PowerFlarm Unit Testing - Portable-PF-In-A-Box
Old August 23rd 16, 01:21 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default PowerFlarm Unit Testing - Portable-PF-In-A-Box
FYI...
Britton Bluedorn's Portable PowerFlarm in a box:
https://www.dropbox.com/sh/yjzhe8wgo...jIrESm4Fa?dl=0
was of IMMENSE help and an efficient cost effective way to test the transmit/receive radiation pattern or range of your installed PF Core unit. Fortunately, he is my neighbor and loaned me the unit.
I hope that this will help others out there as well.
Walt Rogersw WX
Old August 23rd 16, 04:06 AM posted to rec.aviation.soaring
greeneggsandjam@yahoo.com
On Monday, August 22, 2016 at 8:21:09 PM UTC-4, WaltWX wrote:
FYI...
Walt Rogersw WX
Very interesting, I think I can guess how you use this, but I'd rather have a description of your test procedure and love to see your data.
BTW on a similar note, flarm.com will give you a range analysis purely in Horizontal 2D. This is probably the most important for anticollision, however I would be curious to also see the vertical range analysis - a side view instead of top view to to see if the pattern is good above and below.
Chris
Old August 23rd 16, 05:10 AM posted to rec.aviation.soaring
brittonbluedorn@gmail.com
FYI, Steve Koerner gets all the credit for thinking of the portable box tester. I just followed through with his recommendations. see link below for history:
https://groups.google.com/d/msg/rec....0/op6SYmVEcmkJ
Old August 23rd 16, 03:32 PM posted to rec.aviation.soaring
Dan Daly[_2_]
FYI...
Walt Rogersw WX
Chris
@Chris - the beam pattern for a half dipole is maximum at 90 degrees and minimum above and below - think of a tire. See the 1/2 wave dipole antenna wiki at https://en.wikipedia.org/wiki/Dipole_antenna . See the radiation pattern demo about halfway down.
This also shows why the antenna should be vertical in the installation; otherwise, you aren't getting the maximum range in the horizontal - where the max warning is most useful...
Old August 23rd 16, 03:58 PM posted to rec.aviation.soaring
Dave Nadler
On Tuesday, August 23, 2016 at 10:33:00 AM UTC-4, Dan Daly wrote:
...the beam pattern for a half dipole is maximum at 90 degrees
Nah, think of a DONUT!
Much better, mmmm...
WTB: PowerFLARM Portable chip.bearden@gmail.com Soaring 9 August 30th 15 03:18 AM
powerflarm portable for sale markmocho53@gmail.com Soaring 0 October 23rd 12 03:32 PM
For Sale PowerFLARM Portable (USA) Andy[_1_] Soaring 0 September 17th 12 12:28 AM
FS - Powerflarm Portable Westbender Soaring 0 January 9th 12 09:21 PM
Portable GPS: receiver and laptop/palm or selft contained unit picopirate Owning 11 May 16th 04 11:37 PM
