DISCUS CS W&B
Old May 28th 17, 02:12 PM posted to rec.aviation.soaring
Default DISCUS CS W&B
Good Morning --
The Discus CS maintenance manual (page 29) uses a value of 135mm (5.3 inches) as the 'A' distance between the datum and the main wheel axle. For those who have actually measured this, do you get a range of values -- because of manufacturing differences - or because springs/shocks age over time. thanks ... kk
Old May 28th 17, 03:32 PM posted to rec.aviation.soaring
Distance from datum to main gear may (will) vary due mostly to shock absorber being somewhat compressed. Best to block the gear in the full down position, then measure that distance. Remember to do all measurements with the ship in level position. Weights at known accurate distances will produce accurate results.
Hope this helps,
JJ
Old May 28th 17, 04:32 PM posted to rec.aviation.soaring
Hope this helps,
JJ
JJ - thanks ... kk
Wanted DIscus CS or Discus B [email protected] Soaring 0 November 14th 08 01:17 PM
Discus verus Discus 2, LS8, ASW 28 Roger Soaring 45 October 31st 06 03:43 PM
Discus 3 or Super Discus? Mirek Soaring 1 June 13th 04 09:28 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
