them apart without damage. The glue is Araldit. If you heat it up to around 100°C, it will come apart easily. |
| Thread Tools | |
| Display Modes | |
| Wedekind sleeve | Hartley Falbaum[_2_] | Soaring | 4 | February 5th 14 01:54 PM |
| Wedekind sleeve for Std Cirrus | John Galloway | Soaring | 8 | July 9th 13 03:15 PM |
| pvc tubing/sleeve source? | Jim Burns | Owning | 4 | September 28th 06 04:36 AM |
| pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 04:36 AM |
| Source for Wedekind sleeves - AS-W20a | Mark Grubb | Soaring | 7 | April 6th 04 09:19 PM |
