A Tale of Two Takeoffs
Old June 17th 17, 09:25 PM posted to rec.aviation.soaring
Echo
Default A Tale of Two Takeoffs
That's pretty interesting. Seems incredibly minute, but if it gets results there's not much to argue with. My only point against teaching it is the complexity it adds to a launch, when there's already a lot going on and plenty to be aware of. I can see it needs to be muscle memory. Thanks for the explanation.
Jordan
Old June 17th 17, 09:29 PM posted to rec.aviation.soaring
Echo
While I'm in an inquisitive mood, here's another one. What speed are you flying when you thermal your ballasted glider in a 45 degree bank in a gaggle, allowing for the extra energy required for surprise maneuvering? What speed were you being towed at 15 minutes earlier that resulted in your vhf complaint for more speed from the tug driver? Since you're flapped (I'm assuming), what flap setting are you using on tow? Trying to better understand this...
Jordan
Old June 17th 17, 09:48 PM posted to rec.aviation.soaring
Actually, I consider this incorrect.
When trained for any job, there is a lot to learn. Things like:
Glass ship, dive brakes open, pilot typically HAS to be holding them open. No comment pre launch
Metal ship, dive brakes open, may be by mistake, say something.
Check for tail dolly
Point out other traffic
Etc.
Nut behind the stick is final say.
Example, annual Snowbird contest in Elmira, people talk about practice for the event (look it up for rules and goal). In reality, it is to reinforce energy management for potential off airport landings and proper landing placement. People that have to practice means they are not ready when it happens in the future, but if properly reinforced all flying season you should do well when needed.
Running a wing should be the same every flying day, contest should only get a minor tweak due to a slightly faster than normal launch and potentially higher glider density. Judgement on go/no go by the runner may be hard, but all the other basics should be covered.
Posted by someone that used to work contests (as ground crew, runner, retrieve, etc.) since the mid '70's and contest flying later on. I also do ground duties even now when at the airport.
The old adage of, practice for the worst, hope for the best, comes to mind. If you don't do it all the time, a contest can be a bad place to learn.
Chip, thanks for the thread. It takes some guts to post this in front of some of the RAS crowd. I have had some of my own nail biters in the past, so I understand.
Old June 17th 17, 09:52 PM posted to rec.aviation.soaring
When you're in a ASW-20C @9lbs on tow and you feel like you are always about to stall on tow, that is too Frikkin slow. Yes, been there done that, feigned an issue so I didn't end up behind that tug later in the contest when wet.
Speed in thermal? Sorta depends on if smooth or rough, I don't know, what feels good? As AOA goes up, some airspeeds lose accuracy. If the plane feels happy, then I'm happy.
I'm too busy watching for other traffic and rely on sound and feel, not looking at an instrument that is a second or two behind actual.
Old June 17th 17, 09:57 PM posted to rec.aviation.soaring
firsys
On Friday, June 16, 2017 at 7:55:55 PM UTC-4, wrote:
I have a secret.
Well, like secrets in a Congressional Intelligence subcommittee, this one is probably known by several hundred people. But I haven’t written about it. Until now.
But first, the lead in. A few days ago on the last day at the Cordele nationals, I dropped a wing on takeoff. The ballast tanks were half full so although the tip didn’t go down hard, the water sloshed in that direction and the wing stayed down. My ASW 24 started to swing off to the right. I wasted no time in pulling the tow release. The glider continued to swing and I braked as I rolled off the asphalt runway into the grass and stopped..
No big deal. I’ve had a rule for many years that if the wing goes down early with ballast, I release. It's almost impossible to get the tip up again (more later). I’ve done it twice before--both times on grass--and it’s slightly embarrassing but uneventful except for blocking the launch. This time I actually rolled out of the way. Not much more than five minutes later, I had been retrieved with a golf cart, put back on the launch line, and was away without ever having to climb out of the cockpit.
Old June 17th 17, 10:28 PM posted to rec.aviation.soaring
Echo
Yeah I'm asking for numbers. I own and fly a ballasted 20. And I've towed my share of contests at Perry and New Castle. I'm asking someone to look in their manual and give me their numbers. I know what the slowest I've towed even a club glider is. I know my 45 degree bank thermal speed full of water.. I still thermal slower than my slowest tow...and towing is a lower bank angle so more margin than thermalling with gliders in 3 quadrants. So the "about to stall" thing on tow is why I ask for numbers. "Feel" is not something I can reference as a tow pilot. If it's for your own comfort, I'd suggest asking for a specific speed. Not "faster." Personally in my 20, flaps 4 and ballasted I feel like I'm standing on my pedals. I usually back off the flap to 3 or 3A once up and settled. Maybe we just tow faster around these parts...
Jordan
Old June 17th 17, 11:24 PM posted to rec.aviation.soaring
I agree, Hank; ballasting was my responsibility. On the grid at Cordele, I removed the wing wheel and double checked, taking time to make sure the water had stabilized and the wings were level. Obviously I misjudged it standing at the right wing because later, after the line crew removed my wing wheel, from the cockpit it seemed like the girl at the right wingtip was holding it a little high (indicating it was heavy). I called out to her over the tow plane noise not once but twice with "Are they balanced?" She nodded the first time. The second time she took her hand off the wingtip to show me ("why doesn't that man believe me?" haha). Since she had the wings balanced, I didn't even think about declining the launch; the line crew had it under control.
I have assumed--but don't know--that when she handed the wingtip to the actual wing runner, that balance was lost. If it looked high to me, it probably did to him. Maybe the slight tailwind contributed. Maybe I just did a bad job on takeoff. Most important, unlike at Nephi, this time I made the right decision and pulled the release. No harm done.
[I'm thinking of using a bubble level or other visual indicator so I can ensure the wings are level when I'm solo. I've seldom launched with full tanks and dumped down; even at max gross the water still sloshes around and the takeoff performance is reduced.]
Agreed, wing runners don't have to be experts but they must know the basics.. And that includes balancing the wings. Even when my tanks are absolutely even, the wing runner still has to make sure one tip isn't lower/heavier than the other. There are no baffles; just two compartments per bag that allow water to flow easily back and forth. It's as important as not letting go of the tip after two steps and not holding back when they can't keep up.
Contest line crews are heavily populated with local kids, many of whom don't have much experience. They're enthusiastic and athletic and they learn quickly. But they have to be trained and supervised. Perhaps we need to add a session for them in the pre-contest briefing where pilots can express their concerns and even demonstrate what works and doesn't work for their gliders.
Some years ago, the young, inexperienced wing runner at a Hobbs multi-class nationals was holding back, steering pilots off course. The problem was the advice he was getting to grasp the wing by both the leading and trailing edges. I didn't want to argue technique on the line so I immediately drafted my daughter, who had never run a wing before. I briefed her for a few minutes, calmed her nervousness, and reassured her she would do great. A 16-year-old high school track star, she ran it perfectly...and was promptly approached by half a dozen pilots to run their wings. The operations director watched what was going on, then quickly recruited her for the line crew. She ended up running wings for nearly all of the crewless pilots at the contest.
This made the contest a lot more fun for Tina, she took home a few bucks from the "pass the hat" line crew fund, and she wrote her college common app essay on the experience, which apparently impressed admissions directors. Soaring is a great sport!
Don't just gripe; speak up...constructively. The Cordele line crew did a fine job the past two weeks. But when I observed one of the younger ones struggling to balance a ballasted wing during the pre-contest weighing, I approached the operations director there and politely advised him that many of us would be launching with partial ballast and it was critical to balance, not necessarily level the wings before launch. He graciously acknowledged my concern and said he would make sure the crew were properly instructed. I believe they were.
John is correct. It's hardly whining to suggest there are problems at many contests involving the launch sequence. I've thrashed the wing runner issue to death. Sometimes tow pilots show up who haven't towed a lot of ballasted gliders, or towed at that airport, or whose aircraft have ASIs that aren't spot on. I have to call for "[towplane ID], 5 knots more airspeed, please" at least once a contest.
The next tow I got at Nephi after my incident last year was from the same tow pilot. And, again, he seemed to stand on the brakes while powering up, then release them with a predictable slingshot effect on the tow rope. I sought out the chief tow pilot, asked him about the practice, and diplomatically offered my assessment. He listened thoughtfully and promised to talk to the tow pilot. Whatever was said, if anything, it didn't happen again.
He didn't suggest that I bring my own tow pilot if I didn't like the ones he managed.
We pilots should be proactive in helping organizers address staffing issues.. Pilots certainly make mistakes; organizers do, too. The smart ones accept our criticism and suggestions graciously, decide which ones make sense, and take appropriate action.
Just my opinion.
Chip Bearden
"JB"
Old June 17th 17, 11:56 PM posted to rec.aviation.soaring
So, you're assuming everyone has a calibrated ASI that reads just like everyone else's?
"What's it sound like, what's it feel like"?
I can't answer your question, I'm watching for traffic and the local gaggle when on tow.
I listen and feel for what is correct. When I'm afraid to do anything beyond minor on controls because it may stall, I'm not happy.
Period.
If you need hard numbers, maybe you need more training?
Posted by an ex CFIG for 8 years.
Old June 18th 17, 01:36 AM posted to rec.aviation.soaring
BobW
That's pretty interesting. Seems incredibly minute, but if it [using
spoilers early in the takeoff roll] gets results there's not much to argue
with.
The effect may indeed be minute, and it almost certainly will vary from ship
to ship for a host of subtle, perhaps forever-mysterious, reasons but, "If it
happens, it must be possible!" That noted, "safe soaring" is all about risk
management, and risk management is all about maximizing one's margins in any
given situation. By single-main-wheel definition, takeoff in a sailplane is a
low-margin situation (hence the near-universal need for a wing runner), and
anything Joe Pilot reasonably can do to minimize his time at risk is arguably
worthwhile doing.
Ah, yes, a sixty four dollar question: "Where and by whom shall the technique
be taught and practiced?" Beaucoup soaring skills are self-learned/self-taught
(one of the attractive charms of the activity in my view). Arguably a quick
way to kill the sport dead would be to mandate from the top down a list of
things that *must* be taught over and above those things presently mandated,
on the grounds of soaring presently having insufficient safety. That's not
meant to suggest I completely agree with the level of federal mandation
presently existing (I am not an an instructor nor have I ever played one on
TV), just that "the safety card" over-enthusiastically applied can squash just
about any human activity unto death. (How ironic.) A life reality is there's
no practical way to avoid having to "self-certify" by innumerable daily
decisions/judgements/practices, if we're to remain alive so we can continue to
enjoy what life has to offer. Soaring isn't immune from the
"self-certification need."
Sensible ways for Joe Soaring Pilot to "post-licensing self-certify" would
seem to be much more widely known in general than are (f'r'example) certain
areas of need (e.g. how to enhance aileron power at low speeds). But that'd be
another thread...!
You're welcome. This aspect of soaring eventually became a subtlety left for
Joe Soaring Pilot to discover, contemplatitively explore, and learn how to (if
deemed desirable) mitigate "on his own"...and evidently, still is. An easy way
to "avoid the need" for this particular bit of self-teaching is to avoid
flying those higher-aspect ratio glass gliders none of us would ever willingly
give up! Interested readers will find references to the technique beginning to
appear in "Soaring" mag way back in the 1980s.
Bob W.
This email has been checked for viruses by AVG.
http://www.avg.com
Old June 18th 17, 01:54 AM posted to rec.aviation.soaring
I don't know of anyone who teaches it. I watched other pilots do it and spoke with them, then tried it myself. It works on my ASW 24.
BTW, I cycle the dive brakes open and closed (without locking them) as the slack comes out of the rope to let the wing runner know I haven't simply forgotten to lock them. Once I have aileron authority, I close and lock them and then focus on lifting off smoothly. Yes, it's one more motion. But I flew a flapped ship for a long time and lowering the flaps to lift off is a little bit analogous, although the lever moves in the opposite direction.
Gary, it's possible you didn't find it necessary because the Pegasus wing may have had a lower angle of incidence than some other Standard Class gliders. I seem to recall reading or hearing that although I can't find any references.
Chip Bearden
"JB"
14 takeoffs = 14 approaches - Video [email protected] Piloting 0 February 4th 10 01:16 AM
Any early turn takeoffs still around? Michael Instrument Flight Rules 12 June 6th 04 06:24 PM
Ground steering and Takeoffs webmaster Simulators 3 February 15th 04 08:34 PM
F-15 takeoffs Mary Shafer Military Aviation 2 July 1st 03 07:41 AM
