Bomb hits tailplane on release
Old June 22nd 04, 06:02 PM
Paul Housley
Default Bomb hits tailplane on release
Perhaps a bit of a random question for this newsgroup.
A while ago, I saw video footage of a bomb being released from a
fighter-bomber under test conditions. It was on an aviation
documentary. The high speed camera then shows it climb up and destroy
the tailplane. I don't think they quite got their trajectory calcs
right!
Has anyone seen this video? Does anyone know where I could get a copy.
Stills from it would be fine. It's for a uni project in case you were
wondering.
If not, anyone able to point me in the right direction of where to
ask?
Thanks for your help.
Paul.
Old June 22nd 04, 06:20 PM
Richard Brooks
right!
wondering.
This shows up towards the end of a documentary called Dambusters, which has
been seen on UKs Channel 4. I think I have a copy of it. It also shows
that the Germans were experimenting with much the same thing.
I shall have a look and see what I can do for you.
Richard.
Old June 22nd 04, 06:41 PM
W. D. Allen Sr.
This is a more common problem than people realize. Releasing a store in
flight from a bomb bay or from under wing is not a no-brainer.
The F-86 had instances when drop tanks went up over the leading edge of it's
wing when released under certain flight conditions. The Navy A-3D had
nuclear shapes hang in the bomb bay after release. A retractable "rake" was
mounted in front of the bomb bay to solve that problem. By the way, in WWII
it was not unheard-of for bombers in higher squadrons to drop their bomb
loads onto lower flying bombers.
WDA
end
"Paul Housley" wrote in message
om...
right!
wondering.
ask?
Paul.
Old June 22nd 04, 07:05 PM
Richard Brooks
right!
copy. Stills from it would be fine. It's for a uni project in case
you were wondering.
which has been seen on UKs Channel 4. I think I have a copy of it.
It also shows that the Germans were experimenting with much the same
thing.
Further to searching I find I've only got the BBC2 documentary which does
not go as in-depth but found this on a Web site.
" An American variant of Highball, codenamed Baseball, was also tested but
during one of the tests, the bomb rebounded and hit the dropping aircraft
causing it to crash, and the tests were stopped.
The URL;
http://www.computing.dundee.ac.uk/staff/irmurray/bigbounc.asp
I've put a call out in uk.media.tv.misc to see if anyone there has a copy
and will let you know.
Richard.
Old June 22nd 04, 07:14 PM
Robert Briggs
right!
The Lanc may have had guns, but that doesn't make it a fighter-bomber.
That said, without the "fighter-" qualification (and substituting
"damage" for "destroy"), the description does indeed suggest the old
Bouncing Bomb trials.
Old June 22nd 04, 07:21 PM
George Shirley
right!
you were wondering.
thing.
The URL;
Richard.
"Dambusters" was on US Discovery Wings channel again last night. IIRC
that story was told and they had a graphic but no picture. Again, aging
memories, even overnight are not always correct. VBG
George
Old June 22nd 04, 08:16 PM
Regnirps
right!
I have also seen something. A Fantom (?) or the like and two chase planes.
Debris or the bomb (missile?) also hits one of the chase planes and it is
destroyed. This was part of a series of accident studies including an F-16
landing with a wheel missing or locked up main gear. The guy ejects after the
F-16 safely comes to a stop, perhaps fearing a collapse and fire.
-- Charlie Springer
Old June 22nd 04, 09:58 PM
Ed Rasimus
right!
Modern aircraft employ "ejector" carts which propel the store away
from the rack using a small pyrotechnic charge and a "foot" or pusher.
Earlier aircraft simply used suspension hooks that opened to release
the weapon allowing it to fall away.
Higher speeds mean the store can generate lift (just like any curved
surface.) There were instances of jettisoned fuel tanks from F-105s
climbing as much as 3000 feet above the release aircraft.
Instability caused by a bent fin can also cause a pitch up moment on
release.
The film you recall was of an F-100 being chased by an F-105 at Eglin.
They were dropping early versions of the MLU-10B land mine. The mine
broached on impact with the ground from a 100' lay-down delivery and
rose up to hit the chasing aircraft. The weapon was inert, but the
impact still destroyed the chase and the pilot ejected.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
Smithsonian Institution Press
ISBN #1-58834-103-8
Old June 23rd 04, 02:26 AM
David E. Powell
"W. D. Allen Sr." wrote in message
it's
was
WWII
There is a film clip around of a B-24 Liberator having a bomb dropped from
above hit her wing root, destroying the plane. Horrible.
WDA
end
om...
right!
wondering.
ask?
Paul.
Old June 23rd 04, 03:34 AM
WaltBJ
Ed Rasimus wrote in message . ..
SNIP
SNIP:
The F105 was piloted by Fred Kyler, who was later my WingCo in the
36TFW at Bitburg. The F100F had a pilot and cameraman aboard. The
MLU10 detonated on ground impact and fragged both aircraft. All 3
ejected and landed okay. Col. Kyler had a great color photo hanging in
his office, taken from the ground, showing both aircraft as they
pulled up, starting to flame from the numerous frag hits. I should
imagine the ground cameraman got his ears blasted since he wasn't all
that far from the impact site.
Walt BJ
A BOMB PATTER IS LIKE A FOOTBALL ArtKramr Military Aviation 17 March 3rd 04 01:54 PM
Air Force announces small diameter bomb contract award Otis Willie Military Aviation 0 October 9th 03 09:52 PM
Air Force announces winner in Small Diameter Bomb competition Otis Willie Military Aviation 0 August 30th 03 03:06 AM
AIRCRAFT MUNITIONS - THE COBALT BOMB Garrison Hilliard Military Aviation 1 August 29th 03 09:22 AM
FORMATIONS, BOMB RUNS AND RADIUS OF ACTION ArtKramr Military Aviation 0 August 10th 03 02:22 AM
