Hi all,
I have fund a nice 109B in Germany. Just wondering about the FAA hassle to get it registered....... Also it has a Grob engine.......talk with Grob in Germany about there engine. Looks like not many parts left. The engine has about 180hrs left. What are you guys thinking ? Thanks Klaus |
I had no difficulty importing my Stemme from Mexico into the USA. Since
the Stemme has an LBA or EASA Type Certificate Data Sheet (TCDS), I simply presented that to an FAA Designated Airworthiness Representative (DAR). He checked the aircraft against the TCDS and issued a US Standard Airworthiness Certificate. Assuming the Grob has a TCDS, there should be no problems with the FAA also assuming the aircraft still conforms to the TCDS. I would be concerned, however, with an orphaned engine with only 180 hours left. What do you do when the engine is no longer airworthy? On 7/17/2017 1:59 PM, Klaus Oestreich wrote: Hi all, I have fund a nice 109B in Germany. Just wondering about the FAA hassle to get it registered....... Also it has a Grob engine.......talk with Grob in Germany about there engine. Looks like not many parts left. The engine has about 180hrs left. What are you guys thinking ? Thanks Klaus -- Dan, 5J |
At 23:23 17 July 2017, Dan Marotta wrote:
I had no difficulty importing my Stemme from Mexico into the USA. Since the Stemme has an LBA or EASA Type Certificate Data Sheet (TCDS), I simply presented that to an FAA Designated Airworthiness Representative (DAR). He checked the aircraft against the TCDS and issued a US Standard Airworthiness Certificate. Assuming the Grob has a TCDS, there should be no problems with the FAA also assuming the aircraft still conforms to the TCDS. I would be concerned, however, with an orphaned engine with only 180 hours left. What do you do when the engine is no longer airworthy? On 7/17/2017 1:59 PM, Klaus Oestreich wrote: Hi all, I have fund a nice 109B in Germany. Just wondering about the FAA hassle to get it registered....... Also it has a Grob engine.......talk with Grob in Germany about there engine. Looks like not many parts left. The engine has about 180hrs left. What are you guys thinking ? Thanks Klaus -- Dan, 5J I would assume that getting a German Export C of A would cost a LOT less than hiring a DAR in the USA. Also, the Export C of A inspection over there could possibly unearth big issues (before the sale is final and the aircraft is shipped), as opposed to a DAR finding them while inspecting it here. The only problem is that the German Export C of A process/De-registration will take 3+ months to complete over there. If you have a German Export C of A and De- registration (Make sure the make, model, serial number on the documents match EXACTLY with your FAA registration application.), and all documents are in order, then the FAA C of A inspection becomes a relatively minor formality. As far as the engine goes (if it were me), I'd be looking for a replacement engine that has already been overhauled or at least another complete "parts engine" for spares. I am no expert in that field though, and will defer to others with more knowledge. We had a G109B in our club as a 5 year lease-back during the Reagan tax credit era. I liked it a lot, but found it incredible that an aircraft like this (which was a lot more complicated than a C-150) would only require a glider license to fly it... RO |
On Monday, July 17, 2017 at 3:59:22 PM UTC-4, Klaus Oestreich wrote:
Hi all, I have fund a nice 109B in Germany. Just wondering about the FAA hassle to get it registered....... Also it has a Grob engine.......talk with Grob in Germany about there engine. Looks like not many parts left. The engine has about 180hrs left. What are you guys thinking ? Thanks Klaus IIRC, Grob did a 912 update for the 109, but there were *issues* regarding completing the certification. Iff these *issues* were resolved, it *might* be possible to have the update done in Germany (with paperwork, ie EASA certs), in which case this would be a much more desirable (but certainly more expensive) machine... Hope that helps, Best Regards, Dave |
Export CofA in Germany is a days work. Certificate of deregistration can be
arranged from the LBA in a week. Been there, done that. Have the current owner do it as part of the deal. Saves hassle. |
At 05:48 18 July 2017, Eric Munk wrote:
Export CofA in Germany is a days work. Certificate of deregistration can b arranged from the LBA in a week. Been there, done that. Have the current owner do it as part of the deal. Saves hassle. Hello, I'm a EASA-FAA engineer & have worked on the G109B-Grob 2500 engine for the last two years. If you want to replace the engine with a EASA/FAA compliant unit, the only company presently advertising an overhauled engine from the factory is Soaring Oxford in the U.K. Please find link below. http://www.segelflug.de/osclass/inde...=item&id=16512 The company normally supplies spares to the RAF cadets flying schools, which no longer require the engines having "Scrapped" the majority of their fleet, hence an abundance of spares no longer required held by Soaring Oxford. The company is expensive, having dealt primarily with the RAF cadets & not having to "trim" their profit margins. I'm sure a discount is available if you play "Hard Ball". Good luck. Best regards Paul |
Hi all, I have fund a nice 109B in Germany. Just wondering about the FAA hassle to get it registered....... Also it has a Grob engine.......talk with Grob in Germany about there engine. Looks like not many parts left. The engine has about 180hrs left. What are you guys thinking ? Thanks Klaus If those engines are VW derivatives wonder if it would be possible to register it as an experimental when needed use one of the current VW based experimental aircraft engines? |
I think Paul Weeden just posted something on Facebook about having a grob 109 engine. Not sure which version
![]() On 7/17/2017 6:36 PM, Michael Opitz wrote: We had a G109B in our club as a 5 year lease-back during the Reagan tax credit era. I liked it a lot, but found it incredible that an aircraft like this (which was a lot more complicated than a C-150) would only require a glider license to fly it... I hear ya, Brother! I don't think I'd trust any C-150 or C-140 (tail dragger) pilot to fly a Stemme with simply a glider license. Still, as I get older and don't want to fly power planes any more, it's good that I don't need a physical to fly the Stemme. I'll know when it's time to quit or my wife will let me know... -- Dan, 5J |
Grob 109B Vector Diagram | Go Soaring | Soaring | 0 | March 23rd 15 03:26 PM |
Wanted Grob 109B | Nick Kennedy | Soaring | 4 | November 12th 14 12:36 AM |
Exporting a glider to/import a glider into Germany | Pete Smith[_2_] | Soaring | 1 | August 8th 08 09:33 AM |
import | Hugh Newbery | Soaring | 1 | June 8th 08 01:44 PM |
Are "Popups" A Hassle? | skym | Instrument Flight Rules | 45 | November 10th 05 06:23 PM |
