CAI 302 date problem
Old October 27th 10, 09:53 AM posted to rec.aviation.soaring
Bernie[_4_]
Default CAI 302 date problem
I'll check the antenna connection before powering on next time, and
hope that you are correct and this was a on-off error.
I mean a 'one off' error !
Old October 27th 10, 11:41 AM posted to rec.aviation.soaring
Bernie[_4_]
Hi Darryl,
Have a look in the IGC file for the Geodetic datum in use (HFDTM
record). If this is not 100, WGS84 then the battery in the GPS25 engine
is suspect (maybe it's suspect anyway). This battery recharges in use,
but if it goes flat, the RTC stops :=
This is not the same battery as that which maintains the volatile RAM.
Tim.
Hi Tim,
from the igc file; that field appears to be blank:
HFGIDGLIDERID:VH GAH
HFDTM100GPSDATUM:
HFRFWFIRMWAREVERSION:F2.6
Regards, Bernie.
Old October 27th 10, 11:46 AM posted to rec.aviation.soaring
Bernie[_4_]
Hi Tim,
HFDTM100GPSDATUM:
Regards, Bernie.
Just checked some much older files (2008, 209) and the field is also
blank, and the logger was working fine then!
Old October 27th 10, 11:51 AM posted to rec.aviation.soaring
Bernie[_4_]
On Oct 27, 9:46*pm, Bernie wrote:
Hi Tim,
HFDTM100GPSDATUM:
Regards, Bernie.
And looked at a file from a completely different 302 in another
aircraft, it also has:
HFDTM100GPSDATUM:
Old October 27th 10, 08:54 PM posted to rec.aviation.soaring
Bernie[_4_]
Thanks Darryl (and Tim, and Tim).
We'll see how it goes next flight.
Regards, Bernie.
Old October 30th 10, 09:45 AM posted to rec.aviation.soaring
Bernie[_4_]
Regards, Bernie.
Everything was A-OK today....... thanks guys.
Old May 3rd 16, 08:46 AM posted to rec.aviation.soaring
Dear All
The CLEAR LOG command in See You Moile works very easily so I wonder can SEE You mobile also e used to set the date and time in the Camridge 302 at the start of a days flying? Anyone know what the command is and correct syntax for the date and time?
See You mobile retains the command in a drop down menu so it would e easy to do each day
Thanks for your help
Martin
Old May 3rd 16, 02:07 PM posted to rec.aviation.soaring
Google on the 302 Data Port User's Guide. I don't see any way to set a date shown in that manual. It does mention another document called the Secure BIOS User's Guide that may include such details but I've never been able to find a copy of that document anywhere.
RS
On Tuesday, May 3, 2016 at 2:46:06 AM UTC-5, wrote:
Dear All
Martin
Old May 3rd 16, 03:04 PM posted to rec.aviation.soaring
Tango Eight
The fix is a new GPS card, as discussed in other threads.
http://www.clearnav.net/main/cn-service.html
best,
Evan Ludeman for CNi
FSDO enforcement- GPS before effective date - which date to put in Aircraft Log for Part 43? Ron A. Instrument Flight Rules 18 March 15th 06 02:30 PM
First Date Jay Honeck Piloting 35 September 14th 05 04:42 AM
FS2004 date FWI Brian Summers Simulators 0 August 10th 03 04:24 AM
GPS 90b out of date? Roger Long Piloting 2 August 8th 03 03:58 PM
Need a date.... Sagz525 Instrument Flight Rules 2 July 23rd 03 02:34 PM
