Blanik L23 Pneumatic Strut Part Needed
Old July 2nd 16, 12:00 AM posted to rec.aviation.soaring
Default Blanik L23 Pneumatic Strut Refill Advice Needed
On Monday, August 11, 2014 at 7:29:04 PM UTC-6, Oscar-Hotel-Mike wrote:
We just bought the following item which is similar. but fancier, than the Aircraft Spruce unit mentioned by Bob K.
http://www.skygeek.com/ats-556.html
The saga continues.
- John
John,
Considering a similar solution for our L-23. Did that part work for you?
Old July 2nd 16, 09:14 PM posted to rec.aviation.soaring
Stephen Damon
Frank is correct on the strut being able to make the glider jump like a low rider. Pressure should be between 750 and 950 lbs.
Blanik strut fill tool Bill D Soaring 1 June 7th 13 08:36 PM
Blanik L-23 Needed Roy Bourgeois Soaring 0 July 17th 06 01:22 AM
Blanik L-23 Needed Roy Bourgeois Soaring 0 July 17th 06 12:20 AM
Blanik L-23 Parts Needed Roy Bourgeois Soaring 0 July 3rd 05 04:46 AM
Blanik Strut adapter David Walsh Soaring 0 September 12th 04 02:16 AM
