Dust Devil Dash - September 10
Old September 10th 16, 03:31 AM posted to rec.aviation.soaring
JS
Default Dust Devil Dash - September 10
The last pre-DDD update of TFR files for a 450SM radius of Tonopah, Nevada in TXT and CUB formats is available.
Find them in Dropbox (link below) and the Tehachapisoaring Yahoo newsgroup.
http://tinyurl.com/DustDevilDash
The waypoint database 2016 v1.5 is available on Soaring Turnpoint Exchange, thanks to John Leibacher. I only ask John for one update per year. He may or may not have updated airspace files, depending on his work load.
The Tehachapisoaring group has access to 2016 v1.6. Dropbox has CUPX file v1.6. The changes are minor, and documented in the SW Aviation Database Information.pdf file, in Dropbox.
Old September 11th 16, 12:33 AM posted to rec.aviation.soaring
Tony[_5_]
Looks like at least two are north of Reno! Go go go!
Old September 11th 16, 03:32 AM posted to rec.aviation.soaring
Tony[_5_]
Kevin Wayt at Lakeview, Oregon! 495 miles, nice!
Old September 13th 16, 04:28 PM posted to rec.aviation.soaring
JS
Results:
(dist/handicap dist)
1 Kevin Wayt 499.1 / 436.21
Old September 13th 16, 04:36 PM posted to rec.aviation.soaring
JS
Win, place and show...
(distance/handicap dist. In land miles)
1 Kevin Wayt Ventus C/17.6 Lake Co. OR 499.1/436.21
2 Terry Honikman/Thorsten Streppel Stemme S10VT Cedarville, CA 455.4/403.48
3 Tom Serkowski ASW27B Ravendale, CA 407.1/357.43
Old September 13th 16, 05:27 PM posted to rec.aviation.soaring
Jim,
How exactly are those distances measured?
Launch to Landing?
Start gate to fixed point?
Release point to fixed point?
Release point to landing?
R5
Old September 13th 16, 06:52 PM posted to rec.aviation.soaring
Ramy[_2_]
Tom actually landed at Fall River Mills, not Ravendale.
Ramy
Old September 13th 16, 09:53 PM posted to rec.aviation.soaring
JS
Ramy
Well spotted, Ramy!
I needed to get on the road and quickly copied those things from the preliminary score sheet.
Just spoke with Rob Morgan, who will correct that from Grand Junction or Greeley.
Tom's extra ~30 points will look good but may not change the leader sheet.
To answer R5's question it's Carl Herold Handicap, launch to landing. Penalty for ballast. Everyone tows to the ridge just south of Mountain Valley.
Past scores are available on SoCalSoaring.com
Anything from LK-10 to Nimbus 4D has appeared at the top of the score sheet.
http://www.socalsoaring.com/index.php?page=dustdevil
(includes a link to Crystal Squadron straight-out flights)
Old September 14th 16, 01:02 AM posted to rec.aviation.soaring
JS
More than likely this will be the score sheet.
Kevin did it again!
Pos Pilot Landing Glider/ID SM/Hcp Dist
1 Kevin Wayt Lake County, OR Ventus C-17.6 RW 499.1/436.21
2 T.Honikman/T.Streppel Cedarville, CA Stemme S10 TH 455.4/403.48
3 Tom Serkowski Fall River Mills, CA ASW-27B 5Z 439.3/385.71
4 Tom Riley Nervino, CA American Spirit TR 342.7/322.82
5 Tom Coussens Truckee, CA PIK-20D Z9 305.9/290.61
6 Doug Fronius Truckee, CA ASW-20 NXS 305.9/279.29
7 Jim Neff Field SE of Mammoth SGS-1-26E 552 161.0/257.60
8 Donald Buman Douglas Co Arp, NV LS-6c 7 278.3/242.96
9 Bill Laningham Bishop, CA ASW-24 DB 157.6/148.14
10 Mike Stryker Olancha, CA SGS1-36 17Q 85.7/112.61
11 Niv Levy Olancha, CA ASW-15 N 85.7/85.70
12 Ron Hodge California City SGS1-26D 417 23.0/36.80
Old September 14th 16, 03:26 AM posted to rec.aviation.soaring
Kevin did it again!
Way to go Kevin!
He and I left the start thermal at the same time and flew together for the first 20-30 miles then split up to go up opposite sides of the Sierras. Rejoined at Mammoth and added Terry/Thorsten to the group. The three ships then flew loose formation to Susanville before splitting up.
I saw a few wisps forming ahead on a path to Mt Shasta, so decided to try reaching it. Unfortunately, I didn't realize that apparently marine air infiltrated the high ground east of Redding and couldn't find any more thermal lift. Worked some ridge lift on a couple hills before throwing in the towel and landing at Fall River Mills.
Kevin, as is often the case, managed to time his final glide to arrive just a couple minutes before sunset!
5Z
Dust Devil Dash JS Soaring 2 September 2nd 15 05:09 AM
Dust Devil Dash -- Teahchapi California Saturday September 17th, 2011 Oscar Soaring 1 September 15th 11 09:55 PM
DUST DEVIL DASH Ian Cant Soaring 0 September 4th 10 09:31 PM
DUST DEVIL DASH Ian Cant Soaring 0 September 4th 10 09:12 PM
Dust Devil Dash [US] Ian Cant Soaring 2 September 15th 07 02:50 AM
