https://en.wikipedia.org/wiki/Avro_Lancaster
The Avro Lancaster is a British four-engined Second World War heavy bomber designed and built by Avro for the Royal Air Force (RAF). It first saw active service with RAF Bomber Command in 1942 and, as the strategic bombing offensive over Europe gathered momentum, it was the central implement for the night-time bombing campaigns that followed. It became the main heavy bomber used by the RAF, the RCAF, and squadrons from other Commonwealth and European countries serving within the RAF, overshadowing its close contemporaries the Handley Page Halifax and Short Stirling. The "Lanc", as it was affectionately known, thus became one of the more famous and most successful of the Second World War night bombers, "delivering 608,612 long tons of bombs in 156,000 sorties." The Lancaster, an evolution of the troublesome Avro Manchester, was designed by Roy Chadwick and was powered by four Rolls-Royce Merlins, or, in one version, Bristol Hercules engines. A long, unobstructed bomb bay meant that the Lancaster could take the largest bombs used by the RAF, including the 4,000 lb (1,800 kg), 8,000 lb (3,600 kg), and 12,000 lb (5,400 kg) blockbusters, loads often supplemented with smaller bombs or incendiaries. The versatility of the Lancaster was such that it was chosen to equip 617 Squadron and was modified to carry the Upkeep "Bouncing bomb" designed by Barnes Wallis for Operation Chastise, the attack on Germany Ruhr Valley dams. Although the Lancaster was primarily a night bomber, it excelled in many other roles, including daylight precision bombing: in the latter role some Lancasters were adapted to carry the 12,000 lb (5,400 kg) Tallboy and then the 22,000 lb (10,000 kg) Grand Slam earthquake bombs (also designed by Wallis). Role Heavy bomber Manufacturer Avro Designer Roy Chadwick First flight 9 January 1941 Introduction February 1942 Retired 1963 (Canada) Primary users Royal Air Force Royal Canadian Air Force Royal Australian Air Force Number built 7,377 Unit cost £45–50,000 Developed from Avro Manchester Variants Avro Lancastrian Developed into Avro York Avro Lincoln The first RAF squadron to convert to the Lancaster was No. 44 Squadron RAF in early 1942. Lancasters flew 156,000 sorties and dropped 608,612 long tons (618,378 tonnes) of bombs between 1942 and 1945. Lancasters were the mainstay of British heavy bombers from 1942 until the introduction of the Lincoln in large numbers, post-Second World War. Just 35 Lancasters completed more than 100 successful operations each, and 3,249 were lost in action. The most successful survivor completed 139 operations, and was scrapped in 1947. Specifications (Lancaster I) General characteristics Crew: 7: pilot, flight engineer, navigator, bomb aimer/nose gunner, wireless operator, mid-upper and rear gunners Length: 69 ft 4 in (21.11 m) Wingspan: 102 ft 0 in (31.09 m) Height: 20 ft 6 in (6.25 m) Wing area: 1,297 sq ft (120.5 m²) Empty weight: 36,457 lb (16,571 kg) Loaded weight: 68,000 lb (30,909 kg) [46] Max. takeoff weight: 72,000 lb (32,727 kg) with 22,000 lb (10,000 kg) bomb Powerplant: 4 × Rolls-Royce Merlin XX liquid-cooled V12 engines, 1,280 hp (954 kW) each Performance Maximum speed: 282 mph (246 knots, 454 km/h) at 63,000 lb (29,000 kg) and 13,000 ft (4,000 m) altitude [40] Cruise speed: 200 mph (174 knots, 322 km/h) Range: 2,530 mi (2,200 nmi, 4,073 km) Service ceiling: 21,400 ft (6,500 m) at 63,000 lb (29,000 kg)[40] () Rate of climb: 720 ft/min (3.7 m/s) at 63,000 lb (29,000 kg) and 9,200 ft (2,800 m) altitude[40] () Armament Guns: 2 Browning .303 Mark II machine guns in nose turret, 2 Browning .303 Mark II machine guns in upper turret, and 4 Browning .303 Mark II machine guns in the rear turret. Bombs: Maximum normal bomb load of 14,000 lb (6,350 kg) or 22,000 lb (9,979 kg) Grand Slam with modifications to bomb bay * |
| UK2 VB873 Avro Lancastrian ex RAF PD140 Avro Lancaster to G-AGLF.jpg | Joseph Testagrose | Aviation Photos | 0 | October 3rd 12 02:49 PM |
| UK2 PD140 Avro Lancaster to RAF VB873 Avro Lancastrian to G-AGLF IanJohnsonColl.jpg | Joseph Testagrose | Aviation Photos | 0 | October 2nd 12 02:36 PM |
| Avro Lancaster - Cutaway Lancaster.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 0 | January 27th 08 01:42 PM |
| Avro Lancaster - Avro Manchester Mk 1 e.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 0 | January 27th 08 01:42 PM |
| Avro Lancaster - Avro Manchester Mk 1 d.jpg (1/1) | Mitchell Holman[_2_] | Aviation Photos | 0 | January 27th 08 01:42 PM |
