Blow holes vs turbulaator tape.
Old October 24th 16, 12:54 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Blow holes vs turbulaator tape.
Just curious if there is research that compares blow holes versus tabulator tape as to effectiveness and drag? i.e., are the bow holes worth the maintenance or is tape effectively just as good? Does the new Ventus have tape or blow holes?
Old October 24th 16, 01:35 AM posted to rec.aviation.soaring
Blow holes don't involve much extra maintenance. When I was polishing the wings on my DG-303, I'd just put a piece of wing tape over them. I only checked whether any holes were clogged once, as I decided it was unnecessary. Hook a low pressure air source to the intake (I used a vacuum cleaner exhaust port). Hold a lit stick of incense over each one, if it failed to brighten up, run an appropriate size needle through the hole (carefully, so as not to push out the brass tube insert). It took longer to replace old turbulator tape on my other gliders.
DG offered a DG-300/303 Club with (among other things) dimple tape replacing the blow holes, I guess they decided the blow holes were worth a premium for that particular airfoil.
Marc
Old October 24th 16, 01:40 AM posted to rec.aviation.soaring
Michael Opitz
tabulator
Ventus have
tape or blow holes?
That subject goes back over 30 years. As I recall, the blowholes
would be better performance-wise if they could be regulated to blow
really strongly at low speeds, and then blow only a little at higher
speeds. To do this, one needs a large inlet to supply enough air to
the ducts at thermalling speeds. Then, you have to shut that
supply down to a trickle when cruising at higher speeds. This goes
backwards to just having a fixed size inlet that is not adjustable in
flight. One would have to have an extendable scoop on each wing
that the pilot could extend and retract depending on airspeed to
achieve this.
Anyway, the Z-tape works pretty well, is cheap to install, and is
easy to maintain. The blowholes are labor intensive both in
construction ($) and in maintenance.
I had DG-300 serial number 2, which was one of the first gliders
with this technology. Back in 1983-1985, I did side by side
comparison tests with the blowhole system working on the regular
fixed size inlets. Then, I repeated the (side by side) tests with the
inlets removed (to nullify the blowholes), and used Z-tape for the
turbulation instead.
I could not see any measurable performance difference between
blowholes (with fixed size inlet) and Z-tape. There were arguments
about the Standard Class rules to the point that there would have
been protests filed if I had come up with and used a variable inlet
scoop, so I left it alone.
So, long story short. The Z-tape is a lot cheaper and easier, and
yields good results. If you are in a class which would allow inlet
size adjustment in flight, and you have lots of money to pay for the
installation, and lots of time to spend maintaining all of of those tiny
holes, then you might see a marginal improvement over Z-tape.
That's how I remember it, although it was a long time ago, and the
blowhole technology may have gotten better.....FWIW
RO
Old October 24th 16, 03:26 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Thanks for the reply. I seem to remember that Dick Butler had throttled the blow holes on his ETA biter, not sure how he did that. seems like tape would have more drag but the manufacturing must be very time consuming (expensive).
tabulator
Ventus have
tape or blow holes?
achieve this.
RO
Old October 24th 16, 04:12 PM posted to rec.aviation.soaring
tabulator
Ventus have
tape or blow holes?
achieve this.
RO
Other than a little care during polishing blowholes don't need much attention but zig-zag tape keeps catching on grass, clothing, under finger-nails and on rigging trestle tops resulting in little sharp and draggy lifted corners that won't stick back down easily.
Old October 24th 16, 04:23 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Model airplane servos to open or close the supply. I think there were two sets of holes. One set further forward for lower speed, and another further back for higher speed. I think the aft set was always open, but the forward set could be closed off to not trip the flow before it needed to be tripped. Tape is only set for one C/L. With multiple sets of holes, you can transition based on C/L with different hole locations.
Old October 24th 16, 05:50 PM posted to rec.aviation.soaring
Jim White[_3_]
Herr Waibel has been quoted as saying of the ASW27 that "there is a 50/50
chance that the blow holes improve performance by 1/2 point". Possibly
apocryphal. Easy to clean with a piece of copper wire and a vacuum cleaner
but tedious beyond belief. jim
Old October 24th 16, 07:18 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I think the JS-1 has two sets of blow holes, as per their web site.
Old October 24th 16, 07:25 PM posted to rec.aviation.soaring
Soarin Again[_2_]
I once got a DG300 in for insp and found that the blow holes on one wing
were inop (apparently the seal of the internal blow hole channel had
failed). The factory said a fix was problematic and to go ahead and
install dimple tape as it works just as well. No telling how many years
the glider flew with one wing turbulated and the other not. The owner was
oblivious to any degradation in handling or performance before and after
installing the dimple tape.
ME
Another Blow to Airbus a[_3_] Piloting 52 August 19th 10 10:49 AM
To blow or not to blow... Dallas Piloting 50 February 15th 08 12:57 PM
oil blow out IO-360 Robert M. Gary Piloting 18 July 17th 06 04:44 PM
oil blow out IO-360 Robert M. Gary Owning 18 July 17th 06 04:44 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
