Taking US registered Experimental Glider to Canada?
Old January 21st 17, 03:01 AM posted to rec.aviation.soaring
Paul Villinski
Default Taking US registered Experimental Glider to Canada?
Just as a "hypothetical," say one wanted to relocate to Canada for a period of, say, four years or so -- maybe eight, maybe permanently.... And one owns a glider registered in the Experimental, Racing and Exhibition Category. Are there issues bringing this along? Can it be flown there with US registration for a period, and/or, can it be registered in Canada?
Always good to have a Plan B.
Old January 21st 17, 03:09 PM posted to rec.aviation.soaring
George Haeh
As long as you don't move to Canada, you can operate your US registered
glider in Canada as long as you want. Once you become a permanent
resident, the limit is 90 days in the previous 12 months.
CAR 202.42 applies.
http://laws-lois.justice.gc.ca/eng/r...ns/sor-96-433/
Many US gliders registered experimental have Canadian type certificates;
which require an expensive type conformity inspection. Some mods may
have to be removed.
Be very careful who you use for this inspection. I know one owner who got a
$10,000 bill.
I used Fox One Corp the second time around. Very reasonable and Dave
knows what he's doing.
http://www.foxonecorp.com/index.php/...port-brokering
Watch out for taxes. You might get exempted under "settlers effects".
Normally you get stuck for 5% GST + provincial 8% give or take. Move to
Alberta where the provincial rate is 0%.
Then there's the trailer. If less than 15 years old, you get to deal with
Registrar of Imported Vehicles. That's just a couple hundred bucks provided
the trailer is eligible. Then you get to deal with the province to get a
plate.
Hint - move to Alberta.
Consider flying in Canada May, June, July and skedaddling the glider back
to
the US the rest of the year. That or figure out how long Canadian
Immigration
rules permit you to visit Canada in a year.
Mind you if you plan to work in Canada, you have to apply for permanent
residence.
Old January 21st 17, 09:55 PM posted to rec.aviation.soaring
Andrzej Kobus
Only if a glider is NOT registered in the US as experimental. If it is experimental you need TC approval.
CAR 202.42 applies.
have to be removed.
$10,000 bill.
plate.
to
Immigration
residence.
Old January 22nd 17, 03:02 AM posted to rec.aviation.soaring
Check your Experimental Operating Limitations..........my Sept, 1999 limits contain the following:
The owner/operator of this aircraft must obtain written permission from another country's Civil Airworthiness Authority (CAA) prior to operating this aircraft in or over that country. The written permission must be carried aboard.........
JJ
Old January 22nd 17, 03:45 AM posted to rec.aviation.soaring
Ben[_8_]
JJ
Did you all notice that the original posting vanished and the individual was thinking of a move for 4 or perhaps 8 years and it was posted on RAS on inauguration day in the US? What a truly amazing coincidence...I do believe this person should definitely be given the opportunity of moving to Canada.....
Old January 22nd 17, 04:53 AM posted to rec.aviation.soaring
Frank Whiteley
JJ
Only disappeared from Google Groups, not from nntp servers.
How to buy a US registered glider Matt Herron Jr. Soaring 33 January 10th 16 03:54 PM
Sensitive altimeter requirement for experimental registered glider? Gary[_9_] Soaring 1 September 22nd 12 01:26 AM
German registered glider maintenance: help with LBA doc needed Ludovic Launer[_2_] Soaring 3 July 19th 08 10:43 AM
Flying to Canada in experimental abripl Home Built 2 December 25th 06 07:53 PM
Approval to fly Experimental over Canada Ted Timmons Home Built 1 March 11th 05 02:46 AM
