LX Question
Old July 12th 17, 06:27 PM posted to rec.aviation.soaring
Bob Caldwell (BC)
Default LX Question
Hi Pilots,
I am looking for some understanding about an issue with my relatively new LX 9000. I have the map settings to be Track Up in cruise and North Up while circling just like I have done with previous instruments. The problem I am experiencing is that when pulling out of a circle and going to cruise the little glider symbol does not align with the course line. It is variable, sometimes pointing off as much as 30 degrees. The course line still points straight up but the glider symbol is heading off in some other direction.. I haven't been able to find a setting for adjusting this.
Any input is appreciated, thanks.
Bob
Old July 12th 17, 10:56 PM posted to rec.aviation.soaring
Scott Williams
Default LX Question
Hey Bob,
A few years ago I was flying with a filser dx50 (grandpa to the LXs)
I remember the glider icon doing what you describe, I never gave it any thought, it is just an icon on a screen.
Good Lift,
Scott
Old July 13th 17, 01:32 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default LX Question
On Wednesday, July 12, 2017 at 2:56:59 PM UTC-7, Scott Williams wrote:
Hey Bob,
Good Lift,
Scott
Scott,
Totally different instrument, totally different company.
LXNAV has nothing to do with filser.
Richard,
Old July 13th 17, 08:41 AM posted to rec.aviation.soaring
Default LX Question
If you want the glider symbol to always point up you need a heading up option. I use goal up in the cruise so that the direction from current position to the next waypoint is up.
Old July 13th 17, 10:24 AM posted to rec.aviation.soaring
Default LX Question
This angle is showing the wind. The plane symbol should be showing the real heading of the glider. The course line is the ground track.
Old July 13th 17, 03:42 PM posted to rec.aviation.soaring
Bob Caldwell (BC)
Default LX Question
Wow, I hadn't thought about the wind and the crab angle. I will check that out. Thanks for the input.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
ILS question Chris Brooks Instrument Flight Rules 71 June 23rd 04 01:57 PM
A 707/720 question DeltaDeltaDelta Piloting 1 January 22nd 04 01:05 PM
