glue to rebond rubber tailskid to LS6
Old July 25th 17, 04:48 PM posted to rec.aviation.soaring
Brian[_1_]
Default glue to rebond rubber tailskid to LS6
I have used Pliobond, comes off with acetone.
http://www.aircraftspruce.com/catalo...s/pliobond.php
Old July 26th 17, 02:40 AM posted to rec.aviation.soaring
Bob Kuykendall
On Monday, July 24, 2017 at 10:22:43 AM UTC-7, JS wrote:
Consider cutting a hole in the bottom of the tail (discovering that there is already a wheel well in the LS6) and installing a tail wheel...
If your LS6 is Experimental, I have a fender and external fairing that fits if it turns out that it isn't already in there.
--Bob K.
Old July 26th 17, 02:12 PM posted to rec.aviation.soaring
--Bob K.
The inner fender is part of LS-6 aft construction, even when skid is installed, based on the one I worked on. It would require the factory drawing to duplicate the mounting of the axle bolt.
FWIW
UH
  #24
Old July 26th 17, 04:16 PM posted to rec.aviation.soaring
Tango Eight
On Tuesday, July 25, 2017 at 7:24:57 AM UTC-4, wrote:
On Tuesday, July 25, 2017 at 6:49:44 AM UTC-4, Tango Eight wrote:
On Tuesday, July 25, 2017 at 2:43:24 AM UTC-4, POPS wrote:
Permanent, not coming off, done.
And so how does it go when you need to remove the skid, for some reason?
best,
Evan
I've never used 5200 but know boatbuilders don't like it for many applications because it is unpleasant to undo for repairs.
The glue on skid idea was always kinda dumb. But it seems *really* dumb to glue the thing on in some fashion that's going to require a sawzall and disk grinder to remove.
Contact cement works. The thicker, gap filling solvent based adhesives (the "goo" and "goop" products) work better, are more forgiving prep wise. These can be worried loose when needed, without destroying the skid.
It's not necessary to overthink this.
best,
Evan
  #25
Old July 26th 17, 05:24 PM posted to rec.aviation.soaring
Sean Fidler
https://youtu.be/soqfhLSEe_0
  #26
Old July 27th 17, 01:22 AM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, July 26, 2017 at 8:16:34 AM UTC-7, Tango Eight wrote:
...going to require a sawzall and disk grinder to remove...
Mmmmm... Sawzall...
  #27
Old July 28th 17, 04:39 AM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Like a tuna .... fillet it off with a NEW razor blade, the ones used in utility knifes. Easy. Liquid vise grips, vise grips and epoxy, nothing more needed in this world.
best,
Evan
Looking for Wedekind sleeves and tailskid with wheel... [email protected] Soaring 6 January 30th 15 02:42 AM
Keep the rubber side down! Waveguru Soaring 1 September 24th 12 04:57 AM
Gluing rubber pieces [email protected] Home Built 16 June 2nd 09 05:32 AM
Rubber stamp??? Tri-Pacer Owning 13 January 28th 06 07:04 PM
Rubber Stamp ??? Tri-Pacer Home Built 7 January 26th 06 01:34 PM
