#31
![]() "Chad Irby" wrote in message . com... In article , "Kevin Brooks" wrote: "Chad Irby" wrote in message m... You assumed the dam, as built, is one big structure of a certain cross-section, that the amount of concrete used on the dam *project* is the same as that just used on the dam (as opposed to the other dam structures, locks, roads, powerhouses), et cetera. I used the only numbers I had available. You have offered exactly--zip in terms of actual numbers. I did mention that the dam didn't have as big a cross-section as you think, with approximate thicknesses. You chose to ignore that, so it's your problem, not mine. You have not provided any specific numbers, period. You carped that it was, "...being about twice..." the cross sectional depth of the Rhine dams--OK, where did you get that from? I told you that I thought you were a bit shy in that estimate, and gave you the reasoning behind why I thought so. You did not respond with any actual measurement--you just carped again.What are the exact measurements at that point, since you seem to be so offended by the use of the rough calcs I gave you? In other words, where is the beef, Chad? Brooks -- cirby at cfl.rr.com |
#32
![]() "Kevin Brooks" wrote in message ... Let's see. Since the max ordinate for the dam in terms of upstream fill is supposed to be only about 175 meters, from what I have read, you halfway dimension would apparently be, based upon that 122 meter estimate above, something like 57 meters--let's be generous and assume a more favorable number for you, of maybe 40 meters (reflecting a more realistic actual cross section). Which last I knew was quite a bit more than 100 feet--more like 125 feet? 125 feet? Heck, if you can deliver them accurately a handful of GBU-28s should take care of the problem. Granted, the hole wouldn't start out that big between the water pressure and the fracturing around the hole I expect that problem would get bigger quickly enough. Now, could Taiwan deliver them (or a local equivalent), that could well be an issue. |
#33
... SNIP dam, and sink it with a depth sensor for detonation... OK, now we are getting into true fantasy land. This discussion started out about military strike operations, not John Wayne/Errol Flynn/Rambo Supercommando operations. The psited case is for Taiwan to do this in order to retaliate against a PRC invasion--and you see commandos, and boats, etc., running willy nilly about all over and around the dam, on land and water? Come on, now... Brooks Then there are two options which come to mind. The first requires more in the way of aircraft and weapons, number wise, and if Taiwan is being threatened by superior forces or heavily bombarded would be much more difficult to pull off. It would involve those carbon filament "grid buster" bombs or missile warheads shot all over the dam's power lines, as well as damage to whatever generators or transformers could be hit with conventional bombs. Plus ships or other things in the area. The second requires a nuclear bomb, perhaps encased in a penetrator case. I suppose this one would be right out, however. If it were go for broke and it were me, I would encase a small but powerful implosion device, maybe with a depleted uranium casing and tip in front of the guidance unit, in an old cannon barrel. Smash it through five to ten meters if possible then blow the crap out of it. The U-238 will add significant radiation to the site, though fallout would be limited by detonation in concrete and under water, depending on how much is ejected upwards, of course. Of course, at this point the PRC nukes Taiwan, so the second method is rather pointless to consider, no? -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#34
"Tank Fixer" wrote in message
k.net... In article , on Sat, 19 Jun 2004 08:42:35 -0700, Henry J Cobb attempted to say ..... What was the weapon that the Pentagon authors think that Taiwan either has now or could develop that would breach the Three Gorges Dam? http://militarynewswatch.blogspot.co...rpedo-dam.html Instant Sunshine Yep. -- When dealing with propaganda terminology one sometimes always speaks in variable absolutes. This is not to be mistaken for an unbiased slant. |
#35
![]() "John Keeney" wrote in message ... "Kevin Brooks" wrote in message ... Let's see. Since the max ordinate for the dam in terms of upstream fill is supposed to be only about 175 meters, from what I have read, you halfway dimension would apparently be, based upon that 122 meter estimate above, something like 57 meters--let's be generous and assume a more favorable number for you, of maybe 40 meters (reflecting a more realistic actual cross section). Which last I knew was quite a bit more than 100 feet--more like 125 feet? 125 feet? Heck, if you can deliver them accurately a handful of GBU-28s should take care of the problem. Granted, the hole wouldn't start out that big between the water pressure and the fracturing around the hole I expect that problem would get bigger quickly enough. Now, could Taiwan deliver them (or a local equivalent), that could well be an issue. First, Taiwan has no -28 delivery capability; the USAF limits such weapons to deployment on B-2's and F-15E's, IIRC. Secondly, GBU-28 penetration in concrete is about 20 feet from what I have read (the over 100 feet number is an earthen penetration. So don't be expectin' to punch many neat little holes with it in such a structure. Brooks |
#36
Think 100 tons of C4 would do it? I know how to get it there. As for
LZs, I made a bunch of them but never wanted to land there. Walt BJ |
#37
![]() "Kevin Brooks" wrote in message ... "John Keeney" wrote in message 125 feet? Heck, if you can deliver them accurately a handful of GBU-28s should take care of the problem. Granted, the hole wouldn't start out that big between the water pressure and the fracturing around the hole I expect that problem would get bigger quickly enough. Now, could Taiwan deliver them (or a local equivalent), that could well be an issue. First, Taiwan has no -28 delivery capability; the USAF limits such weapons to deployment on B-2's and F-15E's, IIRC. Secondly, GBU-28 penetration in concrete is about 20 feet from what I have read (the over 100 feet number is an earthen penetration. So don't be expectin' to punch many neat little holes with it in such a structure. I was thinking along the lines of multiple hits in the same location. If the first bomb penetrates 20 feet it will also crater x more feet and fracture y more feet softening the remaining concrete. I would be kind of surprised if three well placed GBU-28s couldn't penetrate a hundred feet of reinforced concrete damn, four I would think a near certainty. I doubt we've provided GBU-28s to too many folks around the world but it's not exactly a design concept cloaked in secrecy and mystery. Taiwan should be able produce a comparable design scaled for their delivery capability; assuming of course they HAVE a system capable of making it that far inland. Uh, how far exactly would that be? |
#38
![]() "John Keeney" wrote in message ... "Kevin Brooks" wrote in message ... "John Keeney" wrote in message 125 feet? Heck, if you can deliver them accurately a handful of GBU-28s should take care of the problem. Granted, the hole wouldn't start out that big between the water pressure and the fracturing around the hole I expect that problem would get bigger quickly enough. Now, could Taiwan deliver them (or a local equivalent), that could well be an issue. First, Taiwan has no -28 delivery capability; the USAF limits such weapons to deployment on B-2's and F-15E's, IIRC. Secondly, GBU-28 penetration in concrete is about 20 feet from what I have read (the over 100 feet number is an earthen penetration. So don't be expectin' to punch many neat little holes with it in such a structure. I was thinking along the lines of multiple hits in the same location. If the first bomb penetrates 20 feet it will also crater x more feet and fracture y more feet softening the remaining concrete. I would be kind of surprised if three well placed GBU-28s couldn't penetrate a hundred feet of reinforced concrete damn, four I would think a near certainty. I doubt we've provided GBU-28s to too many folks around the world but it's not exactly a design concept cloaked in secrecy and mystery. Taiwan should be able produce a comparable design scaled for their delivery capability; assuming of course they HAVE a system capable of making it that far inland. Uh, how far exactly would that be? Oh, a mere 1200 to 1400 miles up the Yangtze River, maybe 1500 miles from Taiwan; piece of cake, right? Let's see, F-16's (the most potent potential ground attack platform the Chinese possess), lugging weapons heavier than anything the F-16 has ever lugged, on a 3000 mile round trip, with aerial refueling being a bit of a problem (both because the Taiwanese have no current refueling capability, and because setting up a tanker track over the PRC proper might not be the most advisable course of action...). Requiring successive, multiple hits against the same exact point of impact...yeah, that's a real doable option! :-) Are you beginning to see why the idea of actually breaching the dam is sort of a non-starter in terms of realistic options? Brooks |
#39
"Kevin Brooks" wrote: Oh, a mere 1200 to 1400 miles up the Yangtze River, maybe 1500 miles from Taiwan; piece of cake, right? Let's see, F-16's (the most potent potential ground attack platform the Chinese possess), lugging weapons heavier than anything the F-16 has ever lugged, on a 3000 mile round trip, ....because nobody would ever send a number of planes on a one-way mission to destroy something that's a major part of the enemy's infrastructure, right? -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
#40
On Wed, 23 Jun 2004 19:16:32 GMT, Chad Irby wrote:
In article , "Kevin Brooks" wrote: Oh, a mere 1200 to 1400 miles up the Yangtze River, maybe 1500 miles from Taiwan; piece of cake, right? Let's see, F-16's (the most potent potential ground attack platform the Chinese possess), lugging weapons heavier than anything the F-16 has ever lugged, on a 3000 mile round trip, ...because nobody would ever send a number of planes on a one-way mission to destroy something that's a major part of the enemy's infrastructure, right? Would you send a large number of your best planes on a one way mission, knowng that teh air disparity would be even worse? And incidentally, ensuring that your own island would be attacked by every means possible. If the 3 gorges goes, I'm fairly sure the PRC would be less hesitant about turning Formosa into a floating heap of ash. Peter Kemp |
PING: Gordon (was: The torpedo high jump...) | Yeff | Military Aviation | 0 | June 10th 04 08:41 AM |
Taiwan to make parts for new Bell military helicopters | Otis Willie | Military Aviation | 0 | February 28th 04 12:12 AM |
realign M-750 to reduce noise in Taiwan | Dan Jacobson | Instrument Flight Rules | 0 | January 31st 04 01:44 AM |
US wants Taiwan to bolster intelligence gathering | Henry J. Cobb | Military Aviation | 0 | January 8th 04 02:00 PM |
monitoring China air communication with a radio in Taiwan | Dan Jacobson | Instrument Flight Rules | 0 | November 23rd 03 09:40 PM |
