Problems with PowerFLARM 6.06.8249 firmware
Old June 22nd 16, 09:11 PM posted to rec.aviation.soaring
Default Problems with PowerFLARM 6.06.8249 firmware
Dan, I think the hex code for the glider given by the FAA is what is used, so yes if your FLARMcfg.txt file was the same you are telling the unit that is the ID to use and both must be the same.
Old June 23rd 16, 03:38 AM posted to rec.aviation.soaring
Ramy[_2_]
Kirk, confirming I have the exact same version as yours.
Ramy
Old June 23rd 16, 04:44 AM posted to rec.aviation.soaring
K m
On Tuesday, June 21, 2016 at 12:10:06 PM UTC-6, kirk.stant wrote:
Interesting. So either is works better (Ramy, Cliff) or it is worse (UH, NR, myself). Something is going on, perhaps with the flarmview software?
Did you all use the 6.06.8249 firmware?
Kirk
I loaded 6.06.8249 firmware the first day of the Nephi Nats and using Flarmveiw with latest version. Flying with 63 other Flarm equipped gliders and no issues so far.
PowerFLARM Portable Firmware Update: 6.02 Paul Remde Soaring 15 April 10th 15 03:13 PM
PowerFlarm Problems Blake Seese 9V Soaring 7 August 14th 14 06:38 PM
PowerFLARM firmware v3.00 released (feature complete) FLARM Soaring 42 July 24th 14 09:24 PM
unusual PowerFlarm problems Mitch Polinsky[_2_] Soaring 4 June 25th 13 06:02 AM
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
