Speed record?
Old September 21st 16, 02:01 AM posted to rec.aviation.soaring
Soartech
Default Speed record?
or fantasy of flight?
On page 52 of the September issue of Soaring magazine Jim Payne is listed as having flown an out and return course of 300 km at an average speed of an amazing ground speed of 189.62 MPH ! Can someone please explain how he did this when the Vne of the Arcus M is 174 MPH. It seems to me the only way to do this is to somehow fly (at Vne the entire flight),downwind, on both out and return legs.
Old September 21st 16, 02:24 AM posted to rec.aviation.soaring
Tom Kelley #711
Wave and altitude kick. Remember the higher you fly your TAS increases. That"s why speed and distance folks fly the great basin. Crusing at 16-18 thousand gets you a 30 Kt kick in TAS. Here's his story from the OLC. Best. #711.
___________
Pilot:
Co-pilot Miguel Iturmendi.
Mission was to fly a declared 300 km out-and-return between Inyokern and Big Pine.
The forecast said the wave would be weak early with winds and lift increasing in the late afternoon.
During the first lap, the wave was not good between Cindercone and Manzanar....the turn was covered in cloud.
During the second lap, the lift was better...the speed was 278 kph.
By the third lap, the lift was ripping and the clouds much better...the speed was 305.12 kph (189.62 mph)...
Late in the day the Antelope Valley was overcast. We descended through a large hole in the overcast near California City.
Had a Sage 2 clearance to FL290 in R-2508.
For photos see www.tumblr.com/SoaringBlog.
Thanks, Cindy for coordinating the Sage 2; Joshua for the outstanding service; and Doug T, Greg, Beth, & Jackie for crewing.
Old September 21st 16, 04:28 PM posted to rec.aviation.soaring
Duster
Link doesn't work for me
Old September 21st 16, 05:07 PM posted to rec.aviation.soaring
RobKol
http://soaringblog.tumblr.com/
Old September 21st 16, 09:12 PM posted to rec.aviation.soaring
Soartech
Tom, Thanks for the explanation. I recalled it as the other way around.
Old September 21st 16, 09:14 PM posted to rec.aviation.soaring
Papa3[_2_]
A rule of thumb under standard conditions is about 2%/thousand feet increase in True Airspeed. So, if you're indicating 100kts at 10% feet you're actually doing closer to 120kts over the ground in still air.
Now, the problem kicks in with flutter and aeroelasticity, so the VNE (indicated) decreases with altitude in most gliders. I'll leave it at that, since it's been more than 30 years since my last problem set on that topic :-)
P3
Old September 21st 16, 10:10 PM posted to rec.aviation.soaring
Ian[_2_]
Pilot:
During the first lap, the wave was not good between Cindercone and Manzanar...the turn was covered in cloud.
Hats off to the pilots for their performance. But the above looks a bit
extreme. So I did some checking. Google found me a copy of the "Flight
Manual for Powered Sailplane, Arcus M" at
http://www.schaenis-soaring.ch/filea..._M_AFM_ENG.pdf
Around page page 38 of that document is a table listing Max permitted
speed verses altitude. I listed 3 points in their hight band below and
used my old circular flight computer to find the TAS at each of the
altitude.
Altitude (m) VNE (km/h) TAS (km/h)
7000 220 318
8000 207 320
9000 195 318
There is obviously a pattern above. To achieve an average cross country
speed of 305km/h must have required operating right on the edge of the
envelope for the entire flight.
Ian
Old September 21st 16, 11:03 PM posted to rec.aviation.soaring
Bruce Hoult
Pilot:
altitude.
7000 220 318
8000 207 320
9000 195 318
Ian
The police won't come knocking on your door if you exceed the "permitted" speed.
They're designed to 40% (?) above Vne and test flown to 20% (?) over.
Yes, exceeding the Vne printed in the manual makes you a test pilot. That's part and parcel of world record flying. Don't try it at home.
Old September 22nd 16, 02:59 AM posted to rec.aviation.soaring
howard banks
Every glider flight manual I studied made it clear that the flight tested limits laid out applied up to 3000 meters ... over that you are relying on a combination of theory, over-design, excessive build over required standards, and it always seemed to me good fortune. I have no idea if such applied to the Arcus M used by Payne.
Old September 22nd 16, 04:26 AM posted to rec.aviation.soaring
Jim's a retired USAF test pilot, so I'm sure understands all the intricacies of flying near Vne.
I'm not an aerodynamicist so here's my lay understanding. A glider's Vne is the true airspeed as indicated IAS at typically 3000m. If I recall, my ASH-26E redline was 146 KIAS which worked out to 160-ish TAS. The chart Schleicher provides for Vne above 3000m drops the IAS to keep the TAS at or below 160.
My ASW-27 chart is:
10K 151 knots
16.5K 133 knots
23K 119 knots
etc...
In the '26 I flew a 100 km triangle in wave between 14 and 18K MSL so limited my IAS to a conservative 120 knots, which I maintained nearly the whole time. The achieved speed for the triangle was a bit over 130 knots. So TAS is your friend even below 18K!
If repeating this in the '27 I would again use 120 as a "safe" Vne for below 18K.
5Z
2200k at 194.66kph is this a speed record? joesimmers[_2_] Soaring 4 May 5th 12 04:05 AM
sailcar speed record bagmaker Soaring 7 April 1st 09 10:47 PM
New world speed record: 534 km/h! [email protected] Soaring 8 September 23rd 06 02:25 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
F-106 Speed record questions.... David E. Powell Military Aviation 67 February 25th 04 06:13 AM
