HANDHELD RADIO
Old March 16th 16, 08:56 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Default HANDHELD RADIO
A deal is pending on that radio.
Old March 16th 16, 09:51 PM posted to rec.aviation.soaring
Candid Sky Productions
On Monday, March 28, 2005 at 9:44:49 AM UTC-7, wrote:
Tim, it's neither. When someone uses the handheld on the ground when
I'm flying in my glider, the transmission is very weak. So much so
that I have to close all the vents and turn up the volume considerably
to hear what they are saying. The radio operates just fine; it's just
that it doesn't seem to transmit well.
I'm only guessing, but I'd put my money on the antenna as the problem.
You need to turn up the audio (modulation) on the handheld. Its either in the menu or internally on a pod. If you are not electronically inclined have someone else do it. If you were close to me I would offer in person assistance...... If its an antenna issue just try a substitute one from a friend.. Usually BNC antennas although old tech are pretty sturdy as they have been used for many years and can handle lots of abuse. And what you describe is low modulation. If it were a bad antenna you would hear lots of static on the signal. As if the ht was out of range.
Also I had a good laugh at everyone bashing JRC when in fact the company has been a respected brand for many years. As good if not better than Icom or Yaesu. I know this from experience owning a few of the HF (ham radio) transceivers they have made.
Remember you are using Amplitude Modulation for communications its not going to be FM stereo sounds.
Old March 17th 16, 03:16 PM posted to rec.aviation.soaring
Paul Agnew
I reponded to Vaughn's Vertex FS message, but was a tad too slow and someone beat me to it. It turns out he's just down the road from me and I would have treated him to lunch as part of the deal. ;-)
Paul A.
Jupiter, FL
Boosting ICOM IC-A23 Handheld Aviation Radio CHANGE USERNAME TO westes Instrument Flight Rules 23 June 9th 04 12:41 PM
STS Handheld Radio Repair - USA Ray Lovinggood Soaring 3 April 25th 04 01:33 PM
Vertex VXA-150 Pro V handheld radio question Alan Meyer Soaring 2 April 24th 04 01:42 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
