cold weather flying
Old May 3rd 16, 03:42 PM posted to rec.aviation.soaring
Tango Whisky
Default cold weather flying
I've got myself SkyBoots
http://www.streckenflug.at/shop/prod...oducts_id=1661
which you put over your normal shoes just before take-off (you can walk around a little bit; they have a small reinforcement on the underside).
I actually don't remember anymore what cold feet feel like ;-)
Bert
Ventus cM "TW"
Old May 3rd 16, 09:15 PM posted to rec.aviation.soaring
Stu
On Monday, May 2, 2016 at 1:32:50 PM UTC-6, ND wrote:
Hi all,
My thread is either 8 months too late, or three months too early depending on how you look at it.
I'm looking for opinions on gear for cold weather flying, and high altitude flying, particularly as it relates to footwear. I'm trying to find a pair of boots which are warm and insulated, but also relatively low profile because i'm looking for rudder clearance. does anyone know of a good brand or specific boot?
thanks dudes.
-Andy
Check out Thermacell heated insoles. You can get them at Cabela's. They have a remote control and I have never had them overheat. Several years ago, I also use Hotonics and at the #3 setting they never overheated my feet, however I did not like the batteries hanging form my boots.
Stu 2Z
Old May 3rd 16, 10:06 PM posted to rec.aviation.soaring
RomeoRomeo
On Monday, May 2, 2016 at 3:32:50 PM UTC-4, ND wrote:
Hi all,
thanks dudes.
-Andy
Here is my preference:
https://nunatakusa.com/down-booties/...i-mukluks.html
Knee High down booties. When it is 40 below, everything from my knees down gets cold (out of the sun), so these are great. NG for bailing out, but are so breathable I can wear them in all but the warmest weather. I am tall, and the relitively thin soles "make me shorter"...
RR
Old May 4th 16, 02:34 AM posted to rec.aviation.soaring
Dan Marotta
Dan, getting out and getting the chute opened are independent of
footwear. ND is pretty flat and well plowed, but you wouldn't want to
walk on the NM canyons and desert in anything flimsy. Then consider how
far you may have to walk in those booties, assuming you haven't broken
an ankle on landing.
Dan
On 5/2/2016 6:29 PM, wrote:
Dan as for a parachute landing the footware is probably the least of your concerns a good ways behind getting out eithout being struck and getting that chute opened. LOL
Dan, 5J
Old May 4th 16, 02:39 AM posted to rec.aviation.soaring
Dan Marotta
I wear hiking boots from REI. I also use them on my motorcycle and, oh
yeah, for hiking!
On 5/3/2016 6:53 AM, ND wrote:
thanks guys! i actually have a pair of heated insoles, they work very well in insulated footwear, but they aren't much good in a pair of sneakers, so i wanted to find a pair of good boots to put them into. i think i'll take a serious look at the motorcycle boots, and ski boot liners. ski boots are supposed to be stiff, but i don't know if the liners are restrictive.
Hi all,
thanks dudes.
-Andy
Dan, 5J
Old May 4th 16, 03:14 AM posted to rec.aviation.soaring
Do your hiking boots have lace hooks? If so, they are not safe for going parachuting.
Old May 4th 16, 01:58 PM posted to rec.aviation.soaring
ND
do these have some kind of sole? do you wear them over your shoes? i like this option, but i want to understand what kind of sole or insole it already might have, since i'd like to incorporate my heated insoles if possible.
Hi all,
thanks dudes.
-Andy
RR
Old May 4th 16, 02:06 PM posted to rec.aviation.soaring
ND are in north dakota? I fly up in the Minot area. We are getting set up to start a club up here.
Dan
Old May 4th 16, 02:51 PM posted to rec.aviation.soaring
Yes Dan I understand the aspects of the hike out. Most of my xc flying was out of minden and Ive had my share of hikes. As for getting out of the ship, boots may be important for another reason. My bro once had to bail out of a ventus after a midair. After a guy hit him my bro found himself in a high G loop (guy clipped my bros elevator it jammed in full up postion). My bro had to use his legs to kick out the canopy cause it wouldnt eject with the high poss G's. In this case his boots definitely saved his ass.
Old May 4th 16, 03:23 PM posted to rec.aviation.soaring
Dan Marotta
Yeah, I know. When I was jumping, they taped up the hooks with duct
tape. So I switched to sneakers. Note that I use a ram air rectangular
chute with a much lower vertical speed at landing.
Dan, 5J
cold weather flying-1967 C172H Heino Weisberg Owning 1 December 16th 08 04:47 PM
1967 H C172 cold weather flying Heino Weisberg Owning 0 December 16th 08 12:49 PM
Warm Weather Pilots, Cold Weather Ops john smith Piloting 3 December 2nd 04 04:00 PM
Cold Weather Winter Flying Q's NW_PILOT Piloting 20 November 9th 04 03:32 AM
Cold Weather Flying Jose Vivanco Owning 27 October 16th 03 11:27 AM
