Do you crab or forward slip in X wind landings
Old February 25th 17, 10:03 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Do you crab or forward slip in X wind landings
Do you crab or forward slip landing in x-winds and why? When I was taught how to fly an airplane the crab method was used when I transitioned to gliders my instructor emphasized forward slip over crab. Years later I have established my procedures, but I thought this might be a useful discussion for newer pilots.
Old February 25th 17, 10:27 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Standard UK training, at least when I learnt and I haven't heard any
different from our instructors since, is to crab with wings level on
approach and kick the glider straight just before touchdown. Another
point is that we are taught to do fully held-off landings regardless of
the size and surface of the club field on the grounds that its the only
sensible way to land out, so we should be able to do it well. I think the
two are related because this keeps the wings level while speed bleeds off
and its fairly easy to kick the glider straight as it settles. If you
also manage a neat two-pointer you can award yourself brownie points as
well as knowing that this will help to keep the glider running straight
despite any cross-wind.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 25th 17, 11:00 PM posted to rec.aviation.soaring
Tango Eight
org |
What two seater is being used to teach fully held off landings?
-Evan
Old February 25th 17, 11:01 PM posted to rec.aviation.soaring
Jonathan St. Cloud
One comment on the crab method, you must transition to forward slip before touchdown. What if when you if you go to kick out the crab, just above runway and you find out that the x-wind is too strong for a forward slip to maintain track.
org |
Old February 26th 17, 12:46 AM posted to rec.aviation.soaring
If I do the crab+held-off landing properly, I should be under 3 ft up (at
the very most: half that is better) and already sinking when I kick the
glider straight. If you're too early straightening up, of course you're
being blown sideways when you land.
AFAIK the upwind wing low technique you guys call 'forward slip' isn't
taught to UK glider pilots. I was never taught it and can't recall seeing
anybody using it on our field.
org |
Old February 26th 17, 12:52 AM posted to rec.aviation.soaring
crab.
might
the two are related because this keeps the wings level while speed
bleeds off and its fairly easy to kick the glider straight as it
settles. If you also manage a neat two-pointer you can award yourself
brownie points as well as knowing that this will help to keep the
glider running straight despite any cross-wind.
martin@ | Martin Gregorie gregorie. | Essex, UK org |
In my club, all of our trainers. We have a couple of ASK-21s, a Puchacz
and a G103 Twin Acro 2.
org |
Old February 26th 17, 01:13 AM posted to rec.aviation.soaring
Jim[_33_]
On Saturday, February 25, 2017 at 1:04:02 PM UTC-8, Jonathan St. Cloud wrote:
Wouldn't that be a "side slip" since the glider's fuselage is aligned with the runway (hopefully) while the windward wing is a little low?
On Saturday, February 25, 2017 at 4:04:02 PM UTC-5, Jonathan St. Cloud wrote:
I have found over the years that students have a much easier time dealing with cross wind using the slip method.
The aiming point does not change. They look right over the nose as usual.
They do not have to try to kick out a crab and move to a wing low attitude while trying to time the round out to a low energy landing.
Obviously they nee to be aware of their bank angle near the ground but the reduced drift down low seems to take care of that.
UH
Old February 26th 17, 03:27 AM posted to rec.aviation.soaring
Matt Herron Jr.
slip will bleed off more energy than a crab. If you are low, a crab would be better. I tend to use slip as you can keep lined up on the approach and it is easy to adjust the slip for wind shear.
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 08:23 PM
Crab, slips, and crossed controls Amine Piloting 190 September 27th 08 08:59 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 10:35 PM
video of cross-wind landings jbaloun Home Built 0 June 2nd 06 02:56 AM
Got some neeed help with cross-wind landings... Ekim Piloting 13 October 23rd 04 05:40 PM
