Winch Launch - Fatal
Old December 9th 16, 10:23 PM posted to rec.aviation.soaring
Dan Marotta
Default Winch Launch - Fatal
Sew, ewe did not really mean two say "wench", then?
On 12/9/2016 1:29 PM, Jonathan St. Cloud wrote:
Damn autocorrect meant wrench launching.
On Friday, December 9, 2016 at 12:02:52 PM UTC-8, Dan Marotta wrote:
Wench launching can be very dangerous, especially if she's heavy and
your aim is poor...
On 12/9/2016 9:19 AM, Jonathan St. Cloud wrote:
So how dangerous is wench launching compared to aero-tow? I only had enough wench launches to remove the "aero-tow only" off my ticket and that was years ago.
On Friday, December 9, 2016 at 7:45:05 AM UTC-8, Don Johnstone wrote:
At 08:24 09 December 2016, Pete Smith wrote:
No, the position changes subtly.
On my cirrus and N2 it is at the lower left of the stick box quadrant,
o
N3 in question and later gliders it is in the upper left.
Please read the accident report and its conclusions.
The accident described in the report was not so much of an issue
when Earlier ASW,17, 18,19,20 were designed and built. Same applied
to SH.
The accident is directly related to more powerful winches. The same
situation would develop with less powerful winches but it took much
much longer. There was more of a ground run to recognise the wing
on the ground and the acceleration was much less which meant that
when it went wrong it went wrong much slower with more time to
react. Not so with a modern powerful winch, when the problem occurs
it goes wrong very quickly, probably too quickly for any chance for a
meaningful reaction. What is described has always happened from time
to time, the only difference is that it did not start killing people until
the winches got powerful.
Dan, 5J
Dan, 5J
  #32
Old December 9th 16, 11:40 PM posted to rec.aviation.soaring
Jonathan St. Cloud
The wench launch comment was meant for another newsgroup!
How dangerous is winch launching went compared to aero-tow? In the States most launches are aero-tow.
Those that know me, also know you would never see me launch a wrench, as experience has taught me never pick up a tool.
your aim is poor...
o
to SH.
Dan, 5J
Dan, 5J
  #33
Old December 10th 16, 02:21 AM posted to rec.aviation.soaring
Scott Williams
I must agree with Don Johnstone,
todays winches are very powerful.
Does this result in higher launches or just much more rapid ones?
  #34
Old December 10th 16, 04:19 AM posted to rec.aviation.soaring
o
to SH.
Muddled thinking, Don.
All winches have throttles so they produce no more power than the winch operator chooses. If the winch seems too powerful, you're problem is with the winch operator, not the winch.
Did "powerful" winches cause a wing drop and subsequent ground loop? Highly unlikely. The problem is far more likely to be with pilot training and general winch operations.
Wings go down on winch launch for three main reasons.
One, excessively slow acceleration allows a wing drop before the pilot gains aileron control - same as with aero tow. The difference is with a CG hook an ensuing ground loop is going to be more violent. It's much safer to get the glider up to aileron control airspeed in the minimum time.
Two, with a fast accelerating winch, should the pilot begin the ground roll with aileron input, they will take effect suddenly forcing a wing tip to the ground before the pilot can react - consciously centering the stick before the launch starts is critical. Avoiding over-controlling ailerons is equally important.
Three, wing "runners" sometimes mishandle the situation. If they are accustomed to aero tow, they will be surprised how quickly the tip must be released.
  #35
Old December 10th 16, 10:10 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 04:19 10 December 2016,
quadrant,=
=20
o
the=20
issue=20
applied=20
to SH.
same=20
much=20
wing=20
that=20
to=20
occurs=20
for a=20
from time=20
unti=
l
=20
Not muddled, incomplete. The problem is far too complex to
describe in a short post.
the winch
ope=
with
the=
In part, yes however the difference is in what is possible. A less
powerful winch is incapable of the rapid acceleration. People make
mistakes, with a less powerful winch the operator cannot make the
mistake of applying too much power. A powerful winch has very
little to do with the cause, it has everything to do with the outcome.
ground loop?
Highl=
and
g=
No, see above, the more powerful winch effects the outcome.
Wings go down on winch launch for three main reasons. =20
pilot
gain=
CG
hoo=
safer to
g=
ground
roll=
tip to
t=
stick
befo=
is
eq=
ually important.
are
accus=
be
relea=
sed.
Post hoc, ergo propter hoc. It seems widely believed that the "wing
drop" is a cause when it is far more likely it is a symptom. To take
your points individually. It used to be popular for pilots to apply
aileron and rudder, prior to moving on a winch launch to anticipate
wing drop in a crosswind, and people got away with this on slower
accelerating winches. Hopefully we have trained this out, certainly
something I am very pedantic about. All the controls, especially the
rudder should be central. The latest advice to wing runners is if
there is any significant force required for them to keep the wings
level the launch should be stopped and the pilot appraised. I would
go further and say if there is any significant force required, with
the ailerons central, then the launch should not take place at all.
Excessively slow acceleration does not cause wing drop, wing drop
is caused by aerodynamic forces. The slower acceleration does
reduce the effectiveness of the control making recovery more
difficult. The wing drop is still a symptom of a developing problem,
not a cause.
I have never said that a powerful winch is the cause of the problem,
it isn't. The same problem occurred from time to time on less
powerful winches but over a much longer period of time and less
energy was available to be put into the glider. The increased power
effects the outcome with the increase of available energy and
therefore the larger divergence and reduced time period over which
the incident takes place. If a control is inappropriately applied the
effect is much greater with the higher speed.
The problem has always been there, it is just that before powerful
winches it did not tend to kill people.
  #36
Old December 10th 16, 12:26 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
be released.
Two additional points (which you may already do):
-train the wing runner to hold the tip from behind (NEVER with
fingers round the leading edge).
This makes it much less likely that the
wing runner can deflect the glider before letting go.
-teach wing runners to BALANCE the glider on its wheel, raising or
lowering the tip a bit to counter the forces generated by a cross-wind.
Done right, you need little more than a finger and thumb on either side
of the TE to keep the wing balanced despite gusts.
If the wing runner is forcing the wing level against a cross wind, then
a wing-drop is almost guaranteed when the tip is released.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #37
Old December 10th 16, 01:08 PM posted to rec.aviation.soaring
IME the control systems in the winch are the most important factor
provided that the winch has enough power to avoid running it flat out for
most of the launch.
I learned on a Supacat (240hp diesel V-8), straight drive, driver's
judgement and hand on the throttle were all that controlled the winch.
Now we have a Skylaunch (380hp LPG converted V-8), automatic gearbox,
analog launch controller which the driver can override. The Supacat used
steel cable while the Skylaunch has always used HD poly rope. I've
regularly flown my Libelle and club gliders (K21, Puchacz, Junior) off
both winches. Initial acceleration rates are similar and so are release
heights, but by and large the Skylaunch gives more consistent launches.
Oddly enough, Supacat launches were faster, typically just below Vwinch,
while the Skylaunch launches are about 5 kts slower, which feels a lot
nicer.
org |
  #38
Old December 10th 16, 02:53 PM posted to rec.aviation.soaring
be released.
org |
Yes, balancing the wing and never just "leveling" it is always a better method - for both winch and aero tow.
  #39
Old December 10th 16, 03:10 PM posted to rec.aviation.soaring
quadrant,=
=20
o
the=20
issue=20
applied=20
to SH.
same=20
much=20
wing=20
that=20
to=20
occurs=20
for a=20
from time=20
unti=
l
=20
the winch
ope=
with
the=
ground loop?
Highl=
and
g=
pilot
gain=
CG
hoo=
safer to
g=
ground
roll=
tip to
t=
stick
befo=
is
eq=
ually important.
are
accus=
be
relea=
sed.
not a cause.
It's not complicated. As with most aviation safety issues, the solution to wing drops is speed and altitude. Speed for aileron control and altitude to get the wing tips away from the ground. Getting both quickly reduces the risk.
  #40
Old December 11th 16, 10:14 AM posted to rec.aviation.soaring
Peter Whitehead
On Tuesday, 6 December 2016 14:15:05 UTC, Jock Proudfoot wrote:
Modern winches are powerful so the ground run is shorter, and it is this which allows greater height on launch (you are effectively lengthening the airfield compared to those with "anaemic winches"). The problem is the acceleration and reduction in time to sort out the problem with wing drop on the ground, and also a stall and wing drop (to inverted ) in the rotation (to climb).This can all happen too quickly for human responses. It kills "smart" people.
Please do read and digest (and disseminate) the following link from experts in the field, the BGA. This programme of "safe winching" has shown reduction (evidence based) in accidents and fatalities in this mode of launching.
https://www.bfgc.co.uk/Documents/Winching.pdf
Pete Whitehead
Winch Launch School Karl Striedieck[_2_] Soaring 1 January 7th 16 03:10 PM
Winch Launch Fatality Nyal Williams[_2_] Soaring 89 June 27th 09 08:45 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
