First TSO-C199 "TABS" device
Old January 3rd 17, 08:56 PM posted to rec.aviation.soaring
Sarah[_2_]
Default First TSO-C199 "TABS" device
http://www.trig-avionics.com/new-tn7...at-flyer-live/
This should be available Q1 2017 - it's already popping up on aircraftSpruce & the like, at a sub- $400 price. Quite interesting for those of us with Trig transponders.
In the US, all airspace is "outside of designated ADS-B out airspace" for gliders. Or motorgliders I presume.
Old January 3rd 17, 10:29 PM posted to rec.aviation.soaring
Sarah[_2_]
I should clarify after some study of 91.225 for gliders.
http://www.ecfr.gov/cgi-bin/text-idx..._1225&rgn=div8
TABS is always voluntary.
After 2020 a TSO-C166b 1090es ADS-B out (not just TABS or UAT) will be required
- In class A, above FL180. Presumably IFR without a wave-window.
Either 1090es or UAT (but not TABS) is acceptable
- Inside class B or class C airspace, or within that lateral boundary above 10,000' MSL (or the airspace ceiling, whichever is lower.)
Otherwise as with a transponder today, ADSB-out of any kind will not be required within the class B "veil" or generally in controlled airspace between 10,000' and 18,000' MSL.
Whew!
Old January 3rd 17, 11:31 PM posted to rec.aviation.soaring
WaltWX[_2_]
Sarah,
Thanks for the explanation... but... I'm still confused. Try explaining it one more time.
It sounds like having TABS with your Trig in a glider will make you more visible to other aircraft who can track ADS-B out messages. The Mode S transponder already gives an equipped glider visibility to TCAS.
Now, in a Mode S equipped glider, I can request a clearance to enter Class A,B, C, or restricted airspace ... but in the future after 2020... will that clearance be denied UNLESS I have a TSO-C166B ADS-B out device? I would hope that FAA or ATC would allow clearances to enter/transit Class A,B,C and restricted airspace WITH a TABS device.
So, to me... this sounds like a very minimally beneficial upgrade to my Trig setup. I wonder... will TABS devices be visible to the satellite based ADS-B tracking service? If so, it might replace other satellite tracking devices like Spot and Delorme/Garmin InReach.
My two cents...
Walt Rogers WX
Whew!
Old January 4th 17, 12:11 AM posted to rec.aviation.soaring
Sarah[_2_]
Hi Walt,
Right. It would make you visible on all those GA ADSB-in devices & ipads. That's something. It should also make your position visible to powerflarm users, but I have not verified that.
That's how I read 91.225. I'd love to be corrected. If you really need to enter class A IFR, you'll need something much more expensive and harder to fit in a glider, a 1090es/TSO-C166 device. A TSO'd UAT is enough for class B or C. If you have an experimental glider non-TSO'd equipment is OK but you have to be careful.
https://www.faa.gov/nextgen/equipadsb/faq/#q4
I'm not an expert in these areas - see other posts on RAS or page Darryl Ramm.
One can always hope.
I don't know. I suspect they would be as visible as any other ADSB-out device, but I'm not certain.
Old January 4th 17, 01:56 AM posted to rec.aviation.soaring
jfitch
What are the consequences of having a Trig 21 vs 22, in both the TABS regulations and pure functionality? I understand that a Trig 21 may not meet TABS regulations, if there ever comes to be some. But will it actually function, if wired to the Trig TN72 source?
Old January 4th 17, 03:44 AM posted to rec.aviation.soaring
Richard[_9_]
Probably none. Except visits from the FCC & airport police.
I will have the TN72 in the first quarter of 2017 per the distributor.
Richard
www.craggyaero.com
Old January 4th 17, 03:56 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
On Tuesday, January 3, 2017 at 7:11:53 PM UTC-5, Sarah wrote:
Hi Walt,
The big advantage of having a TN72 coupled with a Trig transponder is that it will trigger the ADS-B ground stations to generate TIS-B and ADS-R broadcasts so that you can reliably see other aircraft if you are ADS-B IN equipped. Without an ADS-B OUT signal, you will not see any transponder equipped aircraft unless they are ADS-B OUT equipped, nor will you see ADS-B OUT equipped aircraft that are using a different frequency than your ADS-B receiver (not an issue if you have a dual frequency ADS-B receiver).
Old January 4th 17, 02:28 PM posted to rec.aviation.soaring
Renny[_2_]
I had inquired directly with Trig on the potential use of the TT21 and the TN72 and this was their response in a message back to me on Dec 7th...
"Thank you for your interest in our TN72 GPS receiver.
The TN72 is compatible with your TT21 transponder and is an ideal choice for your glider.
TABS exists to allow exempt aircraft like yours to participate in ADS-B.
Your TT21 transponder exceeds the technical requirements of TABS and so does not require upgrading.
The TN72 will be shipping in early 2017 and will be available through all Trig dealers."
Old January 4th 17, 02:46 PM posted to rec.aviation.soaring
Sarah[_2_]
I would think either would be fine. They are almost identical except in power output. There are actually no TABS regulations other than the TSO.
https://www.law.cornell.edu/cfr/text/14/91.227
goes on and on about UAT and TSO-166 specifications but doesn't mention TABS.
We will see when more information comes out of Trig. For instance - It would be really nice if the required antenna wasn't larger than the TN72 and more expensive.
Old January 4th 17, 04:34 PM posted to rec.aviation.soaring
Richard[_9_]
Available for preorder
http://www.craggyaero.com/nav_com.htm
First quarter of 2017
More information to follow on website
Richard
www.craggyaero.com
"Do It Yourself" airborne proximity warning device Linar Yusupov Soaring 101 September 2nd 19 02:41 AM
TABS Peter von Tresckow Soaring 1 March 11th 16 08:31 PM
5.7" Mirasol Android Device Craig Funston[_2_] Soaring 10 March 3rd 12 10:02 PM
Guitar Chords/Tabs for "Ridge Runner" [email protected] Soaring 3 November 20th 08 05:00 AM
"View Limiting Device" recommendations please [email protected] Instrument Flight Rules 27 February 4th 08 02:25 AM
