https://en.wikipedia.org/wiki/Pratt_...00_Double_Wasp
The Pratt & Whitney R-2800 Double Wasp is a twin-row, 18-cylinder, air-cooled radial aircraft engine with a displacement of 2,800 in³ (46 L), and is part of the long-lived Wasp family. The R-2800 is considered one of the premier radial piston engines ever designed and is notable for its widespread use in many important American aircraft during and after World War II. During the war years, Pratt & Whitney continued to develop new ideas to upgrade this already powerful workhorse, most notably water injection for takeoff in cargo and passenger planes and to give emergency power in combat. First run in 1937, the R-2800 was America's first 18-cylinder radial engine design. The Double Wasp was more powerful than the world's only other modern eighteen, the Gnome-Rhône 18L of 3,442 in³ (56.4 L). (The American Wright Duplex-Cyclone radial of 3,347 in³ (54.86 L) was also under development at the time,[2] and promised to be more powerful than either the P&W or Gnome-Rhone radials. The Double Wasp was much smaller in displacement than either of the other 18-cylinder designs, and heat dissipation was a greater problem. To enable more efficient cooling, the usual practice of casting or forging the cylinder head cooling fins that had been effective enough for other engine designs was discarded, and instead, much thinner and closer-pitched cooling fins were machined from the solid metal of the head forging. The fins were all cut at the same time by a gang of milling saws, automatically guided as it fed across the head in such a way that the bottom of the grooves rose and fell to make the roots of the fins follow the contour of the head, with the elaborate process substantially increasing the surface area of the fins.[4] The twin distributors[5] on the Double Wasp were prominently mounted on the upper surface of the forward gear reduction housing and almost always prominently visible within a cowling, with the conduits for the spark plug wires emerging from the distributors' cases either directly forward or directly behind them, or on the later C-series R-2800s with the two-piece gear reduction housings, on the "outboard" sides of the distributor casings. When the R-2800 was introduced in 1939 it was capable of producing 2,000 hp (1,500 kW), for a specific power value of 0.71 hp/in³ (32.6 kW/L). The design of conventional air-cooled radial engines had become so scientific and systematic by then, that the Double Wasp was introduced with a smaller incremental power increase than was typical of earlier engines. Nevertheless, in 1941 the power output of production models increased to 2,100 hp (1,600 kW), and to 2,400 hp (1,800 kW) late in the war. Even more was coaxed from experimental models, with fan-cooled subtypes producing 2,800 hp (2,100 kW), but in general the R-2800 was a rather highly developed powerplant right from the beginning. Type Radial engine National origin United States Manufacturer Pratt & Whitney First run 1937 First flown May 29, 1940 The following is a partial list of aircraft that were powered by the R-2800 (and a few prototypes that utilized it at one point): Brewster XA-32 Breguet Deux-Ponts Canadair CL-215 Canadair C-5 North Star Consolidated TBY Sea Wolf Convair 240, 340, and 440 Curtiss P-60 Curtiss XF15C Curtiss C-46 Commando Douglas A-26 Invader Douglas DC-6 Fairchild C-82 Packet Fairchild C-123 Provider Grumman AF Guardian Grumman F6F Hellcat Grumman F7F Tigercat Grumman F8F Bearcat Howard 500 Lockheed Ventura/B-34 Lexington/PV-1 Ventura/PV-2 Harpoon Lockheed XC-69E Constellation Martin B-26 Marauder Martin 2-0-2 Martin 4-0-4 North American AJ Savage North American XB-28 Northrop XP-56 Black Bullet Northrop P-61 Black Widow Northrop F-15 Reporter Republic P-47 Thunderbolt Sikorsky CH-37 Mojave Sikorsky S-60 Vickers Warwick Vought F4U Corsair Vultee YA-19B Specifications (R-2800-54) General characteristics Type: 18-cylinder air-cooled twin-row radial engine with water injection Bo 5.75 in (146.05 mm) Stroke: 6 in (152.4 mm) Displacement: 2,804.5 in³ (45.96 L) Diameter: 52.8 in (1,342 mm) Dry weight: 2,360 lb (1,073 kg) Components Valvetrain: Poppet, two valves per cylinder Supercharger: Variable-speed (in F8F-2, unified with throttle via AEC automatic engine control), single-stage single-speed centrifugal type supercharger Fuel system: One Stromberg injection carburetor Fuel type: 100/130 octane gasoline Cooling system: Air-cooled Performance Power output: 2,100 hp (1,567 kW) @ 2,700 rpm Specific power: 0.75 hp/in³ (34.1 kW/L) Power-to-weight ratio: 0.89 hp/lb (1.46 kW/kg) * |
"Miloch" wrote in message ...
https://en.wikipedia.org/wiki/Pratt_...00_Double_Wasp Check out this monster: The Lycoming XR-7755 was the largest piston-driven aircraft engine ever produced, with 36 cylinders totaling about 7,750 in³ (127 L) of displacement and a power output of 5,000 horsepower (3,700 kilowatts). It was originally intended to be used in the "European bomber" that eventually emerged as the Convair B-36. Only two examples were built before the project was terminated in 1946. It would have been a maintenance nightmare. It makes you wonder where aviation would be today had it not been for the fortuitous appearance of the gas turbine engine. |
OOPs - Smaller This Time Pratt and Whitney Twin Wasp Aero Engine 6/6] TAM089.JPG (1/1) 111 K | Mr Bill[_2_] | Aviation Photos | 6 | March 31st 08 06:00 PM |
OOPs - Smaller This Time Pratt and Whitney Twin Wasp Aero Engine 5/6] TAM088.JPG (1/1) 101 K | Mr Bill[_2_] | Aviation Photos | 0 | March 31st 08 09:18 AM |
OOPs - Smaller This Time Pratt and Whitney Twin Wasp Aero Engine 2/6] TAM085.JPG (1/1) 134 K | Mr Bill[_2_] | Aviation Photos | 0 | March 31st 08 09:18 AM |
OOPs - Smaller This Time Pratt and Whitney Twin Wasp Aero Engine 1/6] TAM084.JPG (0/1) 94 K | Mr Bill[_2_] | Aviation Photos | 0 | March 31st 08 09:18 AM |
Was the Pratt & Whitney Double Wasp the best engine of WW II? | Dave Kearton | Aviation Photos | 18 | January 12th 07 07:20 PM |
