Oudie IGC
Old December 17th 16, 09:53 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default Oudie IGC
How does Oudie IGC derive TAS and Wind? Especially when there is no thermalling. It does not have Ptot/Pstat input and does not have heading info.
The TAS (5 bytes) and GSP (5 bytes) are recorded in the *.igc file --in the B-Record, as configured by the I-Record.
Also--quantities TRT and VAT are recorded. What is that?
Thanks
Old December 17th 16, 10:40 PM posted to rec.aviation.soaring
Tim Newport-Peace[_5_]
Default Oudie IGC
info.
Thanks
TRT -Track True. Three numbers based on degrees clockwise from 000 for
north
VAT -Compensated variometer (total energy/NETTO) vertical speed in metres
per second and tenths of metres per second with leading zero and no dot
(".") separator between metres and tenths. Valid characters 0-9 and
negative sign "-". Negative values to have negative sign instead of leading
zero
Old December 18th 16, 11:25 PM posted to rec.aviation.soaring
Default Oudie IGC
Thanks
Thanks---
Found this Oudie was connected to an S80. So--mystery solved.
Oudie 5.19 Bug Lauren Soaring 3 June 4th 14 06:57 PM
Oudie fredblair Soaring 0 June 13th 12 06:56 PM
Oudie Peter von Tresckow Soaring 2 December 18th 11 01:31 PM
Oudie Steve Hunt Soaring 2 July 8th 11 12:19 AM
oudie Steve Hunt[_2_] Soaring 0 July 7th 11 08:58 AM
