Buying a glider, advice on type and prices
Old August 30th 16, 08:53 PM posted to rec.aviation.soaring
Bruce Hoult
Default Buying a glider, advice on type and prices
On Tuesday, August 30, 2016 at 11:53:20 PM UTC+12, Dan Daly wrote:
The site says something like approved life of 3000 hours with extensions so maybe that's the one that's now been upgraded to 12,000 hours. (will check) That's one reason I was looking for a more recent model in case GRP gliders do have problems in later life. Just about anything will outlast me but I'm thinking resale value.
http://szd.com.pl/downloads/4fdeffe8...l-10039816.pdf is the document which extends the life of all SZD-55 to 12k. The associated Flight Manual must be amended with the 2012 changes, which is noted at the end of the EASA document. Mainly they talk about what inspections have to be done periodically, and change the bits of the manual that talk about the authorized lifespan of the glider.
Most gliders get an initial 3,000 hr approval, then as they approach that, they are assessed by the factory to see if they have problems. If not, additional 3,000 hrs. As they approach 6,000, same, etc., until design life is reached. I don't know what the design life of Schempp-Hirth, Schleicher, etc are (I know ASK-21's are at 18,000 hrs). I think of most GRP gliders as having infinite lives, though gelcoat must be refinished periodically.
OK .. *why* must gelcoat be refinished periodically?
I suppose eventually it might start letting moisture through into the structure, but I suspect most people are refinishing it at less than 50% (maybe much less) of its potential protective lifetime for purely aesthetic reasons.
Does cracked gelcoat have much of an effect on aerodynamics? One that someone other than a top competition pilot would notice?
Old August 30th 16, 09:42 PM posted to rec.aviation.soaring
Aerodynamics isn't the issue - gelcoat failure can progress until it's a structural issue.
There are many early Cirrus & Libelle (amongst others) from the early / mid 70s that still flying with original gelcoat without any signs of failure.
Nick.
Old August 30th 16, 09:50 PM posted to rec.aviation.soaring
Dan Daly[_2_]
There are many early Cirrus & Libelle (amongst others) from the early / mid 70s that still flying with original gelcoat without any signs of failure..
Nick.
Different gelcoats than today's, due to environmental concerns for the workers. Agree older gel held up better, unless exposed to a lot of temperature swings (wave flights without temperature stops every 5000'). Newer std class - which is what is being discussed here - have gelcoat issues. PU paint is preferable, in my opinion. I can also think of several original Cirrus which required full refinishes in their lives.
Old August 31st 16, 12:20 AM posted to rec.aviation.soaring
Bob Whelan[_3_]
On 8/30/2016 2:42 PM, It was written:
structural issue.
In the spirit of seeking genuine knowledge - and readily acknowledging
widespread *concern* that cracking/flaking gelcoat can "somehow" morph into a
"premature" structural issue - can anyone cite solid information (data, links,
etc.) shedding light on the mechanism(s?), location and quantity of UV-exposed
plastic sailplanes thrown onto the garbage heap after failing structural
tests, etc.? It's a serious - not rhetorical - query.
There's plenty of engineering data, as well as "common-sense/observational
data", around indicating UV is a catholic attacker/degrader of all manner of
materials, but have sailplane manufacturers, or (say) the LBA, or anyone else,
set about obtaining such data for GRP/CRP sailplanes?
Hard data eagerly welcomed!
Bob W.
Old August 31st 16, 03:11 AM posted to rec.aviation.soaring
Papa3[_2_]
Failed gelcoat absolutely "prints" down into the glass/epoxy substrate. We've just refinished two gliders in our club which were left to go beyond minor crazing to full-on gelcoat failure. Once the gelcoat is totally stripped, you're left with visible lines in the glass/epoxy. Under a 4x loupe you can see that there is an edge to these lines where there are small voids in the epoxy.
Does this materially affect the integrity of the wing/fuselage/control surface structure? That's beyond my pay grade.
Gerhard Weibel's take is as follows (from the Schleicher Technical Note on "paint cracks"):
Owing to the UV-radiation the gel coat of the paint surfaces grows
brittle and shrinks; at the same time the UV-light destroys paint ingredients.
So moisture (rain, dew) working in on long term will wash the
decomposed paint ingredients out off the paint. The paint starts chalking
and gets hairline cracks owing to the concurrence of embrittlement
and shrinkage. Furthermore, these hairline cracks gather dirt
which through its aggressive effect and its stronger heating-up from
sun radiation further precipitates the degradation of the paint. Owing
to this the intended protective effect for the fiber composite structure
against moisture and UV-radiation is no longer granted.
Certainly a good care with hard wax can slow down the above process
distinctly, but it cannot be stopped completely. For this reason a
repainting of the aircraft will always become necessary at some point
of time.
However, we point out explicitly that paint cracks - even deep cracks -
do not represent damages to the aircraft structure if as of their first
appearance immediate correct maintenance and care is given furthermore
to the aircraft.
As all the outside skin of the aircraft is dimensioned for stiffness, there
are no critical mechanical strength problems, even if some cracks
have gone down into the fiber composite structure and have already
attacked the resin matrix base.
The unknown ageing effects caused by the influence of moisture and
UV on the unprotected fiber composite structure are more dangerous.
P3
structural issue.
Bob W.
Old August 31st 16, 08:30 AM posted to rec.aviation.soaring
Ian[_2_]
On 30/08/2016 20:48, John wrote:
Thanks for the nice reply. I'm not wealthy at all, sold my house and
bought a caravan when the ex. left me. I love my caravan, it's in a
fantastic location and then I found a really exciting ridge soaring
site nearby and here I am! May as well spend it whilst I can and have
some fun. Thought a decent glider will be as good as money in the
bank just now. Really appreciate the friendly help from everyone.
Sounds like you intend to fund your post flying career pension by
reselling the ship. Be careful gliders are not always readily saleable.
A popular make of ship that is suitable for low our pilots would be most
easily resold. You may still take a bit of a knock if you have to sell
in a hurry.
Then look for a good trailer. A good finish, preferably already
refinished in PU. Modern radio and vario/computer and good instruments
with appropriate units (ft, m, knots, km/h, m/s etc) for your country.
Also a ship with good factory support.
Remember to budget for insurance costs if you not in a position to
absorb a "self insurance loss" and "maintenance plan" tax if you go for
one of the older LS/DG models.
Maybe a nice LS4? Or LS8, Discus 2 etc.
Ian
Old August 31st 16, 06:54 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Ian
For the record, I am the owner of an "older LS model", and not associated with the company in any way other than owning a plane and having purchased the "Maintenance Plan". The "Maintenance plan tax" is 245 Euro per year. If that is a deal breaker for you, I think you will find some other reason to not buy a sailplane.
Steve Leonard
  #28
Old August 31st 16, 08:32 PM posted to rec.aviation.soaring
Or you could run (not walk) to W&W and buy the Pegase101 that just went up - go to the Pegase Yahoo group and you will find 100 guys who love their Glider (including me) - a great glider to own while you figure out how to spend an additional large chunk of cash.
WH
  #29
Old August 31st 16, 09:29 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Pegase wings aren't that light, but not really a problem. I flew my
club's Pegase 90 a lot and really liked it. It was my first high
performance toy after getting Silver on the club's SZD Juniors.
One point to remember about the Pegase: if you have a choice between a
Pegase 101 and a Pegase 90, go for the 90 assuming that all other things
are similar. 101s all have Hotelier connectors on the ailerons and
airbrakes while the 90s were built later and have automatic connections
on all control surfaces.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #30
Old August 31st 16, 10:18 PM posted to rec.aviation.soaring
Paul T[_4_]
OK think you said your in the Northern UK so my advice with the
money and the experience you have and if your looking to sell the ship
at some point and not lose money is to buy a good LS4a, LS8-18
(probably best option if you have around £40-45k to spend) or Discus.
Make sure they have good gel coats and ancillary equipment.
But best talk to your CFI your skill level and what he might think an
appropriate ship - maybe get some time in a high performance two
seater i.e. Duo Discus/DG1000 first.
In the UK you will find it harder to resell an ASW24, ASW27, ASW28,
SZD55, Pegase, Lak 17 or Ventus A/B/C than the above. ASW20's are
getting long in the tooth.
Ignore Americans who don't read threads entirely - there are lots on
here that will give well meaning but crap advice for the UK scene.
Student Pilot needs advice on buying 172 Cessna mcannon Owning 2 September 5th 05 03:43 PM
Advice on buying a 182 Robbie S. Owning 26 February 11th 05 10:28 PM
Advice on buying a 152? rajek Owning 27 June 21st 04 08:09 PM
I need some advice on buying my own plane BEFORE training... Anthony L Piloting 6 April 22nd 04 11:13 PM
Advice request -- buying an airplane Casey Wilson Owning 4 April 19th 04 03:22 PM
