Air scoop popping open at high speed
Old March 27th 17, 10:45 PM posted to rec.aviation.soaring
Matt Herron Jr.
Default Air scoop popping open at high speed
This weekend I did a high speed run to test some new seals I had installed on the rudder for vibration. VNE is 147 Kts in the Ventus, and so I only took it up to 130 kts IAS (yes I was only at 2000 ft MSL, so altitude was not a factor). At that speed the air scoop on the sliding canopy window suddenly popped open and scared the hell out of me with the sudden noise and rush of air.
Anyone have this happen, and is there a way to fix it?
Thanks for any suggestions.
Old March 27th 17, 11:07 PM posted to rec.aviation.soaring
JS
Yes, both vent windows at the same time giving a ride in a DG1000.
Install a cockpit extractor vent.
Old March 28th 17, 12:39 AM posted to rec.aviation.soaring
Agreed, the OP needs a better way to vent air out. Doing the rear seals allow the vent to pressurize the interior which blew the side vent open since it can't escape through the rudder hinge.
Or, close the front vent and don't fix the exit issue.
Old March 28th 17, 12:45 AM posted to rec.aviation.soaring
Matt Herron Jr.
Old March 28th 17, 03:17 AM posted to rec.aviation.soaring
Karl Striedieck[_2_]
Tighten the pivot bolt.
Old March 28th 17, 03:25 AM posted to rec.aviation.soaring
Dan Marotta
What KS said. There's a screw and nut about which the vent scoop
rotates. Tighten that until you're happy with the stiffness of opening
the window. Don't tighten it so much that you break the window.
Dan, 5J
Old March 28th 17, 03:59 AM posted to rec.aviation.soaring
MNLou
I have the same issue when I fire up the sustainer engine on my LAK17at. Don't know why.
During normal flight, never an issue - at any speed. Start the motor and, boom, the side vent flies open. This is flying at 51 kts.
I'll try closing the front vent the next time and see if that helps.
Lou
Old March 28th 17, 08:48 AM posted to rec.aviation.soaring
Ramy[_2_]
You probably sealed your canopy too well...
Ramy
Old March 28th 17, 02:40 PM posted to rec.aviation.soaring
A small piece of tape on the exterior of the scoop is a quick/temp fix that can be done in flight and removed in flight (for the window next to a person). I do this for extended hi-speed ridge flying.
Old March 28th 17, 05:57 PM posted to rec.aviation.soaring
Dan Marotta
That's the "Auto-Vent System" designed to keep you from choking on
gas/oil fumes... :-D I'll bet that doesn't happen with Renny's LAK-17bfes.
Lou
Dan, 5J
F/A-18 High Speed Pass Glen in Orlando[_3_] Aviation Photos 0 September 24th 11 04:57 AM
B-1 High Speed Pass Canuck[_8_] Aviation Photos 0 August 18th 09 06:13 PM
Doors popping open in flight bob Piloting 43 June 1st 06 02:07 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 05:12 PM
High Speed Passes & the FAA JJ Sinclair Soaring 57 October 6th 03 04:00 PM
