Shameless update from Dale Kramer
Old March 16th 16, 02:07 PM posted to rec.aviation.soaring
DaleKramer
Default Shameless update from Dale Kramer
Some of you know who I am and that I have not had a real sailplane since I sold my Ventus2CX a few years ago. I am still waiting for Flarms to be mandatory in all contests before I try to find a way back into competition.
What I have been doing is flying my electric Lazair and RV8.
A lot of you know I designed the Lazair ultralight aircraft and now I have come up with a new aircraft design that some of you may be interested in (and I have started a Kickstarter campaign to try to fund it).
I hope you'll at least look at my design and who knows, someday I may visit a contest in a vLazair.
Here is a link for more information:
https://www.kickstarter.com/projects...ertical-takeof
Or just go to Kickstarter and search for vLazair (don't forget the 'v').
Old March 16th 16, 07:04 PM posted to rec.aviation.soaring
Mandatory Flarms? Maybe if folks arent so busy playing with all their cockpit electronics they can keep their eyes outside where they belong. Flarms are not the answer, decent airmanship is. And heaven forbid any more dang things become mandatory. We cant legislate away idiocy.
Craig Funston
Very cool stuff Dale. Looking forward to seeing your progress. I really enjoyed seeing your build blog on the eLazair several years ago. Will you be be blogging this one as well?
Oh, and thanks for the FLARM plug too :-)
Craig Funston
7Q
Old March 16th 16, 07:22 PM posted to rec.aviation.soaring
DaleKramer
Craig,
Thanks, right now I plan to have sort of a log on its Kickstarter page, at least for the 1/4 scale vLazair.
Dale
Old March 16th 16, 07:55 PM posted to rec.aviation.soaring
Steve Koerner
On Wednesday, March 16, 2016 at 12:22:12 PM UTC-7, DaleKramer wrote:
Craig,
Dale
Cool concept. There are a couple things I can see to worry about. It would seem like transitioning from horizontal to vertical landing would involve a risk that the pilot not make it all the way down to the parked position before his 3-4 minute battery life expires.
The other thing that looks worrisome is vulnerability to ground wind in the vertical standing position.
Dale will be pleased to know that the upcoming Nephi nationals does require PowerFlarm. Hopefully that trend will continue.
Old March 16th 16, 08:12 PM posted to rec.aviation.soaring
DaleKramer
Hi Steve,
The transitions should be very quick. Thrust to weight will be about 1.3/1 so acceleration into cruise should be very quick. Landing transitions will basically be just a normal final approach to a touchdown spot but with the idea of being 50 ft high (or so) when you get there. This transition will be very easy to verify and demonstrate with the 1/4 scale. Can always add a few more pounds of battery if needed.
I am hoping to design the gear such that a single person can tip it from tail to nosegear if it gets windy for a tiedown.
What will be strange is that the 'ideal' landing direction will be a 90 degree crosswind landing wrt wind efects.
Great comments!
I saw that for Nephi, hope it continues for a while. Can't afford a glider yet.
Thanks,
Dale
Old March 16th 16, 08:58 PM posted to rec.aviation.soaring
Steve Koerner
On Wednesday, March 16, 2016 at 1:12:18 PM UTC-7, DaleKramer wrote:
Hi Steve,
Great comments!
Thanks,
Dale
It will be interesting to see how that vertical landing works out with the model. I can't visualize how a normal approach speed can get you to a vertical position. Without thrust vector control it seems like it would require a high approach speed in order to then pull up to a vertical position and begin backing.
Have you modeled the vertical landing? How high does the aircraft get if things are done correctly? What speed does it back down at? Will the landing be autonomous or pilot controlled?
I can swallow the idea of vertical take-off much more readily than the landing. Maybe I'm just not visualizing the dynamics of the landing problem correctly.
Old March 16th 16, 09:14 PM posted to rec.aviation.soaring
Andrzej Kobus
Dale, good to hear there is still hope we will see you back in contest flying
Andrzej
Old March 16th 16, 09:58 PM posted to rec.aviation.soaring
Steve Koerner
Thinking about that some more, you don't necessarily have to approach at a higher speed and pull up. With enough thrust you can power your way through deep stall. Yet I still think it questionable that you can have enough battery life to assuredly get landed before it all comes to an end. I hope it works.
Old March 17th 16, 02:33 AM posted to rec.aviation.soaring
DaleKramer
Steve,
Sorry, been busy, but yes you got it. With top electrics OFF and bottom electrics ON FULL, and wingtip electrics on 1/2 and Rotax on FULL there is still 1:1 thrust and about 900 ft-lbs of thrust pitch UP moment available (plus aerodynamic pitch up from elevators). It should pitch up to hover relatively easily. There are two throttles for manual flight, one for electric and one for Rotax. Yes there will be a auto transition mode. Electrics don't even come on until slow speed (fixed pitch props). Multirotors come down very quickly and very stable with a good controller, not like the limitations of the 1950's tail sitters (all manual control).
Glad you are thinking about it
Dale
Art Kramer Andrew Chaplin Military Aviation 8 July 12th 04 11:25 PM
Art Kramer, your computer may be infected old hoodoo Military Aviation 6 May 24th 04 12:43 PM
Question for Art Kramer. M. H. Greaves Military Aviation 2 May 10th 04 05:17 PM
More B-26 Nonsense from Art Kramer funkraum Military Aviation 7 January 21st 04 10:53 PM
ATTN: Art Kramer robert arndt Military Aviation 2 July 4th 03 02:33 PM
