Winch Launch - Fatal
Old December 14th 16, 09:19 AM posted to rec.aviation.soaring
Jim White[_3_]
Default Winch Launch - Fatal
At 01:59 14 December 2016, wrote:
Don, you brought up the old pitch-up myth so I'll go there.
Pitch-up on acceleration can only happen with the tailwheel in the air
and
that can only happen if the glider is slowly dragged into the air with
feeb=
le acceleration and THEN strong acceleration applied. It can't happen if
s=
trong acceleration is applied at the very start of the ground roll and
main=
tained until the glider reaches the normal airspeed for rotating into the
c=
limb.
I could go on at length about this but I wrote a long paper on it
available=
here
https://dl.dropboxusercontent.com/u/...celeration.pdf
Rather
than take my word for it, I very strongly suggest the BGA and other
nationa=
l clubs do their own investigation using tension loggers. What you will
se=
e may terrify you.
Hi Bill. If you follow URAS you will see that Don, whilst old and wise,
doesn't speak for the UK gliding community.
  #52
Old December 14th 16, 09:35 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Quote:
Originally Posted by View Post
On Tuesday, December 6, 2016 at 7:15:05 AM UTC-7, Jock Proudfoot wrote:
You're right, relying on the pilot pulling the release doesn't work simply because it takes too long for the pilot to react.
I think there is just one cause of ground roll accidents and it's very simple - inadequate acceleration.
A glider just wants to fly and with the wing incidence angle at about 10 degrees with the tailwheel on the ground it will do so in about 2 seconds at 1G. Unless things are badly set up beforehand, the wings will stay balanced for at least that long. Once airborne. there is no risk of a ground roll accident.
The acceleration which worked with old wooden glider just doesn't get a heavy glass glider to aileron control speed and then airborne quickly enough.
Pitch-up on acceleration can only happen with the tailwheel in the air and that can only happen if the glider is slowly dragged into the air with feeble acceleration and THEN strong acceleration applied. It can't happen if strong acceleration is applied at the very start of the ground roll and maintained until the glider reaches the normal airspeed for rotating into the climb.
I could go on at length about this but I wrote a long paper on it available here https://dl.dropboxusercontent.com/u/...celeration.pdf Rather than take my word for it, I very strongly suggest the BGA and other national clubs do their own investigation using tension loggers. What you will see may terrify you.
Hi Bill
An excellent paper and one that I will be sharing. It tallys with my own observations from watching multiple higher acceleration winch launches of a PW-5. In all cases the tail wheel hit the ground with the acceleration and with the stick neutral the glider lifted off in a shallow climb with a slow controlled rotation with increasing speed till it was in the full climb at around 150'
As described in your paper, the most dangerous winch launches I have seen and experienced have been ones with slow acceleration
Regards
Colin
  #53
Old December 14th 16, 10:30 AM posted to rec.aviation.soaring
Terry Walsh[_2_]
and
feeb=
if
s=
main=
c=
limb.
available=
here
https://dl.dropboxusercontent.com/u/...cceleration.pd
Rather
other
nationa=
se=
e may terrify you.
Hi Bill,
The theory may be correct but I can assure you that a K18 ALWAYS needs the
application of almost full forward stck after lift off to prevent over
rotation. This is using a powerful V8 winch with about 2 seconds of ground
roll. Yes the accleration is still happening after lift off. With a narrow
steel drum throttle response is never instantaneous due to inertia of the
drum, even with the powerful (300 hp+) V8.
  #54
Old December 14th 16, 12:09 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
the ai
and
with
feeb=
happe
if
s=
and
main=
int
c=
limb.
available=
here
Rather
other
nationa=
you will
se=
e may terrify you.
wise
Hi Bill,
ALWAYS needs th
of groun
narro
of th
I believe there is a solution to this, one which no one will like, but
which would reduce the frequency of the accidents, unfortunately it
may also very expensive and difficult to achieve on existing aircraft
and would result in a reduction in winch launch height. Move the
launch hook forward.
  #55
Old December 14th 16, 01:04 PM posted to rec.aviation.soaring
It is pointless to enter into any sort of winch launching discussion here that is based on decades of experience by thousands of European pilots.
  #56
Old December 14th 16, 08:43 PM posted to rec.aviation.soaring
B4soaring
ver
about 1
wing
n
doesn't get
quickl
enough
the ai
ai
It can'
groun
fo
available her
Rathe
othe
Wha
Hi Bil
th
til
hav
Regard
Coli
Ventus_a
The tailwheel hitting the ground is normal for all gliders that sit on
a nosewheel and happens because the CofG is higher than the
winch hook. It has nothing to do with the rate of acceleration.
Taking off into a shallow climb with the elevator neutral is what I
would call normal acceleration.
Bill's pdf shows something completely different. The pilot is holding
the stick too far back in the early stages of launch & the elevator is
pushing the tailwheel down on to the ground even after the
mainwheel has taken off. That's just poor technique & usually
happens because the pilot is behind the aircraft & blindly pulling
back after the glider starts moving.
  #57
Old December 14th 16, 10:45 PM posted to rec.aviation.soaring
A Discus is a "taildrager" which normally sits tailwheel-down.
  #59
Old December 15th 16, 02:30 AM posted to rec.aviation.soaring
Having the tailwheel rolling along the ground with
the mainwheel several feet in the air is not, and never should be,
considered a normal winch launch.
Absolutely true, but counter-intuitively, the only way this could happen is with low acceleration. High acceleration means high rope tension which acts to pull the nose down if the tailwheel is still rolling.
If you look at videos of winch launch takeoffs frame-by-frame you'll find that it's not unusual to see the main wheel a few centimeters off the ground while the tailwheel is still rolling on the runway. The ASK-21 photo in the paper is typical of this. The duration of a "spur roll" is usually only a few frames of video so it's very hard to catch with a still camera.
One can get these videos with a YouTube downloader. Then, the file can be played back frame-by-frame.
  #60
Old December 15th 16, 04:01 AM posted to rec.aviation.soaring
JS
....Or perhaps any acceleration with C/G near the aft limit?
Experienced a "good looking" start if you didn't notice the stick full forward until airborne.
Still enjoy winch launching. We should do more of it.
Winch Launch School Karl Striedieck[_2_] Soaring 1 January 7th 16 03:10 PM
Winch Launch Fatality Nyal Williams[_2_] Soaring 89 June 27th 09 08:45 PM
Winch Launch Fatality Ed Gaddy[_2_] Soaring 3 June 23rd 09 11:15 PM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Winch launch M B Soaring 0 October 30th 03 07:33 PM
