#11
![]() I'll check the antenna connection before powering on next time, and hope that you are correct and this was a on-off error. I mean a 'one off' error ! |
![]() Hi Darryl, Have a look in the IGC file for the Geodetic datum in use (HFDTM record). If this is not 100, WGS84 then the battery in the GPS25 engine is suspect (maybe it's suspect anyway). This battery recharges in use, but if it goes flat, the RTC stops := This is not the same battery as that which maintains the volatile RAM. Tim. Hi Tim, from the igc file; that field appears to be blank: HFGIDGLIDERID:VH GAH HFDTM100GPSDATUM: HFRFWFIRMWAREVERSION:F2.6 Regards, Bernie. |
![]() Hi Tim, from the igc file; that field appears to be blank: HFGIDGLIDERID:VH GAH HFDTM100GPSDATUM: HFRFWFIRMWAREVERSION:F2.6 Regards, Bernie. Just checked some much older files (2008, 209) and the field is also blank, and the logger was working fine then! |
On Oct 27, 9:46*pm, Bernie wrote:
Hi Tim, from the igc file; that field appears to be blank: HFGIDGLIDERID:VH GAH HFDTM100GPSDATUM: HFRFWFIRMWAREVERSION:F2.6 Regards, Bernie. Just checked some much older files (2008, 209) and the field is also blank, and the logger was working fine then! And looked at a file from a completely different 302 in another aircraft, it also has: HFDTM100GPSDATUM: |
Thanks Darryl (and Tim, and Tim).
We'll see how it goes next flight. Regards, Bernie. |
On Oct 28, 6:54*am, Bernie wrote:
Thanks Darryl (and Tim, and Tim). We'll see how it goes next flight. Regards, Bernie. Everything was A-OK today....... thanks guys. |
Dear All
The CLEAR LOG command in See You Moile works very easily so I wonder can SEE You mobile also e used to set the date and time in the Camridge 302 at the start of a days flying? Anyone know what the command is and correct syntax for the date and time? See You mobile retains the command in a drop down menu so it would e easy to do each day Thanks for your help Martin |
Google on the 302 Data Port User's Guide. I don't see any way to set a date shown in that manual. It does mention another document called the Secure BIOS User's Guide that may include such details but I've never been able to find a copy of that document anywhere.
RS On Tuesday, May 3, 2016 at 2:46:06 AM UTC-5, wrote: Dear All The CLEAR LOG command in See You Moile works very easily so I wonder can SEE You mobile also e used to set the date and time in the Camridge 302 at the start of a days flying? Anyone know what the command is and correct syntax for the date and time? See You mobile retains the command in a drop down menu so it would e easy to do each day Thanks for your help Martin |
The fix is a new GPS card, as discussed in other threads.
http://www.clearnav.net/main/cn-service.html best, Evan Ludeman for CNi |
FSDO enforcement- GPS before effective date - which date to put in Aircraft Log for Part 43? | Ron A. | Instrument Flight Rules | 18 | March 15th 06 02:30 PM |
First Date | Jay Honeck | Piloting | 35 | September 14th 05 04:42 AM |
FS2004 date FWI | Brian Summers | Simulators | 0 | August 10th 03 04:24 AM |
GPS 90b out of date? | Roger Long | Piloting | 2 | August 8th 03 03:58 PM |
Need a date.... | Sagz525 | Instrument Flight Rules | 2 | July 23rd 03 02:34 PM |
