What are your opinions on the Slingsby Skylark 4?
Old April 11th 17, 09:50 PM posted to rec.aviation.soaring
Default What are your opinions on the Slingsby Skylark 4?
How did it stack up against the K6e, SHK, etc.?
How are it's flying qualities?
What's your thoughts?
Thanks so much!
-Nick
Old April 11th 17, 10:05 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Thanks so much!
-Nick
My main memory is rigging the club 4... Very heavy centre section that must be held close to fuselage in order to connect controls; nervous work. Outer panels light. There is a flight report in Winning on the Wind vol 1 page 31-33; he found it slightly superior to the Ka-6, though larger and heavier.. He liked the handling and comfort for a tall man.
Old April 11th 17, 11:29 PM posted to rec.aviation.soaring
Thanks so much!
-Nick
Do you have a hangar which is at least big enough to accommodate the glider with the center section rigged? If so, then if K6E performance with a big comfortable cockpit appeal to you, a Skylark 4 is worth considering.
Old April 11th 17, 11:46 PM posted to rec.aviation.soaring
Have flown and assembled all three. Ka6 the easiest to assemble and easiest to fly, probably one of the nicest handling sailplanes ever built. Skylark 4 more involved to assemble, but very nice to fly, docile, and good climber. SHK wings heavy and require technique, but very manageable with a SoloRigger. The SHK will easily outperform the Ka6 and Skylark 4 . The handling is good, but not as docile as the Ka6 or 4. The Skylark 4 is very capable of all badge distances downwind and is enjoyable to fly. If you are considering buying a Skylark 4 , you should call Bruce Beddow who has owned a 4 for over 20 years.
Old April 12th 17, 10:22 AM posted to rec.aviation.soaring
Peter Whitehead
I did 2 diamonds in K6e and Skylark 4 in the UK. 300 triangle in the Skylark, so amazingly comfortable and roomy, a gentleman's machine. Trim in pitch the best,can fly hands off. K6e a disaster in this respect. Skylark 4 ailerons need some work, k6 a delight to fly, much easier for working the thermals, though the Skylark, once centered, allows you to eat your lunch. If you are a big chap I would go for the Skylark, especially if can be left in hangar with tips off. Airbrakes good on both, but skylark's are supreme, the best of any glider I have flown. Pete
Slingsby T.61 MotorFalke R. Wubben Soaring 11 December 10th 17 07:38 PM
For all things Slingsby Jack Russell Soaring 0 January 18th 15 11:20 PM
Gliders at Camphill 2 - Slingsby T-41 Skylark 2C Andrew B Aviation Photos 0 July 1st 09 10:09 AM
Skylark test flight and piloting technique. Roger (K8RI) Piloting 0 May 9th 07 03:05 AM
Slingsby T-21 Nyal Williams Soaring 14 March 1st 07 08:28 AM
