Wanted Axel for Grob 103 Tail Wheel
Old March 7th 17, 12:52 PM posted to rec.aviation.soaring
Default Wanted Axel for Grob 103 Tail Wheel
Does anyone have an axel they are willing to sell for a Grob 103 Tail wheel?
Thanks,
Tim Hanke
Adirondack Soaring
Saratoga Springs, NY USA
Old March 7th 17, 04:03 PM posted to rec.aviation.soaring
Dan Marotta
Is it a special part?
When I recently replaced my solid aluminum tail wheel with a split brass
wheel, I learned that the wheel (on my glider, at least) is supported by
machined bushings on either side and a standard 12mm bolt through the
center.
Thanks,
Tim Hanke
Adirondack Soaring
Dan, 5J
Old March 8th 17, 01:36 AM posted to rec.aviation.soaring
Thanks,
Tim Hanke
Adirondack Soaring
Tim,
We had a similar issue last year wit our G103. I believe the solution was found by going out and having someone manufacturing a replacement that worked with the 12 mm bolt. I can get details if you are interested.
-Brian
Caesar Creek Soaring Club
ASW 19 tail wheel [email protected] Soaring 13 September 20th 16 11:09 PM
Grob Twin Astir I pneumatic tail wheel conversion kit Robert Dunning Soaring 0 March 28th 13 02:34 PM
Grob 103 Tail Dolly Roger Fowler[_2_] Soaring 3 September 1st 10 02:21 AM
Wanted: Tail Dolly for Grob 102 Club III Mitch Deutsch Soaring 2 May 4th 10 09:05 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
