Focke-Wulf Fw 190
Old June 28th 16, 03:05 PM posted to alt.binaries.pictures.aviation
Miloch
Default Focke-Wulf Fw 190
https://en.wikipedia.org/wiki/Focke-Wulf_Fw_190
The Focke-Wulf Fw 190 Würger (English: Shrike) is a German single-seat,
single-engine fighter aircraft designed by Kurt Tank in the late 1930s and
widely used during World War II. Along with its well-known counterpart, the
Messerschmitt Bf 109, the Fw 190 became the backbone of the Luftwaffe's
Jagdwaffe (Fighter Force). The twin-row BMW 801 radial engine that powered most
operational versions enabled the Fw 190 to lift larger loads than the Bf 109,
allowing its use as a day fighter, fighter-bomber, ground-attack aircraft and,
to a lesser degree, night fighter.
The Fw 190A started flying operationally over France in August 1941, and quickly
proved superior in all but turn radius to the Royal Air Force's main front-line
fighter, the Spitfire Mk. V,[3] especially at low and medium altitudes. The 190
maintained superiority over Allied fighters until the introduction of the
improved Spitfire Mk. IX.[4] In November/December 1942, the Fw 190 made its air
combat debut on the Eastern Front, finding much success in fighter wings and
specialised ground attack units called Schlachtgeschwader (Battle Wings or
Strike Wings) from October 1943 onwards. In the opinion of German pilots who
flew both the Bf 109 and the Fw 190, the latter provided increased firepower
and, at low to medium altitude, manoeuvrability.
The Fw 190A series' performance decreased at high altitudes (usually 6,000 m
(20,000 ft) and above), which reduced its effectiveness as a high-altitude
interceptor. From the Fw 190's inception, there had been ongoing efforts to
address this with a turbosupercharged BMW 801 in the B model, the C model with
the Daimler-Benz DB 603, and the D model with the Junkers Jumo 213. Problems
with the turbos meant only the D model would see service, entering service in
September 1944. While these "long nose" versions gave them parity with Allied
opponents, it arrived far too late in the war to have any real effect.
Specifications (Fw 190 A-8)
General characteristics
Crew: 1
Length: 9.00 m (29 ft 5 in)
Wingspan: 10.51 m (34 ft 5 in)
Height: 3.95 m (12 ft 12 in)
Wing area: 18.30 m² (196.99 ft²)
Empty weight: 3,200 kg (7,060 lb)
Loaded weight: 4,417 kg (9,735 lb)
Max. takeoff weight: 4,900 kg (10,800 lb)
Powerplant: 1 × BMW 801 D-2 radial engine, 1,250 kW (1,700 PS, 1,677 hp)
Performance
Maximum speed: 656 km/h (408 mph) at 19,420 ft (5,920 m)
Range: 800 km (500 mi)
Service ceiling: 11,410 m (37,430 ft)
Rate of climb: 15 m/s (2,953 ft/min)
Wing loading: 241 kg/m² (49.4 lb/ft²)
Power/mass: 0.29-0.33 kW/kg (0.18-0.21 hp/lb)
Armament
Guns:
2 × 13 mm (.51 in) synchronized MG 131 machine guns with 475 rpg
4 × 20 mm MG 151/20 E cannon with 250 rpg, synchronized in the wing roots and
140 rpg free-firing outboard in mid-wing mounts.
Specifications (Fw 190 D-9)
Crew: 1
Length: 10.20 m (33 ft 5½ in)
Wingspan: 10.50 m (34 ft 5 in)
Height: 3.35 m (11 ft 0 in)
Empty weight: 3,490 kg (7,694 lb)
Loaded weight: 4,270 kg (9,413 lb)
Max. takeoff weight: 4,840 kg (10,670 lb)
Powerplant: 1 × Junkers Jumo 213A 12-cylinder inverted-Vee piston engine, 1,287
kW (1,750 PS, 1,726 hp) or 1,508 kW (2,050 PS, 2,022 hp) with boost (model 213E)
Performance
Maximum speed: 685 km/h (426 mph) at 6,600 m (21,655 ft), 710 km/h (440 mph) at
11,000 m (36,000 ft)
Range: 835 km (519 mi)
Service ceiling: 12,000 m (39,370 ft)
Rate of climb: 17 m/s (3,300 ft/min)
Wing loading: 233 kg/m² (47.7 lb/ft²)
Power/mass: 0.30–0.35 kW/kg (0.18–0.22 hp/lb)
Armament
Guns: (all synchronized to fire through propeller arc)
2 × 13 mm (.51 in) MG 131 machine guns with 475 rpg
2 × 20 mm MG 151 cannons with 250 rpg in the wing root
Bombs: 1 × 500 kg (1,102 lb) SC 500 bomb (optional)
Old June 28th 16, 03:17 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
On 2016-06-28 14:05:02 +0000, Miloch said:
Here is one of my shots taken at Paso Robles.
Regards,
Savageduck
Click image for larger version
Old June 28th 16, 04:22 PM posted to alt.binaries.pictures.aviation
Miloch
In article 2016062807172345813-savageduck1@REMOVESPAMmecom, Savageduck says...
This is a multi-part message in MIME format.
I see you're using a Nikon D300S...I have a Nikon CoolPix 630S (heh) and try
shooting airplanes whenever I see them. Yup...I see a plane's contrail at
30,000 feet and I'm trying to get a 'good' shot of it with my pocket camera and
its telephoto cranked all the way out!
Of course a CoolPix wasn't made for that but I keep on trying.
Spectacular shot! A testament to the camera and especially you the
photographer.
I make the assumption you were using a telephoto lens...about how high up and
far away was the plane?
Old June 28th 16, 05:01 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
Savageduck says...
photographer.
Thanks.
Yup! I was using a Nikkor 70-300mm. It was making a high speed, low
level pass at ±800ft. For that shot the range was 400-500 yds.
This was earlier in the approach for that pass when they were about
1000 yds out on the other side of the airport.
It was a good day for shooting warbirds, and they cooperated with some
good low passes with P-51's, P-38L, B-25 and others.
Regards,
Savageduck
Old June 28th 16, 05:28 PM posted to alt.binaries.pictures.aviation
Savageduck[_3_]
Savageduck says...
photographer.
Thanks.
....and then there was on the ground taxiing.
Regards,
Savageduck
Old June 29th 16, 07:25 AM posted to alt.binaries.pictures.aviation
Bob (not my real pseudonym)[_2_]
The only flightworthy original FW 190A - complete with BMW 801 engine
- owned by the Flying Heritage Collection in WA State. Rescued from a
Russian swamp in the 1980s.
Name:	Fw 190A-5  N19027  Flying Heritage Collection  PAE  8-6-11  133.jpg
Old June 29th 16, 07:26 AM posted to alt.binaries.pictures.aviation
Name:	Fw 190A-5  N19027  Flying Heritage Collection  PAE  8-6-11  165.jpg
Old June 29th 16, 07:28 AM posted to alt.binaries.pictures.aviation
Seen here with the FHC's Bf 109E, found on a French beach.
Name:	Fw 190A-5  N19027, Bf 109E  N342FH  Flying Heritage Collection  PAE  8-6-11  019.jpg
Cockpits 8 - Focke-Wulf Fw 190 b.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 May 25th 15 12:53 PM
Cockpits 7 - Focke-Wulf Fw 190 a.jpg (1/1) Mitchell Holman[_8_] Aviation Photos 0 May 24th 15 02:00 PM
Hamilton Air Show Batch 4 [12/31] - Focke Wulf Fw-190-4.jpg (1/1) Indrek[_6_] Aviation Photos 0 June 25th 13 02:44 AM
focke wulf ta 283 1944 fox[_2_] Aviation Photos 0 March 17th 10 06:38 PM
Focke Wulf, Falcon Wing??? James Dandy Military Aviation 14 January 13th 04 11:23 PM
