Color Platforms for Top Hat/XCSoar
Old June 23rd 17, 08:03 PM posted to rec.aviation.soaring
Default Color Platforms for Top Hat/XCSoar
What color devices are pilots using for Top Hat/XCSoar? I'm running Top Hat on a Kobo Glo (large eink gray scale--great readability) and a Dell Streak 5 (smaller screen, color, acceptable readability). If the Dell were a little brighter and larger, it would be perfect.
Options seem to range from other mobile phones all the way up to the OpenVario project (at least for XCSoar). What works for you?
Chip Bearden
"JB"
Old June 23rd 17, 08:20 PM posted to rec.aviation.soaring
Mike C
Chip Bearden
"JB"
The 7" Streak works well - if you can find one. About the same brightness as the 5", but easier to read due to the size. I usually use the smaller Streak. These days I think color really is not much of an advantage. The real info is in the info boxes.
Mike
Old June 23rd 17, 08:31 PM posted to rec.aviation.soaring
Dan Marotta
Though I have a ClearNav II in my Stemme, I also have a Dell Streak 5
running XCSoar on the right side of the cockpit. I find that each
platform delivers information that the other does not or delivers
similar information in a more understandable way. Even when I fly solo,
I run the Streak for the added information. Note that I have the
terrain display turned off as it makes for a much clearer display, not
to mention that I have a high definition canopy displaying the terrain.
Chip Bearden
"JB"
Mike
Dan, 5J
Old June 23rd 17, 09:35 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
A Medion S.3747. It has a transreflective screen which is more readable
in bright sun than any of the purely backlit devices. It also has an 800
mAH removable battery.
It is a smaller screen - 3.5" - but that is a benefit if, like me, you
fly a glider with the panel inside under the nose fairing (Std Libelle in
my case) because this prevents anything from hanging out over the edge of
the panel. I'm actually running LK8000 rather than XCSoar, but that
doesn't affect this discussion.
IMO the S.3747 is worth grabbing if you can find one.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 24th 17, 02:50 AM posted to rec.aviation.soaring
I use a Nexus 2013 7 inch. Its best with polarized sunglasses. Otherwise there is a reflection. I have also used a moto g3 which also worked great.
Old June 24th 17, 02:58 AM posted to rec.aviation.soaring
Dan Daly[_2_]
I use XC Soar on an Oudie Lite; before, on a Streak 5 inch. I had connected the Streak by IOIO board, I now connect the Oudie to a CNv with the Goddard cable. I prefer the Oudie for visibility.
Old June 24th 17, 03:26 AM posted to rec.aviation.soaring
Chip Bearden
"JB"
Samsung Galaxy Note 4.
Daylight readable with polarized sunglasses
Internal GPS and barograph for backup system use.
Large very high resolution screen
many spares available
Recent android OS not obsolete windows CE type stuff - will be supported for several more years.
Wifi
Bluetooth
I used it 2 years with XCsoar and it worked great.
Old June 24th 17, 05:01 AM posted to rec.aviation.soaring
Garrett McEwen
Currently using LG G3. Works great. Replaceable battery, bright enough screen, works in any orientation with polarized glasses, excellent built in barometer.
Old June 24th 17, 05:04 AM posted to rec.aviation.soaring
SoaringXCellence
I'm currently trying an OpenVario with XCSoar. Open source all around. It's a nice system. Check out details at openvario.org. I think TopHat has a Linux version that will work.
Old June 24th 17, 05:49 AM posted to rec.aviation.soaring
JS
A couple of friends are using OpenVario. Heat can be a problem.
Pacific War in Color, pt 9 - P 61 in color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 April 5th 17 01:18 PM
Pacific War in Color, pt 8 - P 39-color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 1 April 4th 17 08:41 PM
Pacific War in Color, pt 8 - P 39s-color.jpg (1/1) Mitchell Holman[_9_] Aviation Photos 0 April 4th 17 01:31 PM
XCSOAR Travis Beach[_2_] Soaring 3 May 24th 08 03:36 PM
Flying platforms/airgeeps David L. Burkhead Home Built 3 January 19th 05 06:33 AM
