Maximum Speed of Airliner At Low Altitude
Old June 13th 04, 11:59 PM
Roger Helbig
Default Maximum Speed of Airliner At Low Altitude
Airline or Military transport pilots .. I would like to ask you some =
questions about the maximum speed that an airliner like a B-767 or 757 =
can travel at low altitude. Someone claims that the speed at altitude =
is much higher than that at low altitude because the drag of the wide =
body limits the maximum speed at low altitude. Can any of you comment =
on that?
Thank you.
Roger Helbig
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old June 14th 04, 04:08 AM
Mortimer Schnerd, RN
Ian MacLure wrote:
Operationally its irrlevant because the FAA limits speed below 10K
ft to 250Kts IIRC.
As to the actual max speed attainable at low altitude, I believe you
have it correct.
Agreed. Thicker air equals lower speed. FAA equals even lower speed.
http://www.mortimerschnerd.com
Old June 14th 04, 04:42 AM
Andy Bush
Each aircraft may well have a different low altitude max speed...this will
be given in knots of Indicated Airspeed (IAS)...and typically is about
350-400 knots for passenger aircraft. At low altitude, IAS and True Airspeed
(TAS) are pretty much the same. While the low altitude max speed is
expressed in knots IAS, the high altitude max speed is expressed as a Mach
number. Passenger jet max mach numbers vary from around .8M to close to .9M.
At high altitude, IAS and TAS often are quite different, with TAS being the
larger value.
The low altitude max speed limitation is an airframe limit and not a drag
limit. In most cases, the jet could go faster but for various aerodynamic
reasons, is restricted from doing so.
"Roger Helbig" wrote in message
news:40ccdcd9@hughey...
questions about the maximum speed that an airliner like a B-767 or 757 can
travel at low altitude. Someone claims that the speed at altitude is much
higher than that at low altitude because the drag of the wide body limits
the maximum speed at low altitude. Can any of you comment on that?
Thank you.
Roger Helbig
-----=osted via Newsfeeds.Com, Uncensored Usenet News =---
-----= Over 100,000 Newsgroups - 19 Different Servers! =---
Old June 14th 04, 05:27 AM
Robey Price
After an exhausting session with Victoria's Secret Police, "Roger
Helbig" confessed the following:
some questions about the maximum speed that an airliner
like a B-767 or 757 can travel at low altitude.
Since I have a checkride coming up...Vmo is 340 KIAS for the 757 I
fly. "Clackers" start going off if you hit 340...ahem, I have seen
this in an Idle thrust descent.
The 757 is a very "clean" airframe. It does not like to slow down. If
a pilot turned the autothrottles off and simply firewalled the
throttles it would haul ass in the traffic pattern. How fast? Not
supersonic, but it requires surprisingly low thrust to hold the FAA
250 KIAS limit beow 10k'. I should have taken notes today (TIC).
Ramp down from altitude, it would probably scare the islamist ****
terrorist with all the warning noise from an overspeed (340+ KIAS). I
mean scare in terms of, "holy allah will this infidel made machine
hold together?"
Robey
Old June 14th 04, 10:20 AM
Cub Driver
I believe the max for any aircraft is 250 knots.
The restriction is lifted in certain cases, for example: military jets
doing a Missing Man at Arlington National Cemetery.
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
The Piper Cub Forum www.pipercubforum.com
Viva Bush! www.vivabush.org
Old June 14th 04, 11:33 AM
Tamas Feher
below 10K ft to 250Kts IIRC.
And Mohamed Atta conveniently ignored this rule. The 9/11 planes went so
fast and so low that they were expected to fall apart in-flight. Boeing
made them too sturdy, however. I wonder if some legal-savvy widows will
sue Boeing for building too good planes and thus causing 2800+ deaths.
Old June 14th 04, 12:51 PM
Robey Price
After an exhausting session with Victoria's Secret Police, Cub Driver
Mil jets are not limited to 250 KIAS "due to operational need," as in
a routine Dash 1 procedure (eg 350 KIAS up Initial for the RF-101, 300
KIAS for the F-4, F-16, F-15). But in the radar traffic pattern we
held it down to 250 KIAS.
But Roger's question has to do with the physical limitation of the 757
not something written in an FAR.
Robey
Old June 14th 04, 05:55 PM
Peter Stickney
"Mortimer Schnerd, RN" writes:
ft to 250Kts IIRC.
have it correct.
Not necessarily - thicker air also = much more thrust. It's all pretty
much a wash, with a transonic airplane. Usually the TAS in units/time
(mph, kts, km/hr) is higher, but the Mach Number's a bit lower. *The
Speed of Sound is proportional to absolute temperature. It's warmer
near the surface, so there's more mph/Mach Number.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old June 15th 04, 10:25 AM
Cub Driver
Now you've done it!
The Warbird's Forum
Viva Bush! weblog www.vivabush.org
Old June 15th 04, 12:47 PM
John Carrier
Generally not true. Indicated airspeed top end is usually highest at low
altitude, but true airspeed capability will rise with increased altitude.
This all assumes no airframe structural limit, which is frequently below the
aircraft's capabilities in commercial designs.
R / John
"Peter Stickney" wrote in message
ft to 250Kts IIRC.
you
have it correct.
Pete Stickney
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
