#31
We have JM1's wound at 115 kv (I think that is RMS) but you can have change that on ordering.
#32
"Who knows, having propellers on 3 different horizontal planes during hover and that are so spread out versus their diameter, could reduce the chances of vortex ring state significantly."
Take into account the interaction between the upper propellers/rotors and the lower with wind affecting the downwash angle. To my eye, you could easily end up with blanking of the lower rotors or unpredictable changes in angle of attack with any wind. Good luck. It's fun to solve problems. |
#33
On Thursday, March 17, 2016 at 10:38:42 AM UTC-7, DaleKramer wrote:
Is that Flywheel Energy Storage or Flat Earth Society? ![]() I haven't found the gas motor I want yet for the 15kw output but I have lots of choices in the 8-10kw. Since this is needed much farther down the road, I have not put much detail design into it. I think I can build this for 25-30lbs. The JM1 only weighs 6 lbs. 10kw may be fine for me since who cares much if it takes 22 minutes to charge up during cruise versus 15 minutes. Dale, that would be the electric glider that goes into regeneration mode when you're in thermals. Take that booming 10 knotter and dial in the regen until you can't climb. Hang in there until you've extracted the energy you want so you can skip all those wimpy thermals in between the good ones. We used to call that L/D ;-) Somewhere i came across a very technical paper on this, but haven't checked the numbers. The catch is always in underestimating the losses and overestimating the efficiency. Hybrid glider might end up working, but what a bummer to have a gasoline motor running constantly at low output to charge batteries. |
#34
Regeneration in thermals used to be high on my list of things to try but now I just do not see being able to get much efficiency out of the process. Traction props just aren't very efficient at being a windmill blade.
#35
Paul,
None of the rotors are directly in the propwash cone of the others, so I do not see any direct interaction between them causing a blanketing effect that reduces AOA of other other rotors. Thanks for the comments, all welcome. Dale |
#36
You might be assuming zero wind. Stationary hovering with no wind fits what you've said. However, when you add in wind, the downwash from the upper rotors will not be perfectly vertical and will be influenced by the wind direction and speed. It's easy to envision the downwash moving downward at an angle that would cause it to intersect with one of the lower rotors. Adding or subtracting a few knots or a few degrees could correct or exacerbate the effect. Exactly what wind speed would cause a loss of lower rotor effectiveness would be an interesting vector to work out. Perhaps that would be a design limitation that could be demonstrated and placarded.
I envision it like doing a 360 hovering turn with a good wind in a conventional helicopter. As some point, you hit a spot where the tail rotor loses effectiveness as the wind affects its angle of attack. Mentally flip it 90 degrees and imagine the wind being the downwash from an upper rotor and you'll get what I'm thinking about. Good luck! Paul A. |
#37
If you used tilting ducted fans, instead of a tilting seat, it would not be as innovative. The ducts would also add drag in horizontal flight compared to folding props. But, if I understand correctly, ducted fans are much less prone to the vortex ring problem.
#38
I've spent a lot of time today reading up on VRS and AsymVR in the case of the V-22. What I can conclude so far is that my my vLazair design departs radically from any VRS states that have been analyzed for both helicopters and VTOLS.
So that leaves extensive testing of the 1/4 scale model of the vLazair as my best course of action (good thing that is what I had planned ![]() Thanks again, Dale |
#39
On Thursday, March 17, 2016 at 6:31:51 PM UTC-4, bumper wrote:
If you used tilting ducted fans, instead of a tilting seat, it would not be as innovative. The ducts would also add drag in horizontal flight compared to folding props. But, if I understand correctly, ducted fans are much less prone to the vortex ring problem. For this transitional design I think ducted fans would weigh too much, reduce my top speed too much and cause too many structural problems. Tilting fans is what I am trying to avoid ... synchronization issues, tilt mechanism weights, complexity ... I am trying to have a design that people can relate to as 'somewhat' of a conventional airplane shape during cruise. |
#40
On Thursday, March 17, 2016 at 4:19:30 PM UTC-7, DaleKramer wrote:
On Thursday, March 17, 2016 at 6:31:51 PM UTC-4, bumper wrote: If you used tilting ducted fans, instead of a tilting seat, it would not be as innovative. The ducts would also add drag in horizontal flight compared to folding props. But, if I understand correctly, ducted fans are much less prone to the vortex ring problem. For this transitional design I think ducted fans would weigh too much, reduce my top speed too much and cause too many structural problems. Tilting fans is what I am trying to avoid ... synchronization issues, tilt mechanism weights, complexity ... I am trying to have a design that people can relate to as 'somewhat' of a conventional airplane shape during cruise. Your "design" looks to have a very high disk loading. What CAD analysis (if any) have you done of this design, and what CAD tools did you use? Tom |
Andrew Chaplin | Military Aviation | 8 | July 12th 04 11:25 PM | |
Art Kramer, your computer may be infected | old hoodoo | Military Aviation | 6 | May 24th 04 12:43 PM |
Question for Art Kramer. | M. H. Greaves | Military Aviation | 2 | May 10th 04 05:17 PM |
More B-26 Nonsense from Art Kramer | funkraum | Military Aviation | 7 | January 21st 04 10:53 PM |
ATTN: Art Kramer | robert arndt | Military Aviation | 2 | July 4th 03 02:33 PM |
