nano troubles
Old September 28th 16, 11:10 PM posted to rec.aviation.soaring
Default nano troubles
My Nano suddenly started acting up. The computer won't recognize it and keeps giving a mass storage device malfunction message. We've tried different cables and computers with the same results. You can take the chip out and download the flights fine, the computer just won't recognize the Nano. Anyone have any experience with this ? So far Im not getting much back from LX..
thanks
Skip
Old September 29th 16, 12:05 AM posted to rec.aviation.soaring
Dan Daly[_2_]
thanks
Skip
Are you running the latest Nano firmware (version 2.30)?
Have you upgraded it lately?
Have you tried downloading it with NanoConfig?
Old September 29th 16, 01:26 AM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
My Nano suddenly started acting up. The computer won't recognize it and keeps giving a mass storage device malfunction message. We've tried different cables and computers with the same results. You can take the chip out and download the flights fine, the computer just won't recognize the Nano.. Anyone have any experience with this ? So far Im not getting much back from LX..
thanks
Skip
We saw this behavior with a couple Nanos at R4S recently. Suspect it is some kind of Windows 10 issue but this is just speculation thus far.
QT
Old September 29th 16, 02:14 AM posted to rec.aviation.soaring
Richard[_9_]
thanks
Skip
First of all don't ever take the micro SD card out of the NANO, Never. And if you have taken it out make sure it is inserted and seated correctly if not you will get an error. It is not designed to be removed.
Make sure the Nano is off when you plug it into the USB port, if it is not off it will give you a malfunction error.
On the side opposite the switch is a hole push a paper clip into the hole to reset the NANO.
If none of this works it has to go back to LXNAV.
Richard
www.craggyaero.com
Old September 29th 16, 02:37 AM posted to rec.aviation.soaring
kiwiindenver
thanks
Skip
I know you said you tried different cables... My Nano is picky about the cable it likes. I now have a higher quality thicker USB cable I always use with the Nano. When I had unreliable PC connections it was always with a typical thin USB cable.
Old September 29th 16, 03:07 AM posted to rec.aviation.soaring
My Nano was acting up at the R4S. I followed Richards instructions by getting a paperclip and resetting it. Problems went bye bye.
Old September 29th 16, 05:47 PM posted to rec.aviation.soaring
thanks
Skip
does it need to be off or on when you reset it with the paperclip?
Old September 29th 16, 09:05 PM posted to rec.aviation.soaring
Richard[_9_]
thanks
Skip
try both on and off
Richard
www.craggyaero.com
Low Altitude Troubles [email protected] Soaring 22 February 4th 14 01:31 AM
G 103 Twin II weight troubles... Eric van Geetsum Soaring 6 April 6th 11 01:33 AM
Newsgroup troubles all over, FYI... walking Piloting 13 July 2nd 08 12:18 PM
troubles with ATC john hawkins Piloting 3 May 6th 07 05:30 PM
troubles with ATC john hawkins Instrument Flight Rules 3 May 6th 07 05:30 PM
