Fatal crash Arizona
Old September 13th 16, 11:24 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default Fatal crash Arizona
At 17:28 13 September 2016, BobW wrote:
On 9/13/2016 9:26 AM, Dave Nadler wrote:
On Tuesday, September 13, 2016 at 10:34:20 AM UTC-4, BobW
As for the report's claimed missing pawl spring...I must be
getting
dense
in my old age, since I'm still puzzled by the intended function
and line
of force of that implicated piece of (missing?) hardware. Back
to the
hook design - what am I missing? Thanks!
Bob W.
If I understand correctly, the missing spring pushes the pawl in
direction opposite of pulling the release knob. Otherwise, the
pawl is
not
secured in the "latched" position, except by a bit of friction with
hook plate (from the spring that is present and any rope
tension).
Do I understand correctly??
Quite possibly. I suppose such a spring fairly might be considered
"suspenders" to the hook-retract-spring's "belt." It's not obvious
from the
photos (Figure 1 shows it best), but installed-geometry, plus
gravity, in
pawl's as-installed position/angle work "against" the pawl
remaining
detent-seated...i.e. the pawl pivoting by itself (no other physical
contacts)
would tend to flop its "business end" *away* from the detent due
to the
longer
cable-attach arm's length compared to the detent-engagement
arm's length
(unequal length teeter-totter).
Nonetheless, whether the absence of a compression spring
between the pawl
and
receptacle/pawl-spring-housing was a crucial element in this
accident is
debatable; it would take very little force on the rope to rotate the
cable
hook from the barely-engaged position (Figures 9) to the fully
engaged
position (Figure 8). Once there, further testing definitely required
to
determine whether the design would be more or less prone to
back-releasing
in
the absence of the pawl spring, in the presence of a rope bow...
That said - and since a number of these hooks have been installed
into the
noses of German-built ships originally entering the USA with only
a CG hook
owners of ships with these hooks SHOULD (and easily can) VERIFY
presence/absence of such a compression spring by checking to
see if the
pawl
is positively forced against the rotating piece of the cable hook
throughout
its rotation range. Positive engagement = spring-present. (Note
that the
spring itself is hidden in the hook's assembled state...and might
easily
escape unnoticed in the event of the hook being disassembled for
any
reason.)
Bob W.
I am now confused by the "installed in German" part. Is the release
you are talking about a TOST release?
  #162
Old September 14th 16, 02:25 AM posted to rec.aviation.soaring
BobW
Snip...
into the
a CG hook
- owners of ships with these hooks SHOULD (and easily can) VERIFY
see if the
pawl is positively forced against the rotating piece of the cable hook
throughout its rotation range. Positive engagement = spring-present.
Bob W.
I am now confused by the "installed in German" part. Is the release you are
Sorry for any confusion. A number of "Applebay releases" have been
subsequently installed in (on the fuselage bottom surface, near the front of
the nose of) non-USA-built gliders imported into the USA with only a single,
CG-mounted, release back by the wheel. This second cable attachment point
provided "a nose-hooked aero-towing option." Many - not all - such modified
ships were of German origin.
FWIW, I've been privately informed by a fellow Zuni owner (of S/N 28) that his
ship's release uses a(n easily visible) *tension* spring (not compression, as
on S/N 2) to positively seat the pawl against the rotating/indented cable hook
part...which is what my fallible memory kinda-sorta remembered from my own
(not recently looked at) Zuni (S/N 3).
In either case, any owner of a ship with an "Applebay nose release" can/should
easily confirm the presence of such a spring by verifying the business end of
the pawl is "somehow or other" positively forced against the rotating cable
hook as it operates throughout its range of motion. The truly curious can
disconnect it before operating their releases to get a better feel for what I
sought to describe in an earlier post. Please do reconnect it...or YMMV!
Bob W.
  #163
Old September 14th 16, 09:18 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
installed
into the
only
a CG hook
VERIFY
to
see if the
hook
present.
Bob W.
release you
are
been
the front
of
a
single,
attachment point
such modified
28) that
his
compression,
as
cable
hook
from my own
release"
can/should
business end
of
rotating cable
curious can
what
I
YMMV!
Bob W.
Thanks for that. My ASW17 was fitted with a TOST winch hook near
the nose for aerotow. There was a wooden block installed behind
the back release ring to prevent it's operation as a back release
function on an aerotow hook is undesirable. Back in the 60's we
would tape up winch launch hooks to prevent the back release from
operating when aerowtowing.
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
