On 26 Jul 2016 18:09:33 -0700, Miloch
wrote: This one sure must have an interesting accident report. Dave: Old age comes at an inconventient time But- the more birthdays you have, the longer you live |
Old Geezerr wrote in
: On 26 Jul 2016 18:09:33 -0700, Miloch wrote: This one sure must have an interesting accident report. Dave: NTSB Identification: ERA09FA283 14 CFR Part 91: General Aviation Accident occurred Wednesday, May 06, 2009 in Lantana, FL Probable Cause Approval Date: 08/12/2010 Aircraft: BEECH K35, registration: N111YR Injuries: 2 Fatal. NTSB investigators either traveled in support of this investigation or conducted a significant amount of investigative work without any travel, and used data obtained from various sources to prepare this aircraft accident report. According to witnesses, during the initial climb after takeoff and as the airplane reached an altitude of 75 to 100 feet above the ground, the engine ran rough momentarily and then lost power. The airplane entered a right descending turn back toward the airport, where it struck two parked, unoccupied airplanes before impacting the ground and colliding with a tractor-trailer container. Subsequent inspection of the engine revealed that the idler gear support pin was backed-off from its proper mounting position. In addition, the two mounting studs did not contain any mounting hardware, and their respective threads were undamaged. A review of maintenance records revealed that the airplane had been operated for about 2 hours since the engine was disassembled for "extensive engine repair due to spalled cam and lifter bodies," about 5 months prior to the accident, and since its most recent annual inspection, which was performed about 1 month prior to the accident. An engine test run that was conducted after the idler gear support pin was properly installed did not reveal any other engine anomalies. The National Transportation Safety Board determines the probable cause(s) of this accident as follows: A total loss of engine power due to disengagement of the idler gear support pin as a result of improper maintenance. |
Beechcraft Bonanza pics [15/21] - Beechcraft Bonanza Cockpit.jpg (2/2) | Miloch | Aviation Photos | 0 | July 27th 16 02:09 AM |
Beechcraft Bonanza pics [11/21] - Beech-Bonanza-V35-V-Tail-N555BC.jpg (1/1) | Miloch | Aviation Photos | 0 | July 27th 16 02:09 AM |
Beechcraft Bonanza pics [10/21] - Beech-Bonanza-V35_.jpg (1/1) | Miloch | Aviation Photos | 0 | July 27th 16 02:09 AM |
Beechcraft Bonanza pics [06/21] - beech-35-bonanza-03.jpg (1/1) | Miloch | Aviation Photos | 0 | July 27th 16 02:09 AM |
Beechcraft Bonanza pics [05/21] - beech-35-bonanza-01.jpg (1/1) | Miloch | Aviation Photos | 0 | July 27th 16 02:09 AM |
