Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turnfrom Base to Final' mutually exclusive?
Old July 29th 16, 01:26 AM posted to rec.aviation.soaring
son_of_flubber
Default Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin onTurn from Base to Final' mutually exclusive?
On Thursday, July 28, 2016 at 5:36:38 PM UTC-4, waremark wrote:
We divide the downwind to base turn into two approximately 45 degrees turns, to insert a 'diagonal leg'. After passing low key, instead of continuing a long way downwind to make a rectangular circuit, we turn 45 degrees onto a diagonal, and later make another 45 degree turn onto a shorter base.
And then you make a 90 degree turn from base to final?
Old July 29th 16, 08:26 AM posted to rec.aviation.soaring
Paul Rice
Default Are 'Single 180 Turn From Downwind to Final' and 'Stall-spin on Turn from Base to Final' mutuall
tur=
continuin=
ont=
base.=20
Yup
Old July 29th 16, 03:33 PM posted to rec.aviation.soaring
The majority of gliders are more stall and spin resistant at medium to steeper banks than at shallower bank angles. (This is aerodynamically different than most airplanes). A continuous 30 degree bank from downwind to final exposes a pilot to a longer period of stall/spin-at-low-altitude risk than two brief periods of stall/spin resistant steeper banked turns. (Or 3 turns in the clipped base pattern).
Turning flight presents a more dynamic visual picture then straight flight. Most normally equipped humans are better at assessing and reacting to the changing energy state of the glider (relative to landing area & speed) as well as detecting conflicting traffic and other hazards during wings level straight flight than during turning flight. This may be due to the less dynamic visual presentation in straight flight. This is especially true while under stress.
While it is true that many of you normally performing well trained pilots can safely fly all kinds of approaches, common sense suggests training and establishing flying habits that are more likely to result in safe outcomes when normal conditions and normal performance deteriorates.
The fact that we are still debating these things in 2016 makes me want to beat my head against the canopy.
Old July 29th 16, 03:49 PM posted to rec.aviation.soaring
Tango Whisky
Le vendredi 29 juillet 2016 16:33:21 UTC+2, a écritÂ*:
I'm sure you can elaborate on this...
Old July 29th 16, 03:52 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Some of the reasons for standard patterns rather than 180:
- it's what other traffic at airports expects. It's what most instructors checking you out on their planes, airports, BFRs, or FAA examiners expect.
- it gives you good time to look from base to see if there is other traffic on final
- many stall spin accidents come from overshooting base to final, then ham-handed corrections. That's more likely from a 180
- many off field accidents come from being too close to the field. planning a 180 puts you close automatically
- less adjustment room if things go wrong.
- A test: try doing your no-spoiler approach that way.
John Cochrane BB
Old July 29th 16, 04:57 PM posted to rec.aviation.soaring
John Wells
Another advantage of a standard-ish circuit, is that the focus is on preparing for the final turn -- you aim to have your final turn completed at a safe height (and speed) in a reasonable place.
There's no reason you can't do this in a 180 deg turn too, but my guess it that it somewhat reduces this focus if it's not trained well. It could potentially have you focusing on your reference point too early, flying more cramped-in circuits as a result?
Old July 29th 16, 05:49 PM posted to rec.aviation.soaring
Dan Marotta
Yesterday, as I held short for takeoff, I watched a Grob overshoot final
out of a "square" pattern. It appeared to me that the pilot did not
check, comprehend, or compensate for the crosswind from the right on
downwind (left-hand pattern), and the wind blew him across the final
approach requiring a great steepening of the bank to pull it back around
and then a turn reversal to line up with the final approach. Note that
there was a CFI-G on board and I'll assume that he was letting the
student make the mistake as a training event.
My opinion on the turning approach is that it gives me continuous
feedback as to my ground track and allows me to continually correct for
the effects of cross winds. Of course I listen to AWOS entering the
pattern and set up a crab on downwind for the expected drift, and
correct that as required. I also watch the final approach course on
downwind and during my turn to final.
This is not rocket science, it's being aware of your situation and
surroundings, a condition less and less apparent these days. And
frankly, it's a lot easier, for me at least, to note and correct for
wind drift during a turn than to notice any effect of a tail wind while
flying a square base leg and then overshooting during the turn to final.
John Cochrane BB
Dan, 5J
Old July 29th 16, 06:22 PM posted to rec.aviation.soaring
Paul Agnew
For students in any type - SEL, Rotorcraft, Glider - having a final approach "box" to hit gives clearer feedback on the approach than a slick turning arrival. At the expert level, I can accept that the continuous turn is more fun, but for low-time pilots it really helps them check their progress if they know they should be close to a specified altitude at a specified distance from the landing zone. Of course, there are adjustments for winds, but being able to instantly evaluate whether you're higher or lower than target helps you make immediate corrections. TLAR works better for experienced pilots.
I remember going up with a friend who was a newly certified Private-SEL. His approaches and landings were all over the place until I showed him how to crosscheck himself by looking for 500' at 1/2 mile on final. With that in mind, he was able to mentally project his progress better and make quicker adjustments.
Paul A.
Jupiter, FL
Old July 29th 16, 06:53 PM posted to rec.aviation.soaring
Bob Whelan[_3_]
while under stress.
Hey Matt, howzis for a data point? The 2nd-most-stressful landing approach I
ever made (microburst [just like #1 & #3] - not recommended for the
faint-hearted!) was done in the Zuni to a (shortish, with drop-off to an
arroyo at the threshold) prairie runway on which I'd never before landed (Owl
Canyon's SE one), from a close-in circling approach, with zero flaps until
v-e-r-y short final, begun from overhead the field at ~3,000' agl and
completed with (essentially) only a 270-degree turn from crosswind to final.
Gives me the mild shakes just recalling it!
Judging the "lower altitude bits" angle of bank was trivially easy compared to
deciding when to steepen the "downwind" portion of the turn into the "downwind
to final" portion. Why? The breathtaking descent rate (estimated later at
~3,000 fpm) "visually overwhelmed" the normally-to-be-expected sight picture
for "normal conditions." How bad was it? It nearly gave me heart failure, when
- for a brief, "I didn't, did I?!?" moment on downwind - the *vertical* ground
rush (contrasted with the downwind's seemingly-absent, more expected,
*horizontal* rush/related rapid progress over the ground) made it seem as if
I'd turned the wrong way onto downwind. I knew I hadn't, but it alarmed me so
much I "wasted" a few moments looking back over my left shoulder just to see
if there was still dust blowing from the SE immediately off the east end of
the target runway. (If I'd turned upwind rather than downwind, a serious
accident would likely have been in my immediate future.) The microburst
downwind sight picture and "over the ground feel" was more akin to what you'd
expect from turning downwind the wrong way on a "normally breezy day...i.e.
agonizingly slow progress over the ground in conjunction with a dismal
L/D....sort of like flying through molasses in terms of "expected downwind
progress." Despite trying to make a conservatively judged approach - e.g. not
planning a base much beyond the approach threshold, etc. - for a while it was
looking as if base would be made entirely within the shortish (2,000'?) runway
length...and crosswind had been at midfield!
As it was, I straightened up on final *maybe* 300' beyond the lip of the
dropoff (quite possibly less...no one on the ground saw the approach to share
their estimates), but I was too focused on judging final approach to give that
estimate much attention. Thermalling-flaps-only until past the threshold lip,
and still several hundred feet aloft; down and stopped well before midfield
after not using the wheel brake (trying to minimize the walking retrieve -
stress removed, we humans revert quickly to "energy saving mode," ha ha!).
I'd reckon prolly 95-98% of my attention throughout the approach was devoted
to "getting the approach path correct" with the remainder being "the usual"
airspeed/coordination cross-checks. There was very little "waiting for the
situation to develop" aspect to this approach, as is typically the case in
more routine patterns. Thanks to the sink rate, things developed "all too
quickly!" as in from 3,000'agl atop midfield. followed by two quick,
thermalling-flaps-only, 360s and on the ground. The first 360 was to clear the
pattern, positively locate a 1-36 I'd figured would opt to land before I did
(he turned out to be clueless, afterward, but got away with it just fine!),
and indubitably verify ground winds (as in "Where in heck is the center of the
downburst?), the second one was the pattern itself.
I don't remember my target pattern airspeed, but it likely wasn't all that
much higher than normal, because throughout, the air - other than being
abbie-normally descendant - was astoundingly smooth, so the primary airspeed
tasks seemed likely to be "only" retaining sufficient energy to deal with
low-level shear while not "overdoing" things. Control wasn't an issue (not the
case with #1 alluded to earlier, and to a lesser extent, #3).
I agree with your general sentiment, but would add that "actual reality" is
the ultimate arbiter of "what must be done" in every landing pattern. Under
the above conditions, I doubt I could have pulled off "a full rectangular
pattern" that wouldn't have terrified me even more than the one performed, due
to the (almost certainly likely) need to turn final well within the runway
western/downwind boundary, and (at some point) to be facing a rapidly
decreasing headwind...my overshoot concerns weren't far behind my undershoot
concerns. As with undershooting, the overshooting options on that runway are
nonexistent, short of barbed-wire fence/railway
embankment/fence-in-borrow-trench/interstate highway/fence/etc., or, (major
yikes) trying to convert to a howling crosswind landing to the south on open
prairie. I dunno if the preceding explanation makes sense, but under the
circumstances and at the time, an "analog" circling pattern seemed more
amenable to fine-tuned approach adjustments than did a "digital" rectangular
pattern, while also likely maximizing runway ahead without wasting runway behind.
I didn't "originally plan on" a circling pattern, it simply seemed the best
and most natural of the available options...and worked superbly.
Aw, c'mon - please don't. The latest scientific evidence suggests doing so can
be harmful to canopies: plastic and cranial (and, the latter's contents)! A
baseline landing pattern standard is a great thing for many reasons...but I
see no fundamental harm in assessing why (and why not) it may not be the cat's
meow for *all* circumstances. You DO want your students to retain, and further
develop, their critical thinking skills, right?
Bob W.
Old July 29th 16, 08:10 PM posted to rec.aviation.soaring
kirk.stant
my $.02:
First, the beauty of the 360 "Overhead" pattern is that it makes it really easy to fly exactly the same pattern at ANY airfield. As long as you come up initial at the same speed, and pitch out at the same bank angle, you will end up at the same place on downwind (adjusted for x-wind, of course). The, you just configure, motor to the perch, and roll into your easy 180 turn to line up on final. Done well, it's one of the most satisfying maneuvers in aviation.
And it has the advantage of being a really quick way to enter the pattern, slow down, and land - useful for towplanes.
BUT - it's meant for relatively fast movers with bigger turn radius's; works fine in a Pawnee at 120 mph, no so good in a J-3 at 65 mph, and not at all in most gliders (yes I've tried).
So, for gliders, all that is really useable is the second half - the continuous 180 degree turn to final. As others mention, that is not what is normally taught, and has some limitations that need to be taken into consideration; the main one is that it has to be done from a low downwind, and it happens fast.
And that is why I think it is actually a useful skill to practice: If you end up low and tight, you should be able to fly a safe 180 (or 270, or 90) pattern and land out of it - because you don't have the option of going around!
Just realize that most other traffic will not be expecting it and fly accordingly.
In regards to you question about the military's track record - I don't have numbers but would bet an expensive bottle of whiskey that it's a LOT better than that of GA - after all a military pilot is better trained, flies more often, gets lots of check rides, etc. That being said, modern military jets are more susceptible to high-sink rate problems in the pattern that stall/spins; look up almost any T-38 accident and getting low and slow on final will pop up often. For a supersonic jet, it is really a dog when slow!
Kirk
66
Downwind to final turns Jonathan St. Cloud Soaring 18 June 7th 15 02:19 PM
Base to Final - Fatal Orval Fairbairn[_2_] Piloting 0 August 8th 10 03:23 AM
The Art of Racing - Final Turn.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 27th 10 12:42 PM
Final Approach, pt 3 - KFME final.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 0 April 8th 09 12:56 PM
Turn to Final - Keeping Ball Centered skym Piloting 224 March 17th 08 03:46 AM
