Problems with PowerFLARM 6.06.8249 firmware
Old June 19th 16, 02:29 PM posted to rec.aviation.soaring
kirk.stant
Default Problems with PowerFLARM 6.06.8249 firmware
Ever since loading up the new PF software back in April, the two PF users in my club have been seeing greatly reduced performance (detection range dropped from 5- 8 miles down to about 1 mile) and the flarmnet ID feature no longer works (now we both get something like "94C" for the other glider ID instead of the correct contest number). PCAS and ADS-B range also seems reduced. Anyone else seeing this problem?
Almost as if stealth mode has been enabled by default! And yes, I checked and it's NOT enabled.
Plan is to re-download and install the latest .fw and .bfn files, and double check the FLARMCFG settings.
Frustrating, last year our PFs were working great...
Kirk
66
Old June 19th 16, 03:54 PM posted to rec.aviation.soaring
Brian[_1_]
We have also noticed a decrease in range with the update to 6.05.xxxx firmware.
Pretty easy to document with the Flarm Range checker using last years files for comparison.
Yesterday I updated to 6.06 and upgraded my Flarmnet file and lost the Flarmnet feature at least with the other glider I was testing with.
The Flarmnet feature might be the result of updating some for the Flarm information on the other glider. (Mode S ID, did not change)
Going to test today with a glider that their flarm setting has not been changed to see if it is my Flarm or the other Flarm causing the competition # not to show on my butterfly display.
Brian
Old June 19th 16, 04:43 PM posted to rec.aviation.soaring
Ramy[_2_]
I had plenty of flights since I upgraded and did not notice any degradation.. In the contrary I noticed significant improvement in range with couple of friends but this was due to antenna issues they had in the past. Detection range seem to be 2-4 miles, occasionally further. As for contest IDs, indeed some folks no longer showing their contest ID, but most do. Not sure what is causing this.
Ramy
Old June 20th 16, 04:35 AM posted to rec.aviation.soaring
Brian[_1_]
Checked flarmnet feature with another flarm today, it worked just fine. So pretty sure issue was that the 1st glider flarmnet setting had just not updated on the flarmnet website yet.
Brian
Old June 20th 16, 03:57 PM posted to rec.aviation.soaring
Kirk
66
My experience agrees with Kirk's. Substantially reduced range and much more intermittent detection.
This is with exactly the same installation and antennas as last season and is reflected in both my gliders.
We got Stealth without asking for it.
UH
Old June 20th 16, 04:51 PM posted to rec.aviation.soaring
No issue for me still good range, and ID's are working. I had to change my Adsb setting to stop seeing every airliner that was flying at 30k+
Old June 21st 16, 07:10 PM posted to rec.aviation.soaring
kirk.stant
Interesting. So either is works better (Ramy, Cliff) or it is worse (UH, NR, myself). Something is going on, perhaps with the flarmview software?
Did you all use the 6.06.8249 firmware?
Kirk
Old June 22nd 16, 01:41 AM
RickH RickH is offline
Junior Member
First recorded activity by AviationBanter: Feb 2016
Kirk
Just to add to Kirk's description- while ground testing, each of us was seeing the exact same Flarm ID for each other's gliders- how does that happen??
Rick
NR
Old June 22nd 16, 01:43 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Kirk
66
Same flarmcfg.txt file FLARM ID in both would do it; or bad FLARMnet registration.
Old June 22nd 16, 09:08 PM posted to rec.aviation.soaring
Here is my header in PF, it says firmware 6.05 I uploaded back in April I believe, not sure what is different in versions but it works, I would have thought it would quit working by now ifvit was not correct? :
AFLA8MZ
HFDTE190616
HFFXA500
HFPLTPilotincharge:Cliff Hilty
HFCM2Crew2:undefined
HFGTYGliderType:Ventus B
HFGIDGliderID:N60RH
HFDTM100GPSDatum:WGS84
HFCCLCompetitionClass:15 meter
HFCIDCompetitionID:CH
HFRFWFirmwareVersion:6.05
HFRHWHardwareVersion:1.0
HFFTYFRType:PowerFLARM-IGC
HFGPSType:u-blox NEO-6Q
HFPRSPressAltSensor:MEAS MS5607
I023638FXA3940SIU
C190616195247000000000100Empty
LFLA19524707FRW 6.05
LFLA195247 STEALTH OFF
LFLA195247 NOTRACK OFF
LFLA195247ID 1 A7C665
LFLA195247OB
LFLA19524707OBSTEXP
LFLA19524707DEVNO FLAPFC10A-000296
LFLA19524707BUILD 7862
LFLA19524707RANGE 20000
LFLA19524707ACFT 1
LFLA19524707FREQ 101
LFLA19524707CFLAGS 00
LFLA19524707RFTX 1
LFLA19524707MISC 00
LFLA19524707LOGINT 2
LFLA19524707NMEAOUT1 61
LFLA19524707BAUD1 2
LFLA19524707NMEAOUT2 1
LFLA19524707BAUD2 2
LFLA19524707PCASPFLAU1 0
LFLA19524707PCASPFLAU2 0
LFLA19524707XPDR 0
LFLA19524707PCASRANGE 7408
LFLA19524707PCASVRANGE 610
LFLA19524707ADSBRANGE 10000
LFLA19524707ADSBVRANGE 1000
LFLA19524707PCASCALIBRATION 30
LFLA19524707MODESALT 0
LFLA19524707MODEC 1
LFLA19524707PCASBEEP 1
LFLA19524707ADSBWARNINGS 1
LFLA19524707CAL57DBM 443
LFLA19524707CAP OBST;RFB;TIS;IGC;ENL;AZN;DLED;USBH;DP2;XPDR
LFLA19524707LIC AUD:0;ENL:0;AZN:0;IGC:1;RFB:1;TIS:1
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
PowerFlarm Problems Blake Seese 9V Soaring 7 August 14th 14 06:38 PM
PowerFLARM firmware v3.00 released (feature complete) FLARM Soaring 42 July 24th 14 09:24 PM
unusual PowerFlarm problems Mitch Polinsky[_2_] Soaring 4 June 25th 13 06:02 AM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
