SkySight forecast available for SW USA
Old March 16th 17, 09:19 PM posted to rec.aviation.soaring
Default SkySight forecast available for SW USA
On Friday, 17 March 2017 01:43:28 UTC+10:30, Tom BravoMike wrote:
Get to know Matthew Scutter on YouTube:
https://youtu.be/htANHB-L_zI
Matthew, I like your approach to gliding and especially the thorough preparation ahead of planned flights.
Tom BravoMike
I also have videos on how I use SkySight.io to plan a task around the weather, see below:
https://www.youtube.com/watch?v=8RIN0086LzY
Old March 18th 17, 02:03 AM posted to rec.aviation.soaring
I have had a number of queries offlist about SkySight's coverage - we cover almost all of the US now, barring an area around North Dakota/Minnesota.
Coverage will be extended there too if demand exists.
Tom BravoMike
Old March 19th 17, 05:20 AM posted to rec.aviation.soaring
Mike C
Tom BravoMike
Today in Moriarty the GFS forecast was the most accurate
Old April 22nd 17, 12:31 AM posted to rec.aviation.soaring
Kurt Thams
One of the features from Dr. Jack that I like but is missing from XCSkies is CU Potential.
Does Skysight have that?
I find it useful because just having "yes / no" to cumulus isn't nearly as informative as the likelihood of them.
Old April 22nd 17, 04:31 AM posted to rec.aviation.soaring
JS
Kurt et al:
Skysight has the following regarding cloud potential.
Boundary Layer Cloud Cover
Low Level Cloud Cover (up to FL130)
Mid Level Cloud Cover (FL130 - 330)
High Level Cloud Cover (FL330 up)
Old April 22nd 17, 10:30 AM posted to rec.aviation.soaring
Hi Kurt,
Yes it does, and SkySight calls this "Cu Depth". The concept is identical.
Cheers,
Matthew
Old April 22nd 17, 12:33 PM posted to rec.aviation.soaring
Hi Kurt,
Cheers,
Matthew
I would like to add that the convergence forecast on skysight is very good. Certainly helped in my last flight.
Thanks Matthew.
Best Regards,
Daniel
Dr Jack forecast high too low [email protected] Soaring 6 February 21st 17 06:40 PM
Flying through known or forecast icing John Doe Instrument Flight Rules 76 December 20th 05 08:01 AM
Flying through known or forecast icing John Doe Piloting 67 December 17th 05 01:20 PM
Translate WX Forecast John T Piloting 34 August 5th 05 02:28 PM
Help, Need Wave forecast Kevin R. Anderson Soaring 2 March 1st 04 06:26 PM
