Aerobatic Two Seat Gliders?
Old January 23rd 17, 01:29 AM posted to rec.aviation.soaring
Papa3[_2_]
Default Aerobatic Two Seat Gliders?
We used to have a KR-03 in the fleet where I did commercial rides. VNE is (from memory) not much over 100kts. Very easy to exceed that in any sort of botched maneuver. I did some dual aerobatic instruction in a Blanik L-13AC, which was actually quite nice. Better roll rate than the Grob 103 and a relatively decent VNE. Spins nicely.
The type certificate data sheets and AD history for all of the gliders you've listed are available online. I'd spend some time going through those as well as online copies of POHs. Especially if you are planning to take others up, it would be nice if you were operating within the current limitations. For example, Service Bulletin SA-003 prohibits aerobatics in Schweizer gliders overriding the POH (answering the question about an SGS-2-32).
Old January 23rd 17, 06:09 AM
Eurofighter Eurofighter is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
The IS28B2 is well within your budget. It might suit your needs.
Old January 23rd 17, 10:10 AM posted to rec.aviation.soaring
Bruce Hoult
Yes, Blaniks are very manoeuvrable. We did a lot of aero in them back in the 80s. I'd be more worried now about whether they are as strong as they should be! They're pretty draggy and will lose energy and height quicker than the glass gliders. But on the other hand you've got to work REALLY hard to get them to 135 knots! Seriously nose down. And the brakes limit you to about 120 knots even in a vertical dive.
Old January 23rd 17, 04:19 PM posted to rec.aviation.soaring
Papa3[_2_]
Bruce,
The L-13AC is a different aircraft. It's more of an L-23 but shortened wings, no flaps, and new empennage optimized for aerobatics. Good compromise between maneuverability without being too slick for newbies.
P3
Old January 23rd 17, 05:19 PM posted to rec.aviation.soaring
Bruce Hoult
On Monday, January 23, 2017 at 7:19:58 PM UTC+3, Papa3 wrote:
Bruce,
Ahh, missed that. Thanks.
Old January 23rd 17, 08:44 PM posted to rec.aviation.soaring
"Service Bulletin SA-003 prohibits aerobatics in Schweizer gliders overriding the POH (answering the question about an SGS-2-32)."
Actually, legally it doesn't. A service bulletin or note or advisory about an aircraft cannot override the approved flight manual or type certificate of an aircraft operated under the aegis of the FAA (Unless it was an alert service bulletin issued in order to get information out quickly while an AD is being processed - it wasn't an alert service bulletin). For it to be legally binding they would have to get an airworthiness directive issued. They did not do this. Not to long ago one of the engine manufacturers tried this sort of tactic and got in a bit of trouble. Whether its a good idea to do aerobatics in a 2-32 being flown in the utility category is a different matter and one I don't have an opinion on seeing as how I've never flown one or worked on one.
You can get a Grob Twin Astir or Twin II for a reasonable amount of money but unless you can find a Twin II Acro which has had the rear fuselage strengthening modification you won't have a glider approved for inverted flight or slow rolls.
Old January 24th 17, 01:39 AM posted to rec.aviation.soaring
SoaringXCellence
Eurofighter
one for sale on W&W for $24K, in Oregon.
Old January 24th 17, 03:35 PM posted to rec.aviation.soaring
Eric Munk
The Twin Astir is according to the FM approved for simple aerobatics only
(loops, stall turn, lazy 8, chandelle, spin).
overridi=
about
certificate
alert
AD=
le=
The=
th=
d=
m=
one=
or worked on one.
b=
stren=
flight
or slow rolls.
Old January 24th 17, 04:07 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 24 janvier 2017 16:45:06 UTC+1, Eric Munk a écritÂ*:
The Twin 1 is full aerobatics (but I don't know about flick rolls).
Old January 26th 17, 05:32 AM posted to rec.aviation.soaring
No, it's not. Simple aerobatics only: loop, stall turn, spin, chandelle.
Parachute use in single seat gliders [email protected] Soaring 13 May 20th 16 04:14 PM
AD note for G-103, Grob two seat gliders Robert M Soaring 13 November 3rd 15 04:45 AM
two seat motor gliders, feedback. John Firth Soaring 6 March 2nd 05 03:45 AM
Two seat self launch aerobatic glider Waduino Soaring 2 January 6th 05 06:51 PM
Commercial - New Data Splitter for 2-Seat Gliders John Giddy Soaring 3 September 17th 03 06:01 AM
