Gear up
Old June 22nd 16, 02:05 PM posted to rec.aviation.soaring
Default Gear up
Is it possible to test the gear up alert on a L-NAV while on the ground?
The manual says it needs to think its going 25 KTS and may have a altitude setting as well.
I would like to add a test in my pre flight.
Dennis
Old June 22nd 16, 03:56 PM posted to rec.aviation.soaring
Dan Marotta
Default Gear up
You might try (gently and carefully) pressurizing the pitot tube with a
large syringe, but that would be a big pain to do on every preflight.
You could also test the system off tow or any other time in the flight
by cracking the spoilers with the gear up.
A better solution would be to develop a habit of verifying the gear
handle is in the down and locked position before beginning your base
turn. Relying on electronic warnings can result in repair bills.
Dennis
Dan, 5J
Gear Up, pt 4 - F5.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:51 PM
Gear Up, pt 4 - Crashed He 111 with balloon cable cutting gear - July 1940.jpg (1/1) Mitchell Holman Aviation Photos 0 April 13th 07 01:50 PM
Gear Up, pt 3 - bob 08.jpg (1/1) Mitchell Holman Aviation Photos 0 April 12th 07 12:07 PM
Gear Up, pt 2 - B-26.jpg (1/1) Mitchell Holman Aviation Photos 0 April 11th 07 12:58 PM
Gear Up - A-10.JPG (1/1) Mitchell Holman Aviation Photos 0 April 10th 07 06:33 AM
