Benalla
Old January 14th 17, 11:10 AM posted to rec.aviation.soaring
RuudH
Default Benalla
Op donderdag 12 januari 2017 15:13:23 UTC+1 schreef krasw:
There was a mid-air collision in 18m class today. Both damaged gliders returned to airfield. Such routine is this at WGC level that it did not make news anywhere?
If you look at the score sheet, LK and HK were involved in this occurrence
I have put both igc files together in this GoogleEarth KML file https://dl.dropboxusercontent.com/u/...se4comfort.kmz
It looks like LK turned inside HK during thermalling
HK immediately returned in the direction of Benalla and landed on Baddaginnie (Earlston) airstrip.
LK initially continued the task and flew back a little bit later to Benalla.
This slide was shown during a safety briefing
https://dl.dropboxusercontent.com/u/...ng-wgc2017.jpg
  #52
Old January 14th 17, 12:32 PM posted to rec.aviation.soaring
Jock Proudfoot
Default Benalla
gliders
Matthew Scutter's Gliding
https://www.facebook.com/MatthewScut...fref=hovercard
  #53
Old January 14th 17, 02:29 PM posted to rec.aviation.soaring
Jim White[_3_]
Default Benalla
gliders
This the work of an ethics committee.
1) It is hard to argue that someone who gives up their race to assist
another pilot in mortal trouble isn't doing the right thing
2) It is also hard to argue that the organisation that decides to cancel
the race because said pilot gave up his race for noble reason and was so
disadvantaged isn't doing the right thing
yet note that the rules say that pilots involved in a mid air must suffer
a technical land out at that point. I was not present in this rule making
but presume that the reasoning is that this rule discourages pilots from
continuing in potentially lethally compromised gliders. It also has a
deterrent effect on rash pilot behaviour as the penalty is very high, even
if not to life and limb.
so
3) It is therefore possible to argue that the organisers who cancel the
task, remove the points downside to the pilots from unsafe flying and that
is wrong.
Better to find a way to reward the good shepherd for his proper and
humane decision?
Always controversial, not always correct
  #54
Old January 14th 17, 02:47 PM posted to rec.aviation.soaring
Rich Owen[_2_]
Default Benalla
Lol!!!!
  #55
Old January 14th 17, 03:10 PM posted to rec.aviation.soaring
Chris Rollings[_2_]
Default Benalla
gliders
eve
The rule was, I believe, introduced after a mid-air (in cloud) in a UK
Nationals in the late 1960's. One of the pilots flew on for about another
50 km with a couple of feet of wing missing.
so
tha
is wrong.
humane decision?
  #56
Old January 14th 17, 05:00 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Benalla
So I am confused. Matthew Scutter's FB post says both gliders crashed and both pilots safely bailed out. One glider spiraled in and the other looped all the way to ground. Other posts say one glider returned to Benalla and the other landed at another airport. Glad both are safe, terrible about the collision and loss of equipment.
The first mid-air the day before, I never did hear who was involved and level of damage, what class glider...
Stay safe down there guys and gal!
gliders
  #57
Old January 14th 17, 05:07 PM posted to rec.aviation.soaring
Renny[_2_]
Default Benalla
On Saturday, January 14, 2017 at 10:00:56 AM UTC-7, Jonathan St. Cloud wrote:
gliders
There is a bit more info here from John Good...
http://ussoaringteams.org/january-14th/
  #58
Old January 14th 17, 05:20 PM posted to rec.aviation.soaring
Tony[_5_]
Default Benalla
Two mid airs.
  #59
Old January 14th 17, 05:52 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Benalla
But to be fair, they did get a safety briefing after the first midair that included a slide about waving to other pilots as they enter a thermal.
On Saturday, January 14, 2017 at 9:20:18 AM UTC-8, Tony wrote:
Two mid airs.
  #60
Old January 14th 17, 11:03 PM posted to rec.aviation.soaring
JS
Default Benalla
Day 5 isn't canceled.
Not that high again. Clouds seem to be scarce.
15m has a 280k nominal task with two 25km circles.
18m has 279k nominal with two 30km circles.
Open is 283k nominal with a 10km and two 25km circles.
WGC 2017 - Benalla Renny[_2_] Soaring 6 October 26th 16 12:38 PM
