Reachable landing sites in iGlide
Old February 7th 17, 12:17 AM posted to rec.aviation.soaring
MNLou
Default Reachable landing sites in iGlide
You might want to think twice about that Dan.
The Oudie with See You Mobile software has a much bigger base of users.
I love mine.
Lou
Old February 7th 17, 12:52 AM posted to rec.aviation.soaring
jfitch
On Monday, February 6, 2017 at 4:17:27 PM UTC-8, Casey wrote:
If you are going with iGlide, be aware that many of the configurable features are hidden in the xml files of the app. They are easily editable, but iGlide has no published documentation for them. Also, to get routes, you need the Adv version, and to get configurable turn points for racing, you need the pro version. If you need assistance email me and I will try to help..
In my opinion (remember, everyone has one...) iGlide is far easier to use than SYM - or any of the others. I own and have flown extensively with XCSoar, SYM, and Winpilot, often 2 at a time.
I like iGlide but I keep having to reinstall "Aeronautical Data", "Map Data", "Flight Parameters", and "Flight Recorder" information. Airglide said its because I do not have enough memory remaining on phone, but I'm wondering if anyone else has had this problem.
I have not had to replace the files, except after certain iOS updates. There have been two that have wiped one or more of the data files that iGlide uses, while perhaps 10 or 12 others have not. I don't know why the difference. I do have sufficient memory left. I am running it in two phones, a 5s and a 6 Plus. It is possible to back up and reinstall the files from iTunes without having to download them again if this happens. The only ones that are very large are the terrain maps, and they are very large indeed.
Old February 7th 17, 01:31 AM posted to rec.aviation.soaring
Casey[_2_]
I believe the one time I had to reinstall data files was due to an iOS update. And I belive the clearing of data from parameters and map data is from storage availability. I have too many apps and photos and sometimes forget about adding more photos.
Old February 7th 17, 03:49 AM posted to rec.aviation.soaring
JS
It might sound completely crazy, but how about using a dedicated device in the glider?
Old February 7th 17, 06:02 AM posted to rec.aviation.soaring
jfitch
I do. An iPhone 6 Plus.
Old February 7th 17, 05:36 PM posted to rec.aviation.soaring
Dan Marotta
snip
/snip
What a concept! Considering you can now find a Dell Streak 5 on eBay
for under $50 (I've seen them as low as $15), and it's daylight
readable, and XCSoar is free and doesn't do all the bad things I'm
reading about iGlide, and it's continually maintained and updated, and
it has a nearly 200 page user's manual... Then you can turn off your
phone so that, should you land or bail out, you'll have a charged phone
to call for help. Maybe not so crazy...
Dan, 5J
Old February 7th 17, 06:03 PM posted to rec.aviation.soaring
Dan
I am not a computer geek so am a bit concerned that xcsoar has no parents....
Did you/do you have any problems with support ?
Dan
On Tuesday, February 7, 2017 at 12:36:51 PM UTC-5, Dan Marotta wrote:
snip
/snip
Dan, 5J
Old February 7th 17, 06:44 PM posted to rec.aviation.soaring
If I use an iPhone 6 plus and not upgrade the OS (it's and old phone ?) I shouldn't have these problems ? it's a question and a wish as well...
Dan
Dan Marotta
XCSoar is an open source program with programmers around the world.
There's also a user forum and a facility to log problems which are then
fixed and updates released on the Google Play Store. On the very rare
occasion when I've had a problem, it's been quickly addressed and
usually was my fault. A quick look in the user manual usually has the
answer. Go to https://xcsoar.org/ and have a look around. There's no
obligation.
I'm not associated with them in any way, but I have used the program for
the past 5 years and have been very impressed with it.
Dan
On 2/7/2017 11:03 AM, wrote:
Dan
Dan
snip
/snip
Dan, 5J
Dan, 5J
Old February 7th 17, 07:26 PM posted to rec.aviation.soaring
Craig Funston
obligation.
Dan
Dan
Dan
snip
/snip
Dan, 5J
Dan, 5J
Dan, what are all the "bad things" you're reading about iGlide?
Just curious
Craig
7Q
iGlide Ben S Soaring 31 February 16th 20 04:14 AM
iGlide runner4065 Soaring 19 March 28th 16 11:12 PM
Iglide chris johnson Soaring 2 August 1st 15 03:22 PM
iGlide Mike Rinaldi Soaring 4 April 28th 15 12:48 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
