I am 6'4" tall. I weigh about 200-210lbs clothed. My height is fairly evenly distributed between legs and torso. My arms are rather long, though.
Please help me start developing a shopping list for a decent glider that I can enjoy owning and flying without cramps or impeded control movements. This would be my first foray into ownership, but I expect to own multiple in the future. Factors to consider: 1. Prefer 2-place to single-seat, but I'm open to both. 2. If 2-place, must be FAA type-certified with standard airworthiness certificate. No experimentals. I want to be able to give commercial rides, instruction, and CAP cadet o-rides. Solo ships can be experimental, but not amateur-built. 3. Will consider self-launchers, sustainers, and motorgliders, but not looking to get into that price range. 4. Will consider antiques & open cockpits, if they have a provenance. 5. Not concerned with competition. 6. Acro would be a plus. 7. Will consider something life-limited (e.g., Lark) if I can get it super-cheap to use as a disposable platform for a couple hundred hours to better identify what I really want from a glider. 8. Priced under $30k, $10-15k is better. My experience: Highly active airplane pilot, IFR, 1000+ hours. Low-time glider pilot (100 hrs). Here's what I have flown: L-23: Fits okay, not very charming to own. ASK-21: Tight, but doable G103: Tighter than the ASK-21, prefer to avoid Bergfalke: Antique wooden open-cockpit novelty; not a candidate. I'll be trying out a SGS 1-23 and an LS-1f this weekend. There are several KA-6 models for sale all over right now (did they just get hit with an AD or something?), so some targeted opinions on these 3 would be timely. Cheers |
The HP-24 would fit you just fine, I guarantee it. It has 18m tips and FES as options. You also get to do all your own inspections and maintenance.
https://www.facebook.com/HP-24-Sailp...t-200931354951 Thanks, Bob K. www.hpaircraft.com |
I'm 6'1" with a long torso. I wasn't even CLOSE to fitting in the LS1-f.
I tried a discus B the other day.. Couldn't close the canopy. I've flown and ASW-24.. but with no seat back, and no chute. Still wasn't comfortable. I hear the HPH 304 is big. Going to try that. I feel your pain. Just keep trying. JP |
Look at the Genesis 2... Very roomy cockpit. And there was one on wings fairly recently...
I'm 6'2", 220lbs, my standard cirrus fits me well with a strong 303 chute and a two inch backrest pad. Less than $20k and good factory support, I like it a lot.
Good lift, Scott. |
Mosquito, Jantar & Pik-20 have enormous cockpits.
I'm 6-3 and fit in the above with room to spare. Nick. |
DG 100/101 ( 1 piece canopy) or 300...
Roomy cockpit, reclined position. A friend of mine about your size fit well into his DG 100, without a chute though, and it had the 2 piece canopy... |
I'm 6'4" tall 195 lbs.
I fit well in my LS3-a. I have been comfortable during long flights. My longest is 8+ hours. The LS-4 has the same size cockpit as the LS-3 I believe. |
Since you are snug in the G103, the roomiest cockpit
out there is the Genesis. Also try Ventus 2bx or 2cx, make sure it is the "x" I know a couple tall pilots who fit well in these. However the ventus will be 3x the price of the Genesis. |
On Thursday, September 8, 2016 at 6:12:37 AM UTC-5, joesimmers wrote:
Since you are snug in the G103, the roomiest cockpit out there is the Genesis. Now that I think about it, I recall that the G103 had some crazy thick pads in the seat. At the time, I was fairly new to gliders, so it didn't occur to me that the pad thickness could be changed out. I think what I should do is: 1. Test the seat with no pads. If it's too tight, then that ship is off the list. 2. Test it with whatever pads the owner has. If I still fit, great. If not, then I know that a thinner pad will probably allow me to fit. 3. Research the availability of thinner pads for the glider described in #2 above. As long as I don't have to pay $2k for some custom-stitched job, I can get along. Now parachutes are another story. Unless I have an acro bird, I do not plan to wear one. I hate them. And the thickness of a chute is likely to create insurmountable fit problems. Does anyone want to rebut these points? Or do I seem reasonable? |
Sooo ... Glider pilots DO make good jet pilots! | AS | Soaring | 2 | November 30th 15 09:02 AM |
Good news for pilots - retirement age | Greg Farris | Piloting | 48 | January 29th 07 01:57 AM |
About Good Pilots and Bad Pilots | Dudley Henriques | Piloting | 96 | February 23rd 06 01:19 AM |
Are pilots really good or just lucky??? | Icebound | Instrument Flight Rules | 68 | December 9th 04 01:53 PM |
Tall pilots in Helo's... | BEEPER708 | Rotorcraft | 5 | September 5th 03 05:05 AM |
