#51
On Monday, August 1, 2016 at 1:04:40 PM UTC-4, Dan Marotta wrote:
Hi Evan, Of course you think there's a right answer because you're a proponent of the square pattern which, if you've read my posts, I'm not at all against.Â* I just prefer to fly the pattern which works best for me and to date, nobody has complained about. That said, I start monitoring the local field from about 20 miles out and am aware of the traffic situation so I plan ahead and don't get into the situation of being #3 but should it still happen: 1.Â* I can reduce my speed considerably and pull up to give time to others. 2.Â* Take a thermal and climb 3.Â* Land on the parallel taxiway 4.Â* Land on the cross wind runway 5.Â* Land opposite direction (we have a long runway) 6.Â* Land way long 7.Â* Make a close in pattern in front of the 1-34 who's probably at twice my distance from the runway.Â* I'll be clear at the taxiway likely before he turns final. I'm sure I can think of more ways to mitigate the situation but I don't feel constrained to drive an aircraft as though it were a train stuck on the tracks.Â* That's the main problem I see with "by the book" flying.Â* I'm not an outlaw and don't mean to come across that way, but I have to sniff when I'm told that there's only one right way to do something.Â* One of my EE professors back in the early 70s (an old German) used to sniff at what he called "cooking book engineers".Â* I took that to heart and try to do what I think is best for a given situation and what works best for me.Â* I understand that, as a CFI you're pretty much constrained to teach by the book, but let me ask you this:Â* Is there anything in the FAA's Glider Flying Handbook that you know to be wrong?Â* Do you teach it wrong if it's so published or do you teach it right? I do what needs to be done and yes, I could fly a square pattern in the situation you described.Â* And another question:Â* Have you ever seen someone really get into trouble because the pilot in front of him in the pattern flew way too far out before turning base and #2 felt that he had to fly even further to maintain spacing?Â* I have. Now please tell me your correct answer.Â* I'm genuinely interested and I've enjoyed this discussion and hope that others less experienced might undertake to learn to think outside the box. Regards, Dan On 8/1/2016 5:59 AM, Tango Eight wrote: On Sunday, July 31, 2016 at 10:32:02 PM UTC-4, Dan Marotta wrote: Fly what works for you and don't disparage techniques that are out of your sphere of experience. ...pop quiz then. You're #3 in the pattern behind a student in a 1-34 flying a standard glider pattern and a tow plane. Behind you is another student + CFI in an L-23. What kind of pattern are you going to fly, and why? I think there's a right answer to this question. best, Evan -- Dan, 5J As an instructor I spend most of my time trying to get pilots to get in the box and stay there. That box involves the use of a rectangular pattern with adjustments as needed for the situation at hand. Cook book- Yes. That said following a cook book doesn't often lead to disaster. UH |
#52
Hi Evan, Of course you think there's a right answer because you're a proponent of the square pattern which, if you've read my posts, I'm not at all against.Â* I just prefer to fly the pattern which works best for me and to date, nobody has complained about. That said, I start monitoring the local field from about 20 miles out and am aware of the traffic situation so I plan ahead and don't get into the situation of being #3 but should it still happen: 1.Â* I can reduce my speed considerably and pull up to give time to others. 2.Â* Take a thermal and climb 3.Â* Land on the parallel taxiway 4.Â* Land on the cross wind runway 5.Â* Land opposite direction (we have a long runway) 6.Â* Land way long 7.Â* Make a close in pattern in front of the 1-34 who's probably at twice my distance from the runway.Â* I'll be clear at the taxiway likely before he turns final. I'm sure I can think of more ways to mitigate the situation but I don't feel constrained to drive an aircraft as though it were a train stuck on the tracks.Â* That's the main problem I see with "by the book" flying.Â* I'm not an outlaw and don't mean to come across that way, but I have to sniff when I'm told that there's only one right way to do something.Â* One of my EE professors back in the early 70s (an old German) used to sniff at what he called "cooking book engineers".Â* I took that to heart and try to do what I think is best for a given situation and what works best for me.Â* I understand that, as a CFI you're pretty much constrained to teach by the book, but let me ask you this:Â* Is there anything in the FAA's Glider Flying Handbook that you know to be wrong?Â* Do you teach it wrong if it's so published or do you teach it right? I do what needs to be done and yes, I could fly a square pattern in the situation you described.Â* And another question:Â* Have you ever seen someone really get into trouble because the pilot in front of him in the pattern flew way too far out before turning base and #2 felt that he had to fly even further to maintain spacing?Â* I have. Now please tell me your correct answer.Â* I'm genuinely interested and I've enjoyed this discussion and hope that others less experienced might undertake to learn to think outside the box. Regards, Dan Hi Dan, No, it wasn't a trick question (good one, Bob :-)), the answer is "the standard pattern". My $0.02: There's no science, no engineering, no product development going on, just traffic sequencing for landing. The standard pattern makes you predictable, adaptable within wide bounds, visible, unhurried. What's not to like? It's the perfect way to sequence. If you have the pattern to yourself (which is often the case where I mostly fly), then knock yourself out. There's the guy that can precision park the G-103 ride glider every time without using the wheel brake, the 2-33 pilot who likes his no-spoiler, no wheel brake precision landings and the XC hotshots doing their low passes in formation. I love that stuff. But when it's time to share with other traffic, particularly other traffic that includes student pilots, the best practice is a standard pattern. And yes, the glider handbook has some issues. best, Evan |
#53
![]() First off, I DIDN'T disparage anybody, but you certainly are. You have NO IDEA what my "sphere of experience" is, or my experience in general. To me, telling me that the way I fly is not safe is disparaging to me. True, I don't know your experience, so why don't you tell me? I've flown single, twin, and triple engined jets, single and twin recips, and twin turboprop beginning 43 years ago. I've flown gliders for 30 years. I've never damaged an aircraft in all that time including 5 dead stick landings due to engine failures. I've flown 66 different types of aircraft. I think that qualifies me to decide which traffic pattern is best for me and I hope you'll note that I've never told anyone the descending 180 turn to final is best, only best for me. If you've flown more years, hours, or types, I respect that, but I don't think that makes my opinion less valid or yours more. I get stirred up when folks tell me that their way is the safest (or best or only) way. This translates to up to 220 ft/sec (a 180 deg turn takes 10-20 sec and complicates the design point on when to start the turn). If you hit unexpected sinking air during this turn you could be in a real pickle! Maybe I misunderstood you, but didn't you make reference to 220 feet per second or 130 kts ground speed? I'd need a 60 kt tail wind on downwind to achieve that kind of ground speed. If you really had a 60 kt tail wind on down wind and flew a standard pattern, I'll wager you would not have made it back to the runway. When I flew an actual pattern with a wind 45 degrees to my right on downwind and the GPS indicating 32 kts, I crabbed away from the runway and spaced further, too. How much? Enough to fly a parallel ground track. Did I fly past the end of the runway before beginning my 180 deg descending turn to final? Heck no! I started the turn at mid field since that was the location where I wanted to stop to clear the runway. My wife, listening to AWOS, told me afterwards that the wind was gusting to 50 kts! I get a sense from your description that you profess flying a ground track. If I'm wrong in that, I apologize. But in the above described case a standard ground track would have resulted in me bouncing off the side of the bluff upon which the airport is located. Simply stating that "square is safer" is, to be blunt, a crock. I DIDN'T say that your ground speed increases during your downwind turn. The point was you are covering a lot of ground fast and can end up further away from the runway than you expect. Not me. I'm in control of my aircraft and won't ever end up further away than I expect unless there's some reason to widen my pattern. And I never said "downwind turn", what I said was "in turning flight" which is exactly what the descending turn to final is. And I said _you_ could lose sight of the runway if _you_ flew a long downwind. I begin my turn from downwind at or just slightly beyond the threshold. I said "you" could lose sight, not "I" could lose sight. You are trying to convince others of the superiority of your technique and I am offering the opposite side of the discussion. You need to calm down and discuss things rationally. Go back and see what I've said. I'm not trying to convince you or anyone else that my way is better, though that's what the US Air Force taught me and I think they know a bit about flying. I've only argued that all of contentions that my way is unsafe are hogwash. What works for me works for me. Fly any way you want but please quit telling me that what I do is "unsafe". PS - I thought I was being rational but apparently not, in your opinion. On 8/1/2016 1:42 PM, 2G wrote: First off, I DIDN'T disparage anybody, but you certainly are. You have NO IDEA what my "sphere of experience" is, or my experience in general. My original contention stands: a square pattern is far safer than a button hook pattern. I DIDN'T say that your ground speed increases during your downwind turn. The point was you are covering a lot of ground fast and can end up further away from the runway than you expect. You agreed that you CAN lose sight of the runway; not losing sight requires a tight "carrier landing" turn which precludes a stabilized final. This is okay if the situation dictates, low altitude or an expedited landing for traffic, but is generally less safe than a square pattern. You are trying to convince others of the superiority of your technique and I am offering the opposite side of the discussion. You need to calm down and discuss things rationally. Tom -- Dan, 5J |
#54
Squeaky, you're so much more articulate than I am. Thank you for
telling it the way I tried to! Dan On 8/1/2016 8:12 AM, Squeaky wrote: Well, not that my answer matters much as I'm only a six year glider pilot, but I do come from a USAF background. All else being equal I fly a curved pattern all the way from downwind to final. Flying that pattern does not stop nor preclude cross checks. I do not stare at the land point all the way around. I check the opposite base along my entire downwind leg. I check again throughout my pattern, and I look for straight in traffic prior to passing the 100-110 degree point where it gets under my belly. I also do not stop cross checks into the cockpit to monitor airspeed, altitude and yaw string. That constant cross check and outside look out has been ingrained in me for years. Even on short final I look around, nod to the duty crew, whatever. I have yet to see anything dangerous in this technique. I was taught you fly a pattern to get you to final in the envelop/cone where you still have correction ability on final--i.e. about half speed brakes. I also fly TLAR... My goal in the pattern, is to hit half brakes all the way around the turn, never changing anything to fly a perfect pattern, roll out, no changes until flare, then touchdown at my aim point. I never quite get there, but that perfection goal challenges and pleases me, and I get pretty close some times. I have been able to fly the same pattern with multiple aircraft in the pattern (almost all of whom fly wider than I do). If I can't time my pattern to follow someone ahead and/or with someone behind, and not conflict with either no matter how I fly, I've got no business flying. Heck, I've held on opposite (right) base to let four gliders land who were in the opposite pattern before I curved my way in behind them in the remaining space. That said, I am more than capable of flying square patterns, and I actually hit 45 degree or higher bank angles in my turns when I do. I do this when winds are high as a matter of course--the long, lower bank angle, continuous turn allows the winds to affect me more, and I prefer the hard, shorter turns, and the wind corrections and min drag of the straight legs and fast turns to the longer gentler draggier effects of the continuous turn. Less wind drag, less wind effect with the straighter legs it seems to me (i.e. more efficient approach). My thoughts: my pattern keeps me closer to the field in case of rapid deterioration of flight conditions or glider problems. I find it much easier to visualize the cone and my approach to it as I'm flying it all the way around the pattern. Since I do not have to time the final turn, I have more time to do lookout, cross checks, etc as my flight inputs are relatively minor corrections all the way around. if I need to get down faster, outside rudder works great (practiced it on purpose, but have never required it). It does make other glider pilots, or instructors at strange field checkouts a little nervous when they fly with me however, as they feel tight and find the constant turn weird or different.... But they have always said I've handled it safely and easily and got on final with zero issues. Squeak -- Dan, 5J |
#55
All good points, Evan. And, to be fair, our pattern is rarely clogged
with another aircraft so predictability is rarely an issue. And yes, I can fly a square pattern and do occasionally, and I've made my preference clear but my precision is better with a curved final turn so that's what I use If I have to land out. Fortunately, with the Stemme, that's pretty much a thing of the past. On 8/1/2016 2:02 PM, Tango Eight wrote: Hi Dan, No, it wasn't a trick question (good one, Bob :-)), the answer is "the standard pattern". My $0.02: There's no science, no engineering, no product development going on, just traffic sequencing for landing. The standard pattern makes you predictable, adaptable within wide bounds, visible, unhurried. What's not to like? It's the perfect way to sequence. If you have the pattern to yourself (which is often the case where I mostly fly), then knock yourself out. There's the guy that can precision park the G-103 ride glider every time without using the wheel brake, the 2-33 pilot who likes his no-spoiler, no wheel brake precision landings and the XC hotshots doing their low passes in formation. I love that stuff. But when it's time to share with other traffic, particularly other traffic that includes student pilots, the best practice is a standard pattern. And yes, the glider handbook has some issues. best, Evan -- Dan, 5J |
#56
On Monday, August 1, 2016 at 5:10:18 PM UTC-7, Dan Marotta wrote:
First off, I DIDN'T disparage anybody, but you certainly are. You have NO IDEA what my "sphere of experience" is, or my experience in general. To me, telling me that the way I fly is not safe is disparaging to me.Â* True, I don't know your experience, so why don't you tell me?Â* I've flown single, twin, and triple engined jets, single and twin recips, and twin turboprop beginning 43 years ago.Â* I've flown gliders for 30 years.Â* I've never damaged an aircraft in all that time including 5 dead stick landings due to engine failures.Â* I've flown 66 different types of aircraft.Â* I think that qualifies me to decide which traffic pattern is best for me and I hope you'll note that I've never told anyone the descending 180 turn to final is best, only best for me.Â* If you've flown more years, hours, or types, I respect that, but I don't think that makes my opinion less valid or yours more.Â* I get stirred up when folks tell me that their way is the safest (or best or only) way. This translates to up to 220 ft/sec (a 180 deg turn takes 10-20 sec and complicates the design point on when to start the turn). If you hit unexpected sinking air during this turn you could be in a real pickle! Â* Maybe I misunderstood you, but didn't you make reference to 220 feet per second or 130 kts ground speed?Â* I'd need a 60 kt tail wind on downwind to achieve that kind of ground speed.Â* If you really had a 60 kt tail wind on down wind and flew a standard pattern, I'll wager you would not have made it back to the runway. When I flew an actual pattern with a wind 45 degrees to my right on downwind and the GPS indicating 32 kts, I crabbed away from the runway and spaced further, too.Â* How much?Â* Enough to fly a parallel ground track.Â* Did I fly past the end of the runway before beginning my 180 deg descending turn to final?Â* Heck no!Â* I started the turn at mid field since that was the location where I wanted to stop to clear the runway.Â* My wife, listening to AWOS, told me afterwards that the wind was gusting to 50 kts! I get a sense from your description that you profess flying a ground track.Â* If I'm wrong in that, I apologize.Â* But in the above described case a standard ground track would have resulted in me bouncing off the side of the bluff upon which the airport is located.Â* Simply stating that "square is safer" is, to be blunt, a crock. I DIDN'T say that your ground speed increases during your downwind turn. The point was you are covering a lot of ground fast and can end up further away from the runway than you expect. Not me.Â* I'm in control of my aircraft and won't ever end up further away than I expect unless there's some reason to widen my pattern.Â* And I never said "downwind turn", what I said was "in turning flight" which is exactly what the descending turn to final is. And I said you could lose sight of the runway if you flew a long downwind.Â* I begin my turn from downwind at or just slightly beyond the threshold.Â* I said "you" could lose sight, not "I" could lose sight. You are trying to convince others of the superiority of your technique and I am offering the opposite side of the discussion. You need to calm down and discuss things rationally. Go back and see what I've said.Â* I'm not trying to convince you or anyone else that my way is better, though that's what the US Air Force taught me and I think they know a bit about flying.Â* I've only argued that all of contentions that my way is unsafe are hogwash.Â* What works for me works for me.Â* Fly any way you want but please quit telling me that what I do is "unsafe".Â* PS - I thought I was being rational but apparently not, in your opinion. On 8/1/2016 1:42 PM, 2G wrote: First off, I DIDN'T disparage anybody, but you certainly are. You have NO IDEA what my "sphere of experience" is, or my experience in general. My original contention stands: a square pattern is far safer than a button hook pattern. I DIDN'T say that your ground speed increases during your downwind turn. The point was you are covering a lot of ground fast and can end up further away from the runway than you expect. You agreed that you CAN lose sight of the runway; not losing sight requires a tight "carrier landing" turn which precludes a stabilized final. This is okay if the situation dictates, low altitude or an expedited landing for traffic, but is generally less safe than a square pattern. You are trying to convince others of the superiority of your technique and I am offering the opposite side of the discussion. You need to calm down and discuss things rationally. Tom -- Dan, 5J Hey Dan, you're strung WAY TOO TIGHT! 1. I NEVER said what you are doing IS NOT safe! YOU said that! In fact, I listed three situations where such a pattern would be not just appropriate, but preferred. What I said is that in all other situations a square (rectangular, if you prefer) pattern would be safer. 2. I am NOT going to get into a ****ing contest with you about who has the most experience; leave it be that I have PLENTY of glider experience. You can win that contest with the heavy iron experience, for what that matters. 3. I explained this before, but let's review: a. 80 kt IAS @ 10 kft density altitude = 100 kt TAS b. 100 kt TAS + 10 kt tail wind = 110 kt ground speed c. 100 kt TAS + 30 kt tail wind = 130 kt ground speed 3. I don't see how you can judge wind speed and direction in a descending turn; flying a stabilized base leg gives a far better feel because you can visually see your crab angle. Same thing goes for the final approach. 4. It sounds like, but you never said, you descending turn is quite wide. Perhaps not that dissimilar to a square pattern with the two turns merged into one. 5. It seems like the CFIGs here agree with me. 6. You can fly whatever pattern you feel comfortable with, as far as I am concerned - you ARE NOT my target audience. Tom |
#57
Really, if you look at patterns that people actually fly, there is not so much difference in philosophy as you think. I challenge everybody to download log files from your airport, or contest, plot them, and see what they look like. Some base legs have long straight segments between sharp turns, some are merely connected gentle turns from downwind to final, but we all end up in the same place, on a controlled glide path and airspeed, safely aligned with the runway. The only thing that is confusing to students is authoritarian pronouncements of single and often incorrect ways to fly it. For example, nobody really flies downwind with a 45 degree lookdown angle to the runway, that would put them 800' away at 800 AGL, with no hope of flying a controlled base leg. Even the author of that silly guideline doesn't fly that close, if you look at his igc files at competitions. Most people fly downwind 2000-2500 away from the runway, which is more like a 20 degree lookdown angle. Do the math, look at what you actually fly, look at what other people fly. For example, see http://noss.ws/temp/patterns.jpg for a sampling of patterns a dozen or so experienced pilots flew and logged on OLC in varying conditions at the same location on the same runway.
#58
![]() Quote:
I then check air brakes and leave them out in order to start getting down and aim to hit abeam my touchdown point at a 30 degree look down angle (from texts, 500' alt abeam touch down point, and trig again). That position, rolling off downwind into a 25 degree bank rocks you nicely around to final with a continuous not too hard turn, plenty of correction, easy to see wind effect, roll out 1/4 mile aligned with runway, simple. I'm not sure who came up with the angles, but they either do not understand trig, or did not do the calculations and compared them to suggested altitudes at each point. As mentioned, since I see almost no one else running down downwind at 1000 feet off set from the runway (and usually at 2000') I'm pretty sure no one else is using that 45 degree look down number. |
#59
Sorry I don't know your name, 2G, nor do I know where you fly, and I'm
not trying to get into a ****ing contest. But let me offer you this: Should you ever come to Moriarty or I come to wherever you are, let's fly my Stemme together and demonstrate our patterns to each other. Then we can laugh about it over a beer. Keyboards and time delays do make for too much acrimony! On 8/1/2016 7:07 PM, 2G wrote: 3. I don't see how you can judge wind speed and direction in a descending turn; flying a stabilized base leg gives a far better feel because you can visually see your crab angle. Same thing goes for the final approach. I'll only reply to the above statement hopefully to explain but it's so much easier to demonstrate. You can judge wind velocity during a turn by your drift across the ground at low altitude. Then small corrections can be made to fly the necessary ground track to arrive at the desired location. Check it out next time you're thermalling down low. -- Dan, 5J |
#60
All you expert pilots are I'm sure fully capable of flying in such a manner as to back up your arguments and I'm sure that you are very safe due to your refined skills. But, is your particular point really relevant to the overall safest best practice that the sport as a whole should be teaching and modeling? Are you always in peak form at the end of an epic XC? Are all of your friends in soaring as reliably skilled as you?
I said it before but I'll say it again: The majority of gliders are more stall and spin resistant at medium to steeper banks than at shallower bank angles. (This is aerodynamically different than most airplanes). A continuous 30 degree bank from downwind to final exposes a pilot to a longer period of stall/spin-at-low-altitude risk than two brief periods of stall/spin resistant steeper banked turns. (Or 3 turns in the clipped base pattern). Turning flight presents a more dynamic visual picture then straight flight. Most normally equipped humans are better at assessing and reacting to the changing energy state of the glider (relative to landing area & speed) as well as detecting conflicting traffic and other hazards during wings level straight flight than during turning flight. This may be due to the less dynamic visual presentation in straight flight. This is especially true while under stress. |
Downwind to final turns | Jonathan St. Cloud | Soaring | 18 | June 7th 15 02:19 PM |
Base to Final - Fatal | Orval Fairbairn[_2_] | Piloting | 0 | August 8th 10 03:23 AM |
The Art of Racing - Final Turn.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | February 27th 10 12:42 PM |
Final Approach, pt 3 - KFME final.jpg (1/1) | Mitchell Holman[_3_] | Aviation Photos | 0 | April 8th 09 12:56 PM |
Turn to Final - Keeping Ball Centered | skym | Piloting | 224 | March 17th 08 03:46 AM |
